Connecting VCR/DVD combo
Hi, I can't see a line and audio in on the back of the TV. How do I connect my DVD/VCR combo unit to it? Hi. I have a TV that I do not use as a tv... no cable, no antenna. I just want to be able to hook up my Insignia dvd/vcr and use it to watch movies, but I'm having trouble connecting it all. My tv has the following connections: S-video, R,L video; video in.  My dvd/vcr has a bewildering array of connections: vcr line in (audio L, R, video); dvd/vcr out (audio R, L, video); component/ progressive scan video out Pr Pb Y; Audio out R L; coaxial (the last two are labeled DVD exclusive out). Can I hook it up so that I can just watch dvds or videos without having to switch the cables? Do I need to change anything if I want to record a video to DVD?
  • clarbone59 Feb 20, 2008
    CANT GET DVD TO PLAY
    Genius:
  • 1,694 Answers
Confusing! TV with NO yellow,red white input ? Buy an RF
adapter Radio Shack about 30.00.....TV has input ? = yellow
video,audio R,L from Insignia source dvd/vcr out ( audio R,L,
video {yellow} ) You don't need to switch cables.As to record
feature,consult owners manual..................................T
Posted on Nov 21, 2007
SOURCE:
Sanyo TV connect to cable box connect DVD player
If your DVD/VCR combo player has three RCA connectors (yellow, red, and white), you can connect them to the corresponding inputs on the front of your TV.
Dec 29, 2012 | Sanyo Televison & Video
Using your DVD-V4600, how do you play a vhs tape on TV? Need step by step instructions.
In order to watch either DVD or VHS on your TV ,you need to make the following connections ..
  • You need to connect "DVD Player / VCR Combo" to" TV " as (Audio/video output of DVD Player / VCR Combo -TO- Audio/Video input of TV) ..
  • use either "RCA analog (red/white +yellow ) " or "SCART "or "Optic " cable.(any standard optical cable )...if exist ,optic is the best way to connect it..Remember your DVD Player / VCR Combo 's "OUT" goes into" IN "of the TV ..
  • pls also remember,wherever you connect your DVD Player / VCR Combo on your TV ,you should switch the source selector accordingly to correspond to the connection on the back...
Hope this helps!..if more help requires pls let me know.
Take care and please
Remember to rate/vote and give me 4 Thumbs Up for me to continue f
or Helping out the Community :)
Jun 30, 2011 | Samsung DVD-V4600 DVD Player/VCR
Vcr has no sound when tape is in but the dvd player has sound
Just a hunch, but on the back of combo players there's often a couple of options for audio output.
Have another look on the back of the unit, whilst its powered off, and see if the red and white plugs are connected to DVD audio out. If they are, look for another set that says combo out, line out, DVD VCR or something along those lines and re connect the red and white plugs.
Apr 04, 2011 | Sanyo DVW-7200 DVD/VCR
Dear Technician, I have 4 components that I am trying to connect together, a Panasonic HDTV model #TC-L32X1, a GO Video DVD/VCR model #DV2130, a Yamaha stereo receiver model#RX-690, and a Scientific...
Hi and welcome to FixYa,
Unfortunately, size limitation of what could be attached prevents posting a connection diagram. Still, proposed connection scheme:
  • 4250HDC's HDMI to Panasonic's HDMI 1 or 2;
  • 4250HDC's VIDEO OUT to GoVideo's LINE IN 1 VIDEO;
  • 4250HDC's AUDIO OUT to 2 pcs of RCA Splitters (shown below);
  • 1 pair from the 2 splitters to GoVideo's LINE IN 1 R-AUDIO-L;
  • the other pair to Yamaha's LD/TV L & R;
  • GoVideo's LINE OUT VIDEO to Panasonic's VIDEO IN 1 VIDEO;
  • GoVideo's LINE OUT R-AUDIO-L to 2 more RCA Splitters;
  • 1 pair from the 2 splitters to Panasonic's VIDEO IN 1 L-AUDIO-R;
  • the other pair to Yamaha's VCR 1 IN L & R;
  • to watch cable TV in HD quality, set Panasonic to HDMI 1 or 2 by pressing Panasonic remote's INPUT button, then 3 (or 4), then OK;
  • to hear cable TV programs on Yamaha's speakers, set Yamaha to LD/TV;
  • to watch DVD or VHS, set Panasonic to Video 1 by pressing Panasonic remote's INPUT button, then 6, then OK;
  • to hear DVD or VHS on Yamaha's speakers, set Yamaha to VCR 1;
  • to record cable TV programs, press GoVideo remote's TV VIEW button a couple of times to cycle through the signal sources or until Line 1 is displayed.
