Question about Kenmore HE3T Washer
Kenmore Elite Smartwash Quiet 9 I can not locate the manual and my washer says ''control locked'' and I can't do anything. How do I unlock it?
  • 5,911 Answers
The following link explains how to correct a "Control Lock" problem on a Kenmore Elite:
http://www.fixya.com/support/r2469429-kenmore_elite_amp_whirlpool_duet
If this does not correct your problem, you may have a more serious issue. Please post back and let me know. I hope this helps you.
Posted on Aug 04, 2009
Kenmore elite smartwash quiet pak 4
This video will show you how to change a door seal on this Bosch front loader washing machine
You can find more Bosch videos in our Bosch repair channel
Jul 22, 2013 | Kenmore Elite 45986 Front Load Washer
Kenmore elite smartwash quiet pak 9 he4t the washer starts filing water when the washer is turned off.
This is symptomatic of a malfunctioning water control valve- not closing fully- the hot water one, if the washer is hot and cold fill, and the cold one if it is just cold fill!
Sorry but it needs replacing and a service call ;-0(
Good luck,
John C
Mar 19, 2011 | Kenmore Elite 45986 Front Load Washer
I have a kenmore elite smartwash and the machine says contols locked, is there any way to reset that?
This advise is for Kenmore Elite and Whirlpool Duet front loader washers and dryers with a Control Lock problem.
This may or may not be an indication of a serious problem. In the majority of the cases, this is a simple operator error. Nearly all these model appliances have some sort of Control Lock feature on the front panel now. This is a designed safety feature that is used to prevent small children from manipulating the controls. The controls can be easily locked or unlocked by pressing and holding the following button on the front panel:
Whirlpool Duet Washer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Whirlpool Duet Dryer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Kenmore Elite Washer - Press and hold the DRAIN/SPIN button for 3 seconds.
Kenmore Elite Dryer - Press and hold the AUTO DRY LEVEL button for 3 seconds.
These instructions may not be all inclusive for all Kenmore and Whirlpool models, but they are the most common. Chances are, if you have a Control Lock feature, the instructions will be printed on the front panel adjacent to the button that is required to lock or unlock the controls.
NOTE: These instructions may also work for newer model Maytag, Hotpoint, Admiral and Fridgidaire model front loaders as well. Refer to your owner's manual or front panel for instructions pertaining to your sepcific model.
If the Control Lock feature will not lock or unlock the appliance, unplugging the unit for AT LEAST 30 minutes is recommended in order to reset the main control board. In many cases this is all that is required to correct momentary glitches.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 25, 2010 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite is now LOUD during spin cycle
It appears your clutch assembly has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Jun 11, 2010 | Kenmore Elite 45986 Front Load Washer
I have a kenmore elite smartwash quietpak 9 HE4t. The control locked light is on. I have tried unplugging for an hour and plugging back in, door is unlocked but no buttons work. What can I DO
The following link explains how to correct a Control Lock problem on a Kenmore Elite:
Some front panel features differ between models, but the instructions should be listed on the front panel of the washer, and are located in the operator/owner's manual. If these preliminary measures do not work, you may have a mnore serious problem.
If you have any questions, please let me know. I hope this helps you.
Aug 23, 2009 | Kenmore Elite HE5t Washer
Kenmore smartwash quiet pak 9 is leaking
The lint is likely from the drum seal rubbing over time.
Aug 07, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite HE4t Washer Control lock lit, door locked
121 MINUTES USUALLY DRAIN CYCLE PLZ REMOVE 3 BOTTOM PANEL SCREWS 7 MM SCREWS, TO OPEN DOOR SLIDE RIGHT HAND TOWARDS DOOR LOCK ,THERE WILL BE A SMALL LEVER TOO PULL DOWN ,NOW ITS OPEN,,, SINCE U HAVE BOTTOM PANEL OFF PUMP IS RIGHT IN FRONT REMOVE PLASTIC HOUSING CLOCKWISE ,,,REMEMEBER HOLD 3 GALLONS OF WATER STILL ,HAVE BUCKET READY ,NOW CLEAN OUT PUMP AND DEBRIS ,, CLOSE IT UP SHOULD BE FINE NO MORE PROBLEMS ,,,,,
Jan 01, 2009 | Kenmore Elite 45986 Front Load Washer
Door stuck Locked Control Locked light on
Try unplugging the washer for at 30 minutes to reset the computer, first. If this proves unsuccessful, you can retrieve you clothes by using the manual release. The following link explains how:
http://www.fixya.com/support/r622155-kenmore_elite_whirlpool_duet_door_jammed
Once you retrieve your clothes, try running diagnostics on it. You can envoke the diagnostic sequence by selecting DRAIN/SPIN, NO/SPIN and then pressing any button under OPTIONS 4 times (must be the same button). The display should go to "C00" as the washer begins a sequence of tests that checks the fill functions, door lock, dispenser functions, motor speed, spin and drain. Allow the washer to run through the entire sequence and shut off. If anything is wrong an error code should be generated. Hopefully, all you had was a minor glitch. Let me know how things turn out. I hope this helps you.
Aug 25, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore HE3T Washer Logo
275 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
