Question about Samsung Office Equipment & Supplies
HI, What causes Ghost images and blush marks when printing with a Samsung CLP315w Laser Printer?
pagebor
  • 2785 Answers
SOURCE: dell laser 300cn
is it happening always or sometime, have you check the cartridge
Posted on May 01, 2008
  • 158 Answers
SOURCE: Colour printing gives ghost image
Are you using genuine Brother color cartridges? If you are, then try different paper (20 pound laser printer paper or plain paper copier paper rather than inkjet paper,) Also, do not use recycled paper. If that does not work, you may need a new imaging (OPC belt) unit, or a new fuser assembly. Check your owners manual about when to replace the imaging unit or fuser. It is usually after 60, 000 prints have been run.
Posted on Jun 09, 2008
komguy
  • 2306 Answers
SOURCE: HP 3015 laser printer with ghost image
A fuser image should only be about 1 1/2 inches away, 3 inches sounds like a drum problem.
Posted on Aug 03, 2009
  • 670 Answers
SOURCE: samsung laser printer prints faded in center
You probally had the imaging unit replaced. The image drum is part of the imaging unit. The problem you described is a common problem with this printer. The cause is that the developer blades in the imaging unit gets coated with toner, and that coating blocks the toner from getting onto the paper to make the image. It get less and less and it shows up as light printing.
It can be fixed by replacing the imaging unit or you can clean the blades yourself if you are handy. If you look at my tips section, I have a detail instructions with pictures showing you how to do it. Hope this helps.
Posted on May 01, 2010
  • 241 Answers
SOURCE: my samsung 3175fn laser printer keeps getting a black line and ye
The printer has a build up of toner on the drum/fuser, a maintenance cleaning done by certified technician of the printer would fix this problem.
Posted on May 31, 2010
How to open the paper tray on the canon clp 315w printer?
Hi Gary, The link below is a free 107 page user guide for a Samsung CLP315w color laser printer I thought you might be interested in.......CHEERS.. http://www.manualsprinter.com/manuals/samsung/Samsung_CLP-315W.pdf
Apr 03, 2016 | Samsung CLP315W Laser Printer
Samsung clx-3160 fn printing ghost images
Remove the fusing unit and clean the upper and lower fuser roller.
Apr 04, 2013 | Samsung CLX-3160 All-In-One Laser Printer
My samsung ML 2510 prints a black streak on each plus a watermark from previous page
If your paper setting are set corectly (normal paper) and you are getting a "ghost image" from the previous page, most likley the fuser is the problem. On rare occasions, the drum unit could be the culpret (Black lines) down the sides of the page as you indicated.
You may have 2 problems.
I would change the toner drum 1st. If the black lines go away ,yet the ghost image continues, then change the fuser as well.
Jan 16, 2011 | Samsung ML-2510 Laser Printer
The print is black and sharp (good) on the left and right edges, but toward the middle it's a bit lighter. It's still fully readable, but not so nice. Suggestions on what can cause this? Printer: CLP315W
Hello
The toner in cartridge is uneven, this caused when the toner is going to end, for instant remedy, pull out the cartridge, shake well and put it back, it will pass some more time till the toner end, then you must replace/refill the cartridge,
Hope it helps, if so do rate the solution
good luck
Dec 15, 2010 | Samsung CLP 315 Laser Printer
Aug 03, 2009 | HP LaserJet 3015 All-In-One Printer
I am getting a ghost image of what I am printing repeating down the center of the page.
i would say ghost image is more likelly your imaging drum.
some printers have the imaging drum built into the cartridge some have it separate.
i would say try another cartridge
also don't trust remanufactured cartridges if you are concerned with print quality.
Apr 24, 2009 | Samsung ML 1430 Laser Printer
Jun 09, 2008 | Brother MFC-9420CN All-In-One Laser...
Dell laser 300cn
May 01, 2008 | Dell 3000cn Color Laser Printer
Laser Printer Problem
Do a panic stop while the machine is in the middle of processing copy. Remove the imaging unit and lift the drum cover to view the surface of the drum. If the image produced on the drum is OK (ie.no ghost image) then focus your attention on the hot rollers just before the paper exit. Otherwise your problem is the imaging unit.
Dec 31, 2007 | Office Equipment & Supplies
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
