Question about Samsung Refrigerators
My Samsung ice box twin cooling plus quit making ice tried everything its cold but wont freeze ice
  • 23 Answers
SOURCE: frigde wont get cold but freezer does.
I am an authorized Samsung service center, and I have dealt with this ongoing design problem for years. The problem occurs when the unit comes out of the defrost cycle, not all of the frost has been removed by the defrost element and an ice bridge occurs at the top and bottom evaporator coil. There are sensors that send readings back to the main PCB during and after this cycle, They have to be replaced along with adding heat transfer clips for better frost meltage and air circulation.
Order the following parts through Samsung:: Fixer # DA61-03585A, Plate # DA61-03502A, Thermal Bi-metal # DA47-10160H, Sensor # DA32-00006W. Have these parts installed by a professional appliance repair company.
I hope this will fix your dilemma, Ward Appliance Repair.
Posted on Dec 29, 2008
  • 1524 Answers
SOURCE: I have a Roper RT21LMXKQ00 Freezer wont freeze
The problem is a defrost problem. The freezer coil has frost on it and thus restricts the cold air from flowing. This affects the refrigerator as it gets its cold air from the freezer. The ice will not make if the temperature is above 12*F and this also is why ice cream is like mush.
Posted on Apr 23, 2009
SOURCE: GE Monogram Ice Maker makes ice, unit doesn't cool enough
This model Icemaker makes ice by flowing water across a freeze plate. It is located in the top of the unit behind the white cover directly below the ON/OFF/CLEAN switches. After freezing a sheet of ice it releases and slides to the cutting grid. It then drops into the ice bin and begins to melt and the whole process starts over again. The level of ice in the bin is controlled by the high level sensor on the right side of the ice bin. It is a whit tube with two wires coming out of the top. Without this sensor it can overrun the bin capacity. Bottom line this unit does not freeze ice, it only holds it like cooler does.
Posted on Jun 04, 2009
SOURCE: not cooling or freezing
westinghouse virtuoso fridge section working freezer cool but not freezing food even when adjusting freezer to as cold as it can be !!
Posted on Aug 03, 2009
  • 43501 Answers
SOURCE: Maytag Plus side by side (Model MSD2356AEA)not cooling in
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
Posted on Sep 29, 2010
My Samsung refrigerator, 26" twin cooling plus wont make ice, the ice off button wont reset, even if I hold the filter reset button, as was suggested manual. freezing fine, just stopped making ice
How old is it? The motor may be turning inside but the plastic gears could be stripped inside and it wont move. Sometimes the entire icemaker unit on refrigerators need replaced. It could require a closer look.
Jun 20, 2015 | Samsung RF265AA Bottom Freezer French Door...
Samsung side by side twin cool Refrigerator side not cooling
Is it freezing from the bottom up? If so check the drain is clear. If it's freezing all over, check the condenser is clean and clear and the compressor switches off when it reaches temperature. Lastly, check the door seals properly all the way round
Apr 23, 2012 | Samsung Refrigerators
My side by side kenmore refrigerator, freezer isnt freezing
the fan in the freezer is not working to blow the cold air in the freezer you need a new fan you need a repair man it will cost you $300 good luck i have the same problem don't buy samsung they are useless that why home depot don't sale samsung
Nov 12, 2009 | Samsung RS265LABP Side by Side...
a symptom of low refrigerrant is that the evaporator coil will develop a small very cold area but wont cool the entire surface .. that cold area can ice up and block air flow .. the result can be an overworked compressor with little or no cooling ... other things that can cause the same trouble
1. bad or blocked air flow on the external coils or condenser fan ..
2. a leak in the door seal will allow moisture that can cause icing
if there is icing then you can turn it off with the door open until the ice melts .. then start over ..
Jul 24, 2009 | Freezers
Apr 23, 2009 | Roper RT21AKXKQ Top Freezer Refrigerator
Samsung RS2556SH
I have a samsung Refrigerator model No. RS2556sh. The Fridge temperature indicator is blinking at 38 degrees. What is the cause for it? How can stop it? Please anwser me through my email: alicezhang90@yahoo.comThanks.
Feb 06, 2008 | Samsung RS2556 Side by Side Refrigerator
Frigedair refrigator
My GE Side by Side refrigerator is about ten years old. the refrigerator side stopped working and is warm. The ice box side is cool but is not as cold as it usually operates.
Nov 07, 2007 | Whirlpool GD5SHAX Side by Side...
Refrigerators Logo
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
