Question about Miscellaneous
Can anybody tell me a little bit of this wood sculptures.?
    Master:
  • 923 Answers
Sure! They are old, fragile, and intricate. That's three things right there!
Posted on Apr 20, 2017
Can anyone tell me the name of this sculptures
Those are tourist knickknack sculptures from Indonesia, and do not have a specific name. They are manufactured in quantity by the locals for sale to tourists.
Apr 15, 2017 | Crafts & Hobbies
I am trying to drill through old encyclopedias, but the drill bits keep snapping in the pages. What type of drill bit can I put on an hand-held drill that will get through the books without breaking?
rx-dk-diy054036_wood-drill-bits_s4x3_lg.jpgI've used 'regular' high speed drill bits for paper, and wood boring bits. I think the wood bits work better, but whatever bit is used the drill flutes have to be cleared out of material. This is done by drilling a little bit at a time and then lifting the drill out of the hole to clear the hole and the drill of shavings. This is essential to do to minimize heat buildup and binding of the drill bit. The drill bit should not break if you take it nice and easy, and drill in small increments .
Dec 17, 2013 | Hinge European Drilling Tool 35mm Cup ...
Drill overheat
Soap might work. Some use candle wax, bees wax, WD 40. I've prayed silicone on the drill bit. Using moderate pressure and low speed definitely helps, and it is essential to clear out the hole of chips frequently. So drilling in increments works. You drill a little, lift the bit up out of the hole to clear the chips. Also the type of bit used is a factor in drilling efficiency: wood boring bits are a good choice. Forstner bits are excellent, and spade bits are just OK. Hope this helps....
Oct 15, 2013 | Drills
I have a Parkside precision pendulum-action jigsaw, model number PPHSS 730. It has three blades... two for wood, one for metal.... but how can I tell which is for metal?
Tom,
The one for metal will almost certainly have the smallest teeth. Sometimes the metal one will a wavy tooth set - that is, if you viewed the blade from the front, there is a sine-wave shape to the tooth set pattern. (Tooth set means the tips of the teeth are bent a little bit to the left or right to make the cut just a little wider than the rest of the blade so that it doesn't get stuck in the cut.)
Good luck.
Feb 10, 2013 | Makita Jigsaw Blade
I can't seem to get the attachment out of my dremel model 380-5. i do not want to damage the tool trying to get it out.
If you have loosened the collet, just tap the bit end on some hard wood which drives the bit inward a little and releases it. Tighten the new bit in the regular way. Hope this helps!
Nov 14, 2010 | Garden
I am using this product for a hardwood floor. I cannot seem to get the staples driven in far enough. I'm using 2" 15 gauge staples and have oiled and set the regulator correctly
the wood may be to hard for the gun to drive the stapel right in or you may just have a worn out gun,,turn the regulater up some more to increase the guns power a little more it should hit the stapels a bit harder then,,,some wood is harder than others,,dont just go by what the book sayes! if it works,,,use your setting not what the book sayes, only back it off a bit if it berrys the stapel a foot beep in the wood!!!
Jul 31, 2010 | Campbell Hausfeld CHN50399 2in1 Flooring...
I just purchased a teaberry stalker 1x and
Sorry I am so far away but sound like the clarifier is open, that is it works on transmit. As you talk to your friends try to move the clarifier a bit at a time to see if it will track with them.
Jan 31, 2010 | Uniden Bearcat Pro PC68XL 40-Channels Base...
Body sculpture BT2710 instructions
hi if you email body sculpture on sales@hi-markgroup.co.uk they will send you a free manual by pdf they are brilliant i know because i have used them for the same reason myself last week
Jules
Apr 08, 2009 | Exercise & Fitness
Miscellaneous Logo
21 people viewed this question
Top Miscellaneous Experts
Brett
Level 1 Expert
Valmae Patterson
Level 1 Expert
cwcollectr
Level 1 Expert
Are you a Miscellaneous Expert? Answer questions, earn points and help others
