Question about Dryers
My crosly dryer well not start - Dryers
  • Dryers Master
  • 8,220 Answers
The fuse is mounted beside the heater element. You need to check for lint balls or a bad blower, very common on these dryers. use a butter knofe or a putty knife to pop the top. then get the screws that hold the front off and lift the front out the way. Inspect for lint and loose blower wheel. Remove the drum and vacuum out the dryer. Replace the fuse. Check out these repair pictures that show the limit beside the heater.
Posted on Jul 25, 2009
  • Dan Webster
    Dan Webster Jul 25, 2009
    The thermal limit must be replaced. I call it a fuse but they call it a thermal limit. More PICTURES
Dryer comes on but won't start any cycle. What could be causing this?
Samsung Dryer Won't Start - Model DV448AGPXAA - Repair ...
www.repairclinic.com/...Dryer/...-/Samsung-Dryer-won-t-start-DV448A...
Samsung dryer won't start? Use our DIY troubleshooting & videos. Then, get the parts you need fast. Return any part for 365 days.
Dryer Won't Start - Repair Parts - RepairClinic.com
www.repairclinic.com/RepairHelp/How-To...Dryer/...---/Dryer-won-t-sta...
If the dryer hums but does not start, the start switch is not at fault. If the dryer does not respond or make any noise, the start switch could be at fault. Use a ...
Troubleshooting Why Your Dryer Won't Start ' PartSelect ...
? 4:47
https://www.youtube.com/watch?v=9xD7lCXJ0ZM
Oct 14, 2011 - Uploaded by PartSelect
In this video you'll learn why your dryer might not be starting. ... If it makes noise but won't start trying spinning the drum empty ten times then close door and try it. ... I changed the door switch and still gives code AU. any suggestions .... thermal fuse everything seems good except my dryer won't come on!!!.
Samsung Dryer DV431AEP - won't start cycle - Appliance Repai
Jan 10, 2016 | Samsung Dv410aew 7.4 Cuft 11-cycle Steam...
Crosly top load makes an"ehhhh" stuck like sound whn spin cycle should be going. It smelled hot when the spin stopped working help please :)
sounds like the brake is jammed or the gearbox or clutch...isnt right
i would have a tech look at it if you cant figure out whats up easily
Mar 09, 2015 | Washing Machines
Kenwood turntable no sound?
Are you using a magnetic "PHONO" input on your amp/receiver, or just a line/aux input? The 'good' turntables from the 70's - 80's used magnetic catridges with a very low level output - you will need a phono preamp in order to hear the turntable. Only phonos (Crosly) that use ceramic catridges generate enough voltage without a preamp. Good luck and let me know if that answered your question.
Aug 10, 2014 | Technics SL-1210 Turntable
How do i get a 1990s sanyo universal reamote to work a 1980s crosly tv
They will not work for each other---the crosley uses a ultrasonic remote and the other a infrared remote.
Mar 18, 2012 | Televison & Video
The other day I started my crosly dryer and it ran for a split second then stopped. i could smell a short but i couldnt find it. i pulled the back off where the knobs are but i couldnt find anything burnt....
that is a very classic sympthom of a bad motor
if it will run for a short time after the motor is cool but wont run till it once again cools down the motor is bad
Jun 28, 2011 | Crosley CDE6000 Electric Dryer
I have a Crosly Dryer. It no longer heats. What is wrong and where would I get the part?
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Nov 07, 2010 | Crosley CDE6000 Electric Dryer
Start switch hums, does not start.
There can be many reasons why your dryer2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer2_bing.gif is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer2_bing.gif Repair ? The dryer2_bing.gif will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Jun 01, 2010 | GE DWSR405EBWW Electric Dryer
GE dryer must hold start button to keep dryer running
heatman101
Jun 20, 2009 | GE 5.8 Cu. Ft. Extra-Large Capacity...
Crosley Model CR79 (4 in 1) not working
FWIW, here's a link to Crosly online support. The only phone number I know of is 1-866-CROSLEY.
I suspect you might have better luck with a reliable local stereo/audio technician.
Sorry I couldn't offer more hopeful advice...
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Apr 30, 2009 | Crosley 4-in-1 Entertainer CD Shelf System
Hotpoint side-by-side freezer drain freezes
yes totally defrost unit and verify drain is not plugged, make sure drain is trapped. it may drain into a pan on top of compressor, where heat dissipated by compressor evaporates condensate. certain crosly model freezers made by w.c. wood co. have a problem with that.
Mar 30, 2008 | Refrigerators
Dryers Logo
54 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
