Question about Vizio Televison & Video
My 55" Vizio vf552xvt keeps shutting off - Vizio Televison & Video
4 Suggested Answers
  • 608 Answers
SOURCE: My 55" vizio randomly shuts
I had a similar problem with my 42 in Philips LCD HDTV.
Here was the problem. My Power Supply Board had several bad capacitors. I opened my TV (warranty was expired of course) and found four bulged capacitors on the PSB. Many major electronics companies Philips/Magnavox, Sony, Panasonic, and others were sold capacitors that failed in 2-5 years instead of 10-20. The capacitors fail prematurely due to a lack of preservatives. Unfortunately, they were installed in all sorts of devices and cause a wide range of failure problems.
Here are some options for you.
1. Have it fixed by a professional $$$$$$$??????? (Is it under warranty?)
Remember, TVs CONTAIN HIGH VOLTAGE AND CAN KILL YOU! Do this at your own risk.
2. Open your TV and find PSB. (The board that the power cord plugs into) Check for faulty caps. If you find some (bulged or leaking) bad caps replace the entire board. The entire board costs around $250 right now because they are in high demand right now. They can be found online. I would definitely shop around though.
3. Remove and then replace individual faulty caps. This takes some soldering skill.
Caps are inexpensive and if you can take care of it yourself it will save you hundreds.
This may be your problem. If you determine that it might be.
I have a Tip/How TO tutorial on this site that may also help. It gives step by step instructions for replacing caps on PSB #715t2432-2. If this is your board you are in luck. Here is the Link: Fixing the Philips Turns/shuts off on its own problem. I'm working on uploading pictures to help guide people though the process as well. Let me know if I can do anything to help.
Hope this helps and if it does please rate it accordingly. Good luck.
Posted on Dec 19, 2010
  • 293 Answers
SOURCE: i have a vizio vf552xvt lcd led hdtv and i wood
You can connect your computer in your television by using VGA connector cable or HDMI cable.Then set the TV into PC in by selecting at the menu setting.
Posted on Jul 04, 2011
SOURCE: I have a 55' Vizio Tru LED model VF552XVT. The TV ran fine for a year and a half and just recently the screen started shutting off after a few hours. I am aware that there is an issue where Vizio
It sounds like an overheating issue with the T-con board. You shouldn't have to run a house fan behind the TV to keep the screen on. Make sure you have the TV in a place where there is enough space around it to allow for air flow. Also, check to make sure the ventilation slots on the back of the TV are not blocked with dust.
Posted on Sep 02, 2012
My tv randomly shuts off
Fault to its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
May 25, 2015 | Vizio VF552XVT 55 in. LCD HDTV
How do i connect wireless keyboard to the TV
Often you can only use "approved" input devices such as keyboards and remotes. This TV came with a Bluetooth remote that has a keyboard on it. You may not be able to connect any other keyboard to it. If you have a Bluetooth keyboard, you can try to connect it if the option is available in the menu (usually setup section). You can also call Vizio to verify if you can connect any other keyboard to the TV besides the remote that came with it.
Nov 04, 2013 | Vizio VF552XVT 55 in. LCD HDTV
55" vizio keeps shuting down
Shut-ing, no wonder it keeps shutting down.
Aug 21, 2013 | Vizio XVT553SV 55 in. LCD TV
Screen show a lot of green ghosting throughout
I had the same problem and removing and replacing the T-Con Board fixed it. I purchased the board from ShopJimmy.com for $59.16. P/N 6871L-4550A T-Con
Apr 04, 2013 | Vizio VF552XVT 55" inch Class XVT Series...
NO VIDEO HAS SOUND WITH CHANNELS, BACKLIGHT LIT
I believe your suspicions are correct. The video portion has failed in some way
Jan 22, 2013 | Vizio VF552XVT 55 in. LCD HDTV
Button on remote not working
Dear xa_becca,
The button must have been worn out with constant use. Try pressing it a bit harder or simply go out and buy a new remote.
Oct 19, 2012 | Vizio VF552XVT 55 in. LCD HDTV
Aug 30, 2012 | Vizio VF552XVT 55" inch Class XVT Series...
How do i fix a picture problem on a Vizio VF552XVT?
not a do it yourself repair--one or more boards are possible.
Jun 26, 2012 | Vizio VF552XVT 55 in. LCD HDTV
I have a vizio vf552xvt lcd led hdtv and i wood like some help with connecting my computer dell xps 8100
Jul 04, 2011 | Vizio VF550M 55 in. LCD HDTV
Televison & Video Logo
32 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
