It has been suspended since 03/12/17 (It was not my fault). Every time I ask to open my learnet web, you give me temporary password just for 12 hours. I have courses should be completed in tow weeks, and I should have a permanent password. can I get a permanent password?
SOURCE: forgotten password
Click the "Forget your ID or password" link at the lower right of your screen, it will help you retrieve your password for sure. And you can have your email address back...as long as you have the information needed to verify your account, one of it is the the answer to your secret question...good luck!
SOURCE: I can't open my ebook library
Here are the instructions by solving this problem:
1. Right Click My Computer
2. Click Properties
3. Click System Protection
4. Click Advanced
5. Under Performances Click Sittings
6. Click Data Execution Prevention(DEP)
7. Click Turn on DEP for all Programs and Services except those I select
8. Click add
9. Under File name: type in ebooklibrary.exe click open.
Make sure that while doing this process your Portable device is connected to the computer. otherwise you will get a message telling you that ebooklibrary.exe file not found. it took me a while to figure this out. I hope that this will help.
SOURCE: Ford Focus Engine System Fault warning light
yes there is a know problem with the fuel system. fuel pump breaks down, empty your fuel filter into a bowl and check for metalic, if you have this in the filter your pump is F..... along with all the other common rail stuff. expensive job... error codes though, i find that hard to believe, fuel pressure faults will occur, i think you garage does not know what to do. or does not want to tell you the cost of the job and he will be in doubt himself of wether he is right..... was you engine coil light flashing at any point.!!!
SOURCE: Email id not work
hello , unfortunately ur account has been blocked by urself.. generally due to security reasons yahoo will block the accounts who retreive their password wrongly... like u have to answer the security questin...dont panic ... write a mail to yahoo regarding your problem..mentioning ecah and every details that u gave at the time of yahoo account setup ... definiely u will get back ur yahoo account..
SOURCE: samsung pixon m8800 fault
my inbox messages get full, i have saved some into my folders but even with an 8G memory card i still have to delete messages. What do I do to get stuff onto the memory card??
Type PHIC[space]PIN[space]LName, FName[space]BDAY[mmddyyyy] and send to 2960 e.g. PHIC PIN DELA CRUZ,JUAN 08191975
For those who have extension name (Jr., Sr., III, etc.), type
PHIC PIN DELA CRUZ,JUAN JR 08191975
The textline also offers services like PhilHealth benefits, qualified dependents, claims status check, ID card replacement, employer PhilHealth no ., PhilHealth address and contact info.
Hope this helps.
