My HD TV just overnight has no picture, just a black screen, but the sound is perfect. Do I need to call a repairman, Or is this something I can handle?
Tried to turn in on this morning. The caption clicked on for a second and then went off. I tried it several times. I disconnected it for a minute, but the same results happened. I pushed in connections on the back, and finally the sound came on, but still no picture at all.
SOURCE: TV turns on then off no picture
I was watching my tv and it just automatically turn off, everytime since then i turn it on it goes off in seconds without picture or sound comes.
Posted on Oct 01, 2006
  • 150 Answers
this is very common. it is the power supply going bad. it should run at 130 volts dc. but it is now running much lower that this. just enought for the tv to come on. but not enough to power all the circuits right.
Posted on Nov 20, 2007
SOURCE: Picture gone
Yes, if I plug it in the green light comes on and the clicking sound goes for several minutes trying to reset I guess then thes\ set shuts off and the green light goes out. If I turn the power on again it will keep repeating this cycle.
Posted on Jan 03, 2008
  • 3 Answers
SOURCE: No Picture
It's the Y-Sustainer problem. However, they normally change the Y-Sus and Z-sus boards at the same time. It's a costly repair.
Posted on Apr 06, 2008
  • 4472 Answers
SOURCE: HCN5527W Samsung wide screen 55" will not turn on, scree went black unit 4 1/2 years old
As stated it is a convergence problem and requires service follow this link to find the nearest authorized service center:
Posted on Aug 29, 2008
Why does the screen shut down after 1 sec while sound continues
It sounds like bad luck to me. You cannot change any settings on a TV by connecting a computer to it. In theory you can damage any monitor by setting the screen resolution of the computer higher than the monitors maximum res. The Sharp 26" has a resolution of 1366 x 768 (1080i) so (again in theory and I have never seen it happen) if you set the output to 1920 x 1024 (HD - 1080p) it can kill the screen. Perhaps this is what has happened. You will need to take it to a Sharp service centre.
May 29, 2014 | Sharp LC-26SD1E 26 in. LCD Television
TV shuts off after 3 seconds
If the sound is still heard then the inverter board has failed and is triping the powersupply,if no sound the powersupply has failed.
Mar 29, 2014 | Panasonic VIERA TC-P50U50 50-Inch 1080p...
I left my 60 inch rear projection mitsubishi HD 1080 on overnight as I fell asleep in front of it for about 5 hours (11pm - 4am). This morning when I turned it on the picture is doing a fisheye effect on...
It sounds your Mitsubishi rear projection tv got problem with convergence output chips failure, I'm not aware about model number of this tv so unable to provide you specific info however, it is hardware failure and few parts need to be replaced by tv repairman.
Convergence output chips make align picture on front screen and if they stop working, you will see 3D look or bowed picture with different colors.
Contact local tv repair shop to fix this issue in tv.
Nov 17, 2010 | Televison & Video
Our Phillips HD projection tv has lost a picture. It started by blacking out once in a while but now the picture is constantly rolling. The screen is distorted and it's impossible to even recognize what is...
Cloudy,distorted pictures.The tv have R,B,G CRT tubes gun coolant probblem.Tries websites like, to buy a Coolant kit to replaced.
Sep 11, 2010 | Philips 55PW9363 55" Rear Projection...
My LG HD tv screen suddenly went green. sound is
I disagree with info provided, if screen of your LG lcd tv becomes green that means inverter board is working and lcd tv does not have convergence ICs.
Please unplug tv from ac wall socket for minute to get it reset, replug back in and turn it On and check its picture.
If still showing green screen then change input source with remote, if tv shows same green screen on all inputs that means its either lcd panel problem or digital signal processor got bad loacted on main board. Local tv repairman is needed to confirm and fix it.
Jul 21, 2010 | LG 42LC2D 42 in. LCD HDTV
Sound but no picture
hi sir
as it is not giving the perfect picture so it might have gone wrong in the screen pixels better to check the lcd screen and me sure the pixels went wrong it can be also coz of the water vapours please keep the tv away from water or windows etc.there might be a circuit problem which may not be working .
thank you
Jun 29, 2009 | Samsung LE40R72BDX 40 in. HD-Ready LCD...
37" Philips LCD sound but no picture
Check the inverter on the sides of the TV. This sounds like the inverter is going bad and that's the reason why you have sound but not picture.
Jun 16, 2009 | Philips 37PF7320A 37 in. HD-Ready LCD...
TV blank, sound okay, picture comes for half a second while switching channels
i am a technician and i too have this issue. if any of you can get a schematic and service notes, send them to trae3@live .com and i WILL find the problem and report to each of you. i cant get any help from sears all i need is to speak with a technician who actually works on these things, get the paperwork and then i am sure it is a matter of a module swap. any info will help us!
Jun 23, 2008 | Protron PLTV-26 26 in. HD-Ready LCD...
Vizio GV42L LCD TV screen black when turn TV on first time
If you are using a set top box this might be caused by turnig the box on at the same tie as you turn the tv on or slightly after you turn the tv on.  If you are using compnent or HDMI inputs the set needs to see the signal as it is turned on to know what formt the signal is in.
Oct 15, 2007 | Vizio P2 42 in. HD-Ready Plasma Television
Televison & Video Logo
26 people viewed this question
Top Televison & Video Experts
