Question about Briggs Garden
Can I use 2 Stoke oil in the crank case for my Briggs and Stratton 6hp shredder.
    Habit-Forming:
  • 100 Answers
2 stroke oil is better than no oil, but I'd advise you to get some 4 stroke oil as soon as you can,,, the viscosity of 2 stroke oil is very different and it contains other minerals.
Posted on Apr 17, 2017
6hp B/S on pressure washer will not fire
check the oil some have a low oil sensor to stop the motor, some have more than one shut off swtich
Aug 19, 2012 | Yard Machines 155 Torque Briggs Stratton...
My briggs & Stratton won't start. Changed spark plug.
check for spark is there a low oil shut off and the oil level is a little low ?
Jul 01, 2012 | Troy-Bilt Chipper Shredder
Ariens 1640 Zoom Riding Mower with Briggs & Stratton engine smoking
check to see if the oil smells like gas the needle valves go bad in the carb and gas over flows into the crank case also the head gaskets go bad and **** the oil from the crank case
May 08, 2012 | Ariens Garden
I have a craftsman 6hp quantum xte pressure washer and while it is running there is oil spraying out of motor.
This depends heavily on where the oil is coming out of the engine. A very common issue is to have at some point tipped the machine over. This causes the fuel to run through the carb and down into the crank case. When this happens you will end up with the crank case being over filled with the oil / fuel mixture and will see things like what you are describing.
Check your oil and see if it smells like gas. If it does drain the oil and replace it with 30WT motor oil. You will likely need to replace the air filter and spark plug as well as it is common for the filter to become oil soaked and the plug to be fouled when this occurs. If you have any questions please feel free to contact me using the information below.
Sincerely,Aron KerrLanda Northwest, Inc.www.landanw.comaron.kerr@landanw.com800.247.8103
Apr 13, 2012 | Briggs & Stratton Garden
How much oil to put in a model no. 32113, 5hp 4 stoke
You engine oil capacity is 20 oz.
Hope this helps.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/matt_8dbc24bf722649ac
Nov 18, 2010 | Parks Optical 13.5hp Briggs And Stratton...
Simplicity Sno Away Snow Thrower Briggs 6hp engine No Spark
Check engine oil.
Remove wire from low oil sensor and the start.
Replace low oil sensor.
Hope this tip help solve your problem.
r/David
Dec 28, 2009 | Briggs & Stratton Ignition Kit 2-8 HP...
Misplaced operation manual for Troy-Bilt Briggs & Stratton Super Tomahawk Chipper/Shredder 8 HP Can it be downloaded? What kind of oil does the chipper use?
Straight 30w NOT 10w-30
prefer air-cooled engine oil from mower dealers or some auto supply stores have air cooled engine oil.
I’m happy to assist further over the phone at https://www.6ya.com/expert/rolandw_c013176d62ee17ae
Oct 07, 2009 | Troy-Bilt® Briggs and Stratton Chipper
My Yard Machine W/a 6hp B&Sengine will crank & run on starting fl
Most likely you still have a jet inside carburetor that is clogged how did you clean it soak it in carburetor cleaner? Did you take out jets to make sure they are clean
May 05, 2009 | Briggs & Stratton 66set Panzer Tractor...
Garden Logo
Top Briggs Garden Experts
Mike
Renee Knafel-Bullock
Are you a Briggs Garden Expert? Answer questions, earn points and help others
