Question about Pool & Spa
Smog bbq Smog spa Bq90r s/n 511 14 1791 0 Need a hot plate or this model
Need part number for BBQ option to replace griddle
You will need the model number & serial number which may be on the back of the cooker on behind the plate under the oven door, then contact the manufacturer or agent. Reece HVAC are also a very good source to obtain parts from.
May 07, 2014 | KitchenAid KDRP463LSS Dual Fuel (Electric...
Burner on bbq grill
For an accurate answer, you would need to provide your model number which can be found on the back of the grill on a small plate, tag or sticker.
Feb 12, 2014 | Cars & Trucks
Cant get face plate back on, for my Executive 56 Hot tub pump
these plates have notches that line up with the may be backwards or need spun a bit to"lock in"
Oct 26, 2013 | Waterway Pool & Spa
Having trouble cleaning the plates after we grill without wrecking the plates...any suggestions? Have tried hot, soapy water, goo gone bbq cleaner, mild scrubbers, and also spraying with PAM before we...
when it's hot lay wet paper towels on them.. no soap remove towels when they stop sizzle. Now just make them wet and sprinkle coarse salt on the grills and scrub with a short brissle wok brush.. the kind with the stiff bambo brissels... remember no soap to clean and no pam when you cook just oil and keep very very clean and it will never get dirty. you may have to keep grill on low untill ready to clean or reheat before cleaning.
Apr 08, 2010 | Coleman Roadtrip Grill LXE 9949-750
New BBQ chaged from propane to NG
Hello. The conversion of any gas appliance usually requires changing orifices, regulator and burner. Then once those changes are made you can adjust the gas flow. The difference in the orifices is this.
Natural gas orifices are larger than liquid propane orifices simply because the gas pressure for the natural gas is lower.
I would double check to be sure that you have installed the correct orifice. Also, you can adjust the amount of gas by turning the orifice in or out, using that socket.
Please call the uniflame technician directly if you still have a problem 800-762-1142 Joe
Mar 11, 2010 | Uniflame Corporation LP Gas Outdoor...
How and where can i locate the smog valves on my 2007 zzr600 canadian bike is a smog block off plate all that is needed?
Are you talking about the ones on top of the valve cover?? if so you don't need any of that the block off plates are. if won't cause any poor runnings.
C.C. Motorsports
Feb 24, 2010 | 2006 kawasaki ZZR 600
Pool & Spa Logo
27 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
