Question about Philips Televison & Video
I need a code for my maxell sound bar for a Philips universal remote
5 Suggested Answers
SOURCE: philips universal remote 4 digit codes
For combination tv/vcr the codes on the Phillips remote are 0039, 0739. I can only enter the channel I want to watch I can not use the up and down arrows for some reason.
sb2141
Posted on Feb 15, 2008
IrishDruid
  • 2712 Answers
SOURCE: universal remote codes for a philips remote
You can find the remote control codes for different brands of devices from
http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
If none of the codes work then we have two other solutions:
1. Searching For Your Code
If you have tried all of the set-up codes for your brand of equipment ,or your brand is not listed, and you are still not able to get the unit to respond, try the following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when you reach the end of all the codes for this device type.
  1. PRESS the button for the device you want to program, (TV, VCR, CABLE, etc.), then RELEASE.
  2. PRESS and HOLD the SETUP button until the red LED flashes twice, then RELEASE.
  3. ENTER 9-9-1 (two blinks on the remote)
  4. ALTERNATE slowly between the POWER key and the DEVICE (TV, VCR, CABLE, etc.) button until your device turns off. (On VCR, LD, and CD players use PLAY instead of POWER)
    Make sure that the remote is pointed at your device during the search, You may have to press this sequences of buttons up to 100 times to search the entire library of codes.
  5. When your device turns OFF, PRESS the SETUP button and RELEASE it to lock in the code for your device.
2. Learn the buttons from the original
Line up your original remote and the head-to-head before completing the following steps.
  1. PRESS and HOLD the SETUP button until the red LED flashes twice.
  2. PRESS 9 - 7 - 5, the red LED will flash twice.
  3. PRESS the DEVICE key where you wish to learn the function. The next 3 steps must be completed within 10 seconds.
  4. PRESS the button that will receive the learned function, the LED will flash rapidly.
  5. PRESS the button on the original remote to be learned.
Now you can repeat steps 3 through 5 to learn other functions onto other keys or press and hold SETUP until the Cinema's red light flashes twice to lock in your new feature. (If the red light does not blink twice, stop and repeat steps through 6).
To test the new feature, press and release the device key in which the new feature was learned followed by the key on which the feature was learned
More help for programming your remote can be found here:
http://www.hifi-remote.com/manuals/ofa-l.shtml?URC-7800#device
Hope that helps!
If your issue is not resolved, please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further as best I can. I am here at your service.
P.S. -You can rate this solution with one of four votes, if you feel your issue is resolved (remember that at times a bit of to and fro dialogue may be necessary to resolve an issue).
  • "FixYa!" - The solution provides great advice on how to solve the problem.
  • "Helpful" - The solution provides useful leads that helps solve the problem.
  • "Thanks for Trying" - The solution does not solve the problem but the effort is appreciated.
  • "Inappropriate" - The solution has absolutely nothing to do with the problem.
Thank you for using FIXYA!
IrishDruid
Posted on May 07, 2008
VOTIT
  • 2071 Answers
SOURCE: philips universal remote codes for zenith t.v.
If you have tried all of the set-up codes for your brand of equipment ,or yourbrand is not listed, and you are still not able to get the unit to respond, trythe following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when youreach the end of all the codes for this device type.
Line up your original remote and the head-to-head before completing thefollowing steps.
Now you can repeat steps 3 through 5 to learn other functions onto other keysor press and hold SETUP until the Cinema's red light flashes twice to lock inyour new feature. (If the red light does not blink twice, stop and repeat stepsthrough 6).
To test the new feature, press and release the device key in which the newfeature was learned followed by the key on which the feature was learned
Hope that helps! Should you have any further questions,please feel free to post them here.
Television Video - DVD Audio Satellite Set Top Box Video - VCR Brand: Model (optional): clip_image001.gifclip_image001.gifWe could not find an exact match, we think this code will work. 10054 clip_image001.gifclip_image001.gifSetup Instructions
· Set the "Mode Switch" to TV.
· Press and hold the "Mute" button and the "Select" button until the visible LED blinks twice.
· Enter the 5 digit Code above.
· Try your new code and tell us how it worked!
You'll have to settle for that, use the middle power key in the tv device to power on & off the tv.
hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE;
Posted on Sep 01, 2008
MNfisherman
  • 11896 Answers
SOURCE: need universal code for philips sru3004 universal remote
here are some sites with your code.
www.remote-codes.com
www.tvcodes.com
www.universal-remote.net/philipsmagnavox.html
Posted on Apr 15, 2009
What is the code for programming universal remote for philips 19 in tv model 19PFL3504D/F7
How To Program A Philips Universal Remote ' Codes For ...
codesforuniversalremotes.com/program-philips-universal-remote/
Here is how to Program any Philips Universal Remote Control. Turn on the device you ... Remote Control Codes December 21, 2015 at 1:19 pm. Stephanie,
Codes For Universal Remotes ' Universal Remote Control ...
Universal Remote Control Codes For TV & Audio. ... Codes for Philips Universal Remotes · Sanyo TV Codes for Universal Remotes · Codes for .... I have an 19 inch Emerson flat screen and a RCA universal remote. Please help with the code ..
Dec 28, 2015 | Philips Televison & Video
I need code for philip s remote for a sayno ty
Philips rca universal remote codes sayno vcr dvd combo ...
www.fixya.com > ... > Remote Controls
Universal Philips Magnavox remote for a Sanyodvd vcr combo ? I have a cableremote and need to program my Magnavox vcr/dvd combo into it i have 2 dvds ...
How to Reprogram a Philips Universal Remote Controller ...
science.opposingviews.com > Computers
Dec 21, 2015 | Philips Televison & Video
Phillips srp5107/wm17
0027,0021,0022 are the codes to check with. For more information http://electrohelponline.blogspot.com/
Nov 20, 2013 | Philips SRP5107/27 UNIVERSAL REMOTE 7 IN...
Program directv remote to Maxell soundbar
Hi, you will need to access the operating manual for your directv remote. It will have codes in the remote. but most likely it will not work your soundbar as most Directv remotes do not have codes for them, and do not support them. You are stuck using the soundbar remote for your soundbar. The only option you can do is to purchase a learning remote from the store that can program to your directv box and your TV, and you can learn the volume keys to your Maxell sound bar.
Oct 13, 2013 | Maxell 193002 ssb1 soundbar
I need the cox remote code for philips sound bar css 2123/f7
I too need this code, if such a code exists. I have found several that control the mute and volume, but none so far control power.
Jul 19, 2012 | Televison & Video
I need a code for my universal remote from Philips. My TV is JVC. That's the code that i need. Please help me......
I need a code for my universal remote from Philips. My TV is APEX. That's the code that i need. Please help me......
Nov 30, 2009 | Philips Universal PH301S Remote Control
Remote Codes
Hi which universal remote do you own? You normally can find the codes on their helpdesk site. For philips:
http://www.urc.philips.com/
Jun 16, 2009 | Philips MX6050D System
Can you help me program my remote?
hi i have a philips universal a rca tv and a dvd named lennox sound 2003 i want to program the dvd with the remote please help no codes lost
Feb 09, 2009 | Philips Universal PH301S Remote Control
I lost my remote codes for my philips US2-PM435S
Lost my remote codes for my philips remote. I need the combo codes for a tv, vcr,and dvd.
Apr 20, 2008 | Philips Magnavox Learning Universal Remote
Televison & Video Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