The use of the splitter shown below would effectively double the AUDIO OUT of the cable box and the DVD/VCR combo to feed both the TV and the stereo. Additionally, this would allow use of the cable box and/or the DVD/VCR combo with or without the Yamaha.
dd46b75.jpg or
27340be.jpg or
Good luck and thank you for asking FixYa.
Apr 27, 2010 | GoVideo Go Video DVD/VCR Combo
Samsung 2333HD to dvd/vcr combo
On a DVD/VCR combo unit....the Component Output (RED, GREEN, BLUE) is exclusive to the DVD player section only (VCR can only output analogue source) and will only be able to view DVD.
To watch VCR, you will need to connect to your TV via Composite (YELLOW) cable, into the Yellow AV input on your TV. You can then tune the VCR section to match your TV's RF input (if you prefer this connection).
Good luck...
"if this has helped you, please rate this solution"
Dec 04, 2009 | Samsung SyncMaster 2333HD 23 in. LCD TV
Can't connect Samsung VCR DVD combo
this will only workif the vcr has a up convert feature whit out up convert it will not work you will have to connect vcr whit yellow red and white cables then dvd and vcr will give u the picture, if u connect dvd with commponent cables if u tv has this input picture from dvd will be better
Jan 26, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Connect to auxillary dvd player
to connect a DVD player to your TV/VCR combo is :
DVD A/V output to TV/VCR Combo A/V INPUT In the back of TV , if TV doesnt have an auxilliary A/V input , then
the other solution is to get a RF Converter box that connects to where you connect the CABLE service .
thats it . hope this helps , please rate this solution , thanks AJ
Apr 30, 2008 | Toshiba MV13M3 / MV13M3W 13 in. TV/VCR...
Connecting dvd/vcr combo with tv and digital cable box.
You trying to put the DVD/VCR combo between the cable box and the TV? OK, cable out goes to vcr in, vcr out goes to tv, I think you got that. Now there should be a tv/vcr button on the vcr/dvd, you need to press that when the unit is on. Also, make sure you are on the correct input on both the vcr and the tv, usually video 1 or AUX and choose line in or L1 on the vcr/dvd. If the tv/vcr button is toggled, itll completely bypass the vcr/dvd player.
Mar 03, 2008 | Toshiba 32A41 32" TV
Hooking up a DVD player to a Quasar TV/VCR Combo
Yes, for a workaround. The adapter would be 2 RCA female to 1 RCA male. You have to connect both the red and white to the female RCAs and use the male to connect to the TV's Audio INput. The yellow goes to the video. There should be no negative technical effect other than lost of stereo quality. The audio output of the DVD is line level and could normally tolerate this condition.
The correct method is to use a simple line level audio mixer and mix the L& R audio signal to produce a mono signal or to use a stereo amplifier for the sound output.
Hope this be of some help/idea. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
Nov 07, 2007 | Quasar VV-1302 13 in. TV/VCR Combo
If you are able to you can connect to the RF connector (F Type Conncetor) on the TV. This should work. The layout is from the VCR (RF to TV) to the TV antenna F type connector from your Cable box to the Antenna in of the VCR that way you have cable through the VCR, and access to you VCR and DVD all controlled by the Cable and VCR remotes (set TV to Channel 3, set VCR to Channel 3) and use the Cable box as the tuner, Use the TV remote to switch between Cable and VCR inputs then use the VCR remote to switch between the VCR and DVD input.
Sep 20, 2007 | GE 25GT516 TV
Televison & Video Logo
225 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
