Question about LG Dryers
I have an ancient LG dlg5988w gas dryer. tE1 code after I changed the thermistor. PCB board I cannot find one available. Anything else I can do?
  • LG Master
  • 2,355 Answers
Check all thermistors for continuity. Check hi limit switch for continuity.
Posted on Apr 19, 2017
SOURCE: My LG gas dryer DLG5988W
i need screen filter dryer for dlg5988w
Posted on Mar 02, 2008
Illeagle
  • 525 Answers
SOURCE: LG DLE5977 Electric Dryer
Below are some solutions that other customers have cited. The control board seems to have a glitch in it, so I would take it back and get a replacement. New product is covered by a factory warranty or a dealer replacement guarantee. My husband and I just BARELY bought an LG Electric Dryer. I'ts model #DLE2516W. As soon as you hit the power button, "check filter" comes on. The right after that, the error code "Te1" flashes and it does nothing but beep. Clearly, the filter has NOTHING in it because I've never run a load of clothes thru it. When I look in the troubleshooting section of the owners manual, it tells me that this means that the thermistor is open and needs to be replaced. But I'm confused as to why a BRAND NEW dryer already needs a part replaced. Can ANYONE please help me. I have lots of laundry to do. Haha!
Comment by Amanda02, posted on Sep 11, 2007 Well... we took it back to Home Depot and they are replacing it. i was trying to fix it because it takes 3 weeks to get a new one. They don't have any in stock!! And it takes 3 darn weeks to get a new one.
Posted on Jun 11, 2008
  • 3 Answers
SOURCE: lg dlg2522w gas dryer with fault code 'tel' or 'te1'. Whatis it?
you cant do nothing sorry it will get damaged
Posted on Feb 16, 2009
SOURCE: I have a LG LDF6810ST dishwasher with a tE error
Follow up to previous post.I replaced my sum seal and other nec. gaskets and reassembled.The TE code is gone and dishwasher performs as designed.I hope this helps someone with one of these POS dishwashers.Thanks
Posted on May 29, 2009
TheMobilian
  • 8220 Answers
SOURCE: lg dryer tromm dlg5988w flashes filter code will
Check your filter, your vent and clean them well. Shut down the power and let it reset itself.
Posted on Jun 09, 2009
Where can i get parts for an LG gas dryer number DLG5988W
http://www.repairclinic.com/Shop-For-Parts/a8b200d684294/Model-DLG5988W-LG-Dryer-Parts
Sep 08, 2014 | LG DLG5988 Gas Dryer
TE1 error...thermistor seems fine
that's a bad thermistor,the thermistor isn't alot of money it's like 15 dollars,change it out,remove the code anf go from there but it should fix it,also check the wire connections.the tech sheet will tell you how to get it into diagnostics to remove the code
Nov 24, 2013 | LG DLE5977 Electric Dryer
HELLO MY DRYER LG MOD DLG5988S GIVE ME A CODE TE1 AND IT DONT START ONLY MAKE A BIP SOUND. SOME BODY CAN HELP ME??
The "tE1" error has to do with the dryer's thermistor. The code indicates the thermistor is open, meaning that it has cracked or broken off, possible the wires are off. if the wires are good then you will need to replace the thermistor. The Thermistor is located next to the blower section of the dryer should have a bule and orange wire and it is on the blower housing. here is a picture and if you need to order it:
http://www.repairclinic.com/LG-Dryer-Sensor-Or-Thermistor-Parts
Mar 19, 2011 | LG DLG5988 Gas Dryer
I have a LG dlg5988w drying that just started making a banging sound. Are there rollers that need replaced?
yes the belt has a tensioner with a bearing and a roller surrounding the bearing
the bearing can be locked up which will put flat spots in the roller m,aking the banging noise
Sound horrifying at times doesn't it?
Mar 07, 2010 | LG DLG5988 Gas Dryer
My LG Dryer DLG5988W wont always heat up. The
Dryer ignitors are not as tempermental as oven ignitors. If it glows, the problem is most likely is not the ignitor. One of the coils on the gas valve is the problem, but with LG, you have to get the entire gas valve, as the coils are not available as seperate parts. By the way, if you are testing the dryer with the front off, you have to make sure to cover the drum opening with something (like a piece of cardboard) so that you will maintain proper air flow for the burner.
Jan 25, 2010 | Dryers
Jun 11, 2008 | LG DLE5977 Electric Dryer
somethin might stuck down insinde the channel where the llint filter goes, small sock baby tee or somethin to that effect, it rests against fan and prevents motor from turning, usually lookin down with a flashlight will confirm this
Mar 02, 2008 | Dryers
Dryers Logo
47 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
