Question about Tablets & eReaders
High voltage on my tablet - Tablets & eReaders
Need know what voltage ac for tablet
I would be surprised if any tablet required an ac voltage. Such devices as phones, tablets, laptops and other small computerised devices almost universally use a regulated and smoothed low voltage dc power adaptor.
Jan 25, 2017 | Tablets & eReaders
When traveling to countries with 220 voltage, is there any danger of overheating my ellipsis 8 android tablet, or should I use a voltage converter?
You can't use your current 110 V converter. Should go to a local accesory store selling converters for your tablet and buy a 220V converter with output SPECIFIED FOR YOUR TABLET - mean, voltage and amperage.
Even using a 220 V converter, you can fry your tablet by not using the PROPER converter.
Jul 01, 2015 | Tablets & eReaders
Cannot turn on. Battery does not hold charge.
I guess your battery is faulty. It may be a result of overcharging which may have caused the battery to be bloated. High voltage from the charger could also have been a reason for the battery's fault.
For this case, I believe your battery is in-built into your tablet. I suggest taking it a repair centre. Also, avoid charging or using as as it may lead to electrical circuit faults which may cause sparks within the tablet.
Nov 30, 2014 | Tablets & eReaders
Why my tablet cant charge?
Check the output of the charger to make sure its delivering the proper voltage to the tablet.
Nov 05, 2014 | Coby kyros Tablets & eReaders
I have had my kocaso m9100 tablet since this past christmas and not had any problems with it until recently. It went completely dead and i had it on the charger for more than 6 hours with a little red...
You need to check battery to see if the battery has correct voltage. Their should be on the battery the number for voltage of battery if battery is not at suggested voltage then check for tablet with voltage meter to see if the tablet is charging at correct voltage. If battery is at correct voltage then something is wrong with tablet. If battery is not at correct voltage then probably battery is bad. Let me know for further assistance
Aug 24, 2014 | Kocaso M M9100 9-Inch 8 GB Tablet
Used wrong charger on tablet, why it won't come on
Hi if the charger used was too high in the voltage, it would probably destroy the tablet. Try charging with the correct one and see what happens.
Don
Jul 03, 2014 | HKC 7" Touchscreen 8GB Tablet 1GHz Android...
My main, most annoying problem with this device is charging it. Sometimes it charges...sometimes it doesn't (more often not) and no matter what outlet it's plugged into or for how long. The icon at the...
With many of these cheaper Android products it's highly recommended to go buy a better charger. You can go to Radioshack, if you have one in your area, and pick up a universal charger that should have the right tip and an adjustable voltage setting. Make sure to get one that matches the original voltage and amperage exactly.
This is a common problem with many of these cheaper tablets coming out of China, they all tend to have poor chargers.
Feb 28, 2011 | PANDIGITAL Digital Book 843967071153...
What do I need to use my Touchsmart tx2 in France. Do I need an adapter or transformer or both
You live in the US, right?
First check the voltage rating on your power supply / charger's primary voltage range. If it states around 110V only, then you need a transformer from 230V to 110V with an euopean plug. Make sure it's a real transformer (rather heavy, rated at ~100VA will be OK), and not a lightweight high-power adaptor, used for lamps, pressing irons, heaters and similar appliances.
If on your charger it states something like "90-240V", then it will cope with the standard european voltage of 230V, and the only thing you need is a travel adapter that will have an european plug on one side and an american socket on the other.
Oct 25, 2009 | HP TouchSmart tx2-1270us Tablet PC
Not used for 1year will not charge up
It is possible that the battery of your Tablet is dead, Still you can try to connect the Tablet PC Directly with the AC adapter.
For you reference you can download the Manual From the following link
http://www.retrevo.com/d/df/P1510D_06SPR_USERSGUIDE.PDF?doc=9388c66467ea4385d3e5c4b5df5cbd28&ts=1254481117154
Oct 02, 2009 | Fujitsu Siemens LIFEBOOK P1510D Tablet PC
Tablets & eReaders Logo
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
