Question about Galaxy Cell Phones
How i unlock a galaxy on 5 - Galaxy Cell Phones
FRP unlock galaxy note 5 easiest and fastest way possible to do it
Hi James.
If you are looking for network unlock code for Samsung galaxy note 5 then here is the direct link to get the unlock code simply with in 2 steps. Just go to the link below
https://www.unlockninja.com/unlock-samsung+galaxy-note-5
Select: Country
Select:-Network
Update IMEI to get the network unlock code
May 14, 2018 | Galaxy Cell Phones
Locked out of my galaxy s7 phone cannot remember my pin
I guess Samsung galaxy mobile is locked due to you have entered unlock key more then 5 to 10 times. And now your samsung galaxy mobile is freezed and hard locked.
Now to Unlock samsung galaxy mobile you need unfreeze code and then sim unlock code or sim network unlock pin. You can generate unlock code from imei number of your mobile. it generate 4 codes. First is your sim unlock pin and last is defreeze code.
You can also try this alternate method for unlocking your galaxy mobile.
If you have rooted your mobile and want to unlock it without code then You need custom rom , bootloader unlock file and also flashing tool. And also download samsung driver from samsung site.
Now once mobile is rooted flash rom on it and unlock bootloader for samsung unlocking.
Instead of this you can also try this method to unlock your samsung mobile.
Enter into service mode of samsung mobile by following command *#27663368378# or *#0011#.
then choose debug screen then network lock then select parso sha256 off option. now once your mobile is rebooted it wan't ask unlock code. Howto network unlock samsung galaxy s7 edge
Oct 01, 2017 | Galaxy Cell Phones
Is it possible to use a unlocked at&t galaxy s5 active or a unlocked Sprint galaxy S6 on verizon?
Hi Axel
Unlocked phones are usually OPEN to use any SIM CARD! Regardless of what SIM you put, the phone is unlocked! SO you can buy a SIM from any carrier and insert into an unlocked phone and it will work.
Mar 11, 2016 | AT&T Cell Phones
I've locked myself out & need to unlock it. I have turned on TalkBack & I need to turn it off.
How to Bypass the Samsung Galaxy S4 Lock Screen ...
droidlessons.com/how-to-bypass-the-samsung-galaxy-s4-lock-screen-pas...
Feb 5, 2014 - Did you forget the pattern to unlock your Samsung Galaxy S4smartphone? ... you unlock and bypass the pattern lock screen security even if youhave ... After about 5 incorrectly drawn patterns it will lock you out and tell you to ....It's been more than a month already that I've been trying to find a solution for it.
How to Unlock Android Phone - JoyofAndroid.com
joyofandroid.com/how-to-unlock-android-phone/
Feb 13, 2014 - Do you feel foolish because you locked yourself out of your phone? Learn how to ... I've tried it and every # combination I could think of. Nothing ... I have a question- I accidentally locked my Samsung Galaxy S4. I know my pin ...
What to do if you forgot your Samsung Galaxy S6 lock screen
Dec 14, 2015 | Samsung GALAXY S4
How to unlock galaxy vhow to unlock galaxy v
Hello. You can unlock your Samsung Galaxy 5 safer and easier using unlock code. You can get the accurate unlock code for a Samsung Galaxy 5 from Unlock-Zone.com at affordable cost. Good luck.
..............UNLOCKING INSTRUCTIONS..............
1 - Switch ON your Samsung I5500 Galaxy 5 with a NOT ACCEPTED SIM Card.
2 - Compose : #7465625*638*CODE# (or *#7465625*638*CODE#).
SOURCE: MobileUnlockGuide.com
Oct 12, 2014 | Cell Phones
I need to unlock my samsung galaxy 5 I 550 3T mobile
Hi visit Wickedunlock.com to unlock your Samsung i5500 galaxy 5 from t-mobile network .Here they ask you the imei number of your mobile .Then at last they deliver you code to unlock your mobile.
Sep 18, 2012 | Cell Phones
Where do you enter the unlock code in the samsung phone
You can Enter the Unlock code in Samsung Galaxy S I9000 using the Unlocking instructions below: You can get the Unlocking instructions at here Wickedunlock.com/samsung-i9000-galaxy-s/rs11wp9/ at free of cost.
Samsung I9000 Galaxy S Unlocking InstructionsWarning : Do not enter any wrong unlock codes on your Samsung I9000 Galaxy S mobile phones. If you enter over a certain amount of wrong unlock codes on your Samsung I9000 Galaxy S mobile phone, your phone may get hard locked and sometimes become unusable.
Method 1:
1 - Switch ON your Samsung I9000 Galaxy S with a NOT ACCEPTED SIM Card.
2 - Samsung I9000 Galaxy S will ask for "Password".
3 - Enter the Unlock Code.
OR (if the Samsung I9000 Galaxy S shows "Insert Correct SIM Card")
Method 2:
2 - Don't bother about what's being displayed on your Samsung I9000 Galaxy S.
3 - Compose : #0111*CODE#.
NOT ACCEPTED: We mean, to use a sim card from a network other than the network your Samsung I9000 Galaxy S is locked to.
CODE: Its the unique Unlock Code for your Samsung I9000 Galaxy S.
If method 2 does not work, you can try method 2 again but this time without any SIM card on your Samsung I9000 Galaxy S.
Apr 09, 2012 | Samsung Galaxy S GTI9000 Smartphone
UNLOCK SAMSUNG
So you need to unlock it,To use any other GSM Network Sim card,You can get the Unlock code from the site Simpleunlocking.com and unlock SAMSUNG I5500 GALAXY 5
Dec 08, 2011 | Samsung I5500 Galaxy 5 Unlocked Android...
How to unlock your phone
Using codes you can unlock your mobile because its easy and safe for your mobile.......
Get the unlock code for your samsung I5500 galaxy 5 model mobile here Onlinegsmunlock.com , it gives the easy instructions for getting the unlock code for your mobile.......
Dec 01, 2011 | Samsung I5500 Galaxy 5 Unlocked Android...
How to unlock my samsung galaxy 5 i forgot my google email and password.. how can i reformat my phone???
The Samsung Galaxy S is one of the iPhone 4's biggest competitor in the UK. Most of the networks here carry the Galaxy S but like all subsidized mobile phones, chances are, the one that you got is locked to that specific network. So, how do you unlock the Samsung Galaxy S from Vodafone, O2, Orange, etc? Well, I've used this guide on a Galaxy S locked to T-Mobile USA so I don't really know if it will work for UK users but other users in other parts of the world reported it working on their Galaxy S locked to their carriers so there's no harm in trying (but then, I take no responsibility when you brick your phone so use at your own risk). This procedure will only work on a Samsung Galaxy S not running Android 2.2.
How to unlock
1) Go to Android Marketplace and search for Samsung Galaxy S Unlock Tool. Two apps showed up and I chose to download the one with five star rating (first one).
2) After downloading, I installed the app, went to applications then opened SGS Unlock.
3) Write down the generated unlock code and unfreeze code as well.
4) Shut down your phone, insert a simcard which your phone is not locked to. The phone will automatically ask for an unlock code. Enter the unlock code and press unlock.
5) Viola! You now have an unlocked Samsung Galaxy S.
google password
Go to the option of the forgot password it will be delivered to your mail ID provided by at the time of the account opening.
Jan 30, 2011 | Google Android
Cell Phones Logo
Top Galaxy Cell Phones Experts
Old-Guy-also
Level 1 Expert
Lawrence Oravetz
Are you a Galaxy Cell Phone Expert? Answer questions, earn points and help others
