Black screen. no picture but sound is perfect. This happened over night. HD TV.
SOURCE: ROLLING TV SCREEN
After 2 days of problems with it, I finally fixed it by unplugging it and plugging back in! Works like new.
Posted on Apr 04, 2008
  • 59 Answers
SOURCE: Philips HD tv has no picture
common fault this , normally the fuse has failed on y-main board due to shorted thick film unit
unfortunately its not a cheep repair job.
Posted on Aug 18, 2009
SOURCE: Kenmark 20" LCD TV Sound but no picture
My Kenmark Tv Switches its picture off if the PSU voltage drops. Audio is OK but picture does not return as PSU voltage goes back up. PSU's are about £10 online !2Volt 4A Might be worth a punt
Posted on Sep 21, 2009
fosg2000
  • 229 Answers
SOURCE: Half TV screen is black
you have a bad Y Sustain board or X Sustain board
undo the back (if you know how to deal with electronics) and with the TV unplugged disconnect one of the board and turn on, see if works or not and try with the other one till find out wich one is.
Fosg2000, Rate me
Posted on Apr 13, 2010
welcomejee
  • 10594 Answers
SOURCE: my LG HD tv screen suddenly went green. sound is
I disagree with info provided, if screen of your LG lcd tv becomes green that means inverter board is working and lcd tv does not have convergence ICs.
Please unplug tv from ac wall socket for minute to get it reset, replug back in and turn it On and check its picture.
If still showing green screen then change input source with remote, if tv shows same green screen on all inputs that means its either lcd panel problem or digital signal processor got bad loacted on main board. Local tv repairman is needed to confirm and fix it.
Thanks.
Posted on Jul 23, 2010
I have sound but while I was watching it the screen went black ,now I have sound but no picture.
Turn the tv off and on again and uf it happened again . The power supply board will need to be replaced or the screen itself
May 07, 2015 | RCA 40 Full Hd Lcd Tv 40la45rq
Why does the screen shut down after 1 sec while sound continues
It sounds like bad luck to me. You cannot change any settings on a TV by connecting a computer to it. In theory you can damage any monitor by setting the screen resolution of the computer higher than the monitors maximum res. The Sharp 26" has a resolution of 1366 x 768 (1080i) so (again in theory and I have never seen it happen) if you set the output to 1920 x 1024 (HD - 1080p) it can kill the screen. Perhaps this is what has happened. You will need to take it to a Sharp service centre.
May 29, 2014 | Sharp LC-26SD1E 26 in. LCD Television
Sound no picture
I think you hit the wrong button before....
To restore the settings please try to restore factory setting and see what happen..
Nov 22, 2011 | Samsung LN22A450 22 in. LCD HDTV
hi sir
as it is not giving the perfect picture so it might have gone wrong in the screen pixels better to check the lcd screen and me sure the pixels went wrong it can be also coz of the water vapours please keep the tv away from water or windows etc.there might be a circuit problem which may not be working .
thank you
Jun 29, 2009 | Samsung LE40R72BDX 40 in. HD-Ready LCD...
ROLLING TV SCREEN
Apr 03, 2008 | Westinghouse LTV-27W2 27 in. HD-Ready LCD...
Black screen and no sound
I realized that there is a 90 day warrantee on parts and a 30 day limited warrantee on labor for the  repairs that were done. As I stated, the original problem was the picture shrinking after a few minutes of the set being on. The repair firm took my control board with them. When they came back to install the repaired control board in my set there was a load spark during the installation, after which I had a black screen and no sound.  The repair firm took my set them and installed a "CAP Kit", a STRM6511, and a "D1881". The set worked perfectly until two days ago.
I called the repair firm an they are coming out this Thursday to check out my TV.   I am hoping the problem is related to the failure of one of the parts installed to fix a similar problem which occurred after the sparking incident.
Mar 31, 2008 | Mitsubishi CS-40505 TV
Hitachi 32LD6600 - When the TV has been on for abot 30 minutes the colours start to go blue/red and the picture is distorted,noting I do gets the picture to display as normal.
Hi i have this tv and last night the screen went black i can hear sound ok but no picture just a black screen, Also i can see dark
outlines /shadows of whats on the tv, can you tell me please what has caused this
Mar 05, 2008 | Hitachi 26LD6600 26 in. HD-Ready LCD...
Problem with viewing DVDs
Video format error. change pal or ntsc and try
Feb 27, 2008 | ViewSonic N2750w 27 in. HD-Ready LCD...
Vizio GV42L LCD TV screen black when turn TV on first time
If you are using a set top box this might be caused by turnig the box on at the same tie as you turn the tv on or slightly after you turn the tv on.  If you are using compnent or HDMI inputs the set needs to see the signal as it is turned on to know what formt the signal is in.
Oct 15, 2007 | Vizio P2 42 in. HD-Ready Plasma Television
Televison & Video Logo
22 people viewed this question
Top Televison & Video Experts
