Question about Rinnai Heating & Cooling
My Rinnai FS35ETR heater turns off as soon as fan starts
3 Suggested Answers
  • 148 Answers
SOURCE: we have a Rinnai 2001 heater, pilot and gas are
could be the the bearings starting to dry up see if you can oil it
Posted on Jun 25, 2009
  • 1420 Answers
SOURCE: I have a rinnai energy
Ignition failure caused by either lack of gas, the electrodes are not the correct gap, restriction in the venting system or the spark is grounding prior to the electrodes. Check spark by holding spark wire close to cabinet (1/4"). Check gap across bull horns (electrodes) they should be no more than 3/16. Make sure all gas valves are on and all wires to gas valve are tight. After these checks, you will need a qualified technician to perform some tests on components.
Posted on Mar 07, 2010
Rinnai R85 starts to warm then stops and blinks 61??
I went to the Rinnai website and this is what I found for error code 61.
Error Code 61 Problem: Fan failure
Solution: Measure the resistance on the fan motor, check the damaged or loose wiring and connections. Make sure that the fan spins freely.
Sounds like either your fan is broken or something is keeping it from spinning freely.
Hope this helps.
Feb 24, 2015 | Rinnai R85ePLUS Tankless Water Heater
I need user manual for Rinnai Fan Heater 2000 RC - 219AC
How to operate Rinnai RC-219AC Fan Heater 2000
Jan 08, 2014 | Rinnai Heating & Cooling
My Rinnai 1001F has just developed a loud rattle when turned on. What's the most common problem and who fixes in Manchester NH?
There are two fans or blowers in your unit. The first to turn on prior to the flame starting. The second fan blows out hot air into the room. Depending upon when the rattle starts will dictate which fan is causing the rattle. Any good gas company should be able to help you out.
Jan 08, 2011 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
My Rinnai is set to 50 but when I run the water no hot water comes. Instead after about 10 seconds the 50 changes to a flashing 61. As soon as I turn the water flow off it reverts to 50.
This is a fault code telling you there is a problem. In this case 61 is a fault on the fan. It's not spinning at the speed expected for the electrical power it's drawing; the heater monitors this. Checks you can do are make sure the flue is not blocked. If Ok you need to get a serviceman to check the fan and heat exchanger for blockages.
Sep 22, 2010 | Rinnai Digital Remote Water Heater Control...
I have a rinnai heater and it stopped working all
rinnai, toyostove and monitor heaters are basically all the same. first you have to make sure your fuel valve is open at the tank. next you have to reset the tank lockout on the sump. then set your set point higher than your room temperature. now press on. the unit will go through a 300 second purge cycle. the pot heater should turn on when the purge cycle starts. after the purge cycle the fuel pump turns on and pumps fuel into the pot. when it vaporizes the igniter lights it. when a flame is detected the flame rod says ok to keep running so the fuel pump shifts into high speed. when plenum temperature reaches a preset level the fan turns on.
Oct 17, 2009 | Rinnai Toyostove Direct Vent Heater:...
Rinnai 431 wont start
You could have something as simple as a blocked flue pipe. Check outside and make sure the pipe is clear of ice or snow. Check the circulating fan and filter for lint. Be sure the lovers on the front of the stove are open and clean of lint.
Tom Hawkins
Apr 07, 2009 | Rinnai RHFE-431FAIII 16,700 BTU Direct...
Rinnai fan stops turning.
You can reach the fan wheel by using a can of compressed air normally used to clean your compute keyboard. Make sure you hold a vacuum wand close to the heater when doing this to collect the debris. Using a small coffee stir straw, lubricate the end of the fan motor shaft with light motor oil. This will keep the motor alive for a bit longer.
Aug 13, 2007 | Rinnai Unvented Gas Zone Heater. 99% fuel...
Heating & Cooling Logo
Top Rinnai Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
vance jones
Are you a Rinnai Heating and Cooling Expert? Answer questions, earn points and help others
