Question about Cell Phones
OI can't open my phone. There are too too may apps, I can't get it open to get phone back to factory app, I need to delete everything on phone. Maybe the games,
    Scholar:
  • 172 Answers
If you have an android phone follow these steps.
Turn phone off
While device is off. Press and hold the Volume down button and the power button at the same time, You will feel the device vibrate when it does release the power button.
You should then see the Android icon lying on its back with an exclamation mark above him. When you see that press the Volume down button once.
Then go down to factory restore. You will do that us ing the Volume down key. Then you select factory reset by pressing the power button.
Good Luck
Ellen
Posted on Apr 18, 2017
How to hard reset cherry mobile superion radar c
Hi Juramil,
Try this:
1. Open your device's Settings. The Settings app can have varying icons depending upon on your specific device, and may be also be found within the App Tray or by pushing the phone's dedicated menu button.
2. Find your Factory Reset option. Depending on your device, the "Factory data reset" feature may be located in one of two sections within the Settings app:
Select the "Privacy" settings, and scroll down to "Factory reset"
Select the "Backup and reset" settings, and scroll down to "Factory reset"
3. Tap "Reset device" to delete all data and restore your device's factory settings. The accounts that you are signed into will be displayed on the screen. By default, all of your phone's internal storage will be wiped.
If you want to erase all of the data on your phone's SD card as well, check the box at the bottom of the screen.
4. Confirm the process by selecting "Erase everything". This will delete all data and restore back to your device's factory settings. Your phone will be as if it just came out of the box.
Jun 02, 2017 | Cell Phones
Hey I have a x gody x11 phone and every time I get on my apps it will exit me. what the problem I need help?
Hey..
Your phone is broken or the apps are broken.
First, delete the app, reboot the phone and download the app again.
Hey, still does it.
Factory Reset the phone which scrubs everything off and reloads the operating system.
Then reload all the apps from backup.
Dec 25, 2016 | Cell Phones
What happens if I cant delete the app and how do I reset will it delete my saved apps
A reset will not delete apps nor data. A full reset to factory settings will delete everything on the phone. So make a backup from time to time, because you sometimes need to reset a phone complete.
Jan 13, 2015 | Nokia Lumia 710
Can't get message on straight talk phone
Check your setting under APN and see if the MMS APN is enabled. If its not then enable it and try again. Other than this, you can back everything up and set your phone back to factory settings. Sometimes Apps cause conflicts with factory settings and unless you delete each app one by one its hard to figure out in an quick manner. You might want to try to delete the most recent app you added when this started to happen before restoring the entire phone!
Jul 15, 2014 | LG Optimus Black Smartphone
What is master reset all about? can i have an explanation?
To make it simple, A master reset restores your phone to default factory settings wiping off data from it...
Jul 14, 2014 | Samsung GTC3300 Cell Phone
Lg optimus logic low system memory
Only some apps can be moved to the card. Here's how to check and move the ones that can along with some other tips for freeing up space in internal storage:
1.Go to the Home screen. Press Menu and tap Settings , then Applications, then All
2. Tap each app and tap "Clear Cache". Tap "Move to SD Card" if it's not grayed out.
3. If there are any apps that you've downloaded and don't use uninstall them. The phone won't let you uninstall system apps that are essential to the phone's operation. If you aren't sure if you need an app or not install ES File Manager (which can be moved to the card) and use it to back up the app to the memory card before deleting.
4. Open Messaging, if you have any picture messages, tap on the bubble containing the picture. Tap Save attachment. After the picture has been saved, tap on the bubble again and tap Delete message. Also delete any text messages you don't need.
5. If you use Gmail, open Gmail, tap Menu, then tap Go to labels, then Trash and delete everything in Trash. If you use a different email app delete everything in its trash folder.
6. Launch the Camera, press the Menu button, tap settings and make sure that "Storage Location" is set to "SD Card".
Feb 01, 2014 | Straight Talk LG Optimus Logic Cell Phone
Very Slow....Light Black Screen when opeing
If it has not corrected itself by turning the phone off and taking the battery out for a couple of minutes then turning it back on you should try a factory data reset. In Idle mode, open the application list and select
Settings - Privacy - Factory data reset - Reset phone
-Erase everything.
May 23, 2012 | Samsung S6102 Galaxy Y Duos - Black...
I install an app. from the micro SD card but this application didn't work properly and my phone restarted after hanging for about 10 seconds then i went back to the applications to delete this non-working...
Almost all cell phones have an option to reset to factory defaults.
You will loose ALL DATA!!
It is different for each phone but generally it is found under Settings -> Security -> Reset To Factory Settings
It may be called something different
Mar 06, 2011 | Cell Phones
My lg ally phone wont send text messages, when i press the send button the is a little message at the top of my phone that says "message not sent".... what do i do i need to tellmy friend an...
your phone is an android phone correct? you can download google voice and set it to handle your txting other apps will do the same or close to it many dont even use your txts up at the end of the month by sending over the internet. if you cant find something well then first try going into messaging app and press your options button next to the home key under your display and select delete threads yes you will loose all your txt history but you can find an app to back them up to your sd card. also try going into the settings under applications manage apps and maybe delete some of your larger apps to free up space, android needs a minimum of 25 mb to run properly. you can under the same list delete the cash of many apps to free up (less) space. if all else fails go back into settings found in the app drawer and do a factory reset under the privacy settings this will mean your phone will be the same way as the day you got it but dont stress after you log into gmail your phone will start to sync your phone book and now a even your apps if you tell it to in the app store after login. your phone should txt just fine after goodluck
Mar 05, 2011 | LG Ally Cell Phone
How can i delete applications on my i9+++ sciphone?
Hello my friend,
check these sites are having instructions how to install and unistall programs.etc.. and some games to download
http://i68resources.blogspot.com/search/label/games
http://ezinearticles.com/?How-to-Install-and-Download-Games-on-the-Sciphone-I68&id=1974736
http://newsciphone.com/DRIVERS.html
Sep 11, 2009 | Dual Electronics CECT P168 Cellular Phone
Cell Phones Logo
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
