How do I get Closed Captioning OFF? - Televison & Video
  • 822 Answers
If you are using a cable box the settings for CC are in the menu of the cable box and not the TV menu,
Hope this helps?
How do I get Closed Captioning OFF? - test-cox-remote-to-tv-rxqoyelogmhreiemkmjokacx-3-0.jpg
Posted on Apr 16, 2017
How to get rid of closed captioning
If pressing the cc button on the Sharp remote does not turn off the closed captioning then the closed captioning is most likely coming from the cable box or whatever you have connected to this television. You can go into the cable box menu by pressing the menu button on the front when it is turned off. That's right turn off the cable box and then press menu on it to access the hidden menu that includes closed captioning. Scroll down to closed captioning and scroll over to disable. A number of other Directv receivers have the CC located on a "captioning" tab on the "display" page under setup and for dish network:
Setting Closed Captioning:
  1. Press and release the MENU button and then select "Preferences."
  2. Select "Closed Caption."
  3. Select "Caption On/Off."
  4. Select "CC is On."
  5. Select "Done."
Sep 20, 2011 | Sharp Televison & Video
I wish to use closed captioning but I can't find the function on my Panasonic TH-42PWD6 monitor. Does it have a closed captioning function, and if so how can I turn it on and off? Thanks.
Researching this monitor, it appears to be a professional monitor with plug-in modules for different inputs. It does not appear to support closed captioning natively.
However, some Set Top Boxes (STBs) do closed captioning themselves. For example, most newer DirecTV STBs have captioning capabilities on the box rather than using the montior's closed captioning feature. Perhaps your source material can open caption for you.
May 06, 2011 | Televison & Video
I need closed caption
Tv air broadcasting shows have to say it,to have closed captioning or have to have a white small sign that said CC to be able to get closed captioning ok.Look for it in ur remote there a button that said CC pushes that button go to CC1,2, u will get closed captioning.Or go into ur tv Menu find closed captioning functions turn it on like CC1,2,3...or Text 1,2,3.. on.Now ur tv are ready to get closed captioning,for the tv air broadcasting shows,that have closed captioning.
Dec 10, 2010 | Broksonic TV
I have a panasonic TV. direct tv remote for a . while programming the timer, somehow closed captioning got turned on & i after hours of trying to get it turned off, NO LUCK. it's driving me insane!!...
I could do better with a picture of the remote. Closed captioning is usually a multi-press button, that is each press takes you through each of the four types of closed captioning and then off.
You can enable closed captioning on a DVD Recorder, it looks like the TV, but its only on the picture from the DVD Recorder.
If you have a PVR, you could have closed captioning on on that device.
Try tuning off everything else to make sure it IS the TV.
Turn on the menu and find the closed captioning settings and set to OFF.
Press the close captioning button on the remote (If there is one) and press CC repeatedly until it says OFF.
Try and control close captioning, timer and menus with the ORIGINAL remote and not a programmable one.
Programmable remotes are not always completely compatible.
Mar 20, 2010 | RCA Universal Remote Control
I need to activate CC for my Dad, Please help I have to go to work. I have a flat screen SOYO
Determine if closed captioning is available on the program that you've selected. In your program guide, the letters "CC" should appear at the end of the description.
Locate the closed captioning option on your remote. Some remotes have a "CC" button that you simply need to push to activate closed captioning
Locate the closed captioning option in your television's menu if there is no "CC" button on your remote. To do this, push the "menu" button on the remote control. The closed captioning option will probably be in the same section as the language function.
Set the closed captioning option to "on." Within several seconds, you should see the text appear on your screen.
To use closed captioning for DVDs, look for the "CC" label on the lower back section of the DVD case where it lists audio information. Turn on your TV's closed captioning and you should see the captioning like you do on a television program. Alternately, some DVDs include English subtitles that you can turn on in the setup/language menu of the DVD.
Thank you.
Aug 28, 2009 | Televison & Video
How to activate "closed captioning" for a Proscan Full HD 1080P
Comcast's remote has nothing to do with closed captioning. It's on your tv remote. First, the tv has to be capable of handling closed captioning, and your's is- and second, the program must have closed captioning provided- current programs do, some older shows do not support closed captioning. Recheck your remote, and if necessary- look at the setup instructions that came with the TV- they should also be posted online at the Proscan support site.
Mar 26, 2009 | Proscan 26LB30QD 26 in. LCD HDTV
Closed captioning
The closed captioning has to be sent in another language, and your set will follow it. Call the TV station to find out where they are getting the captioning from, or maybe they can get you directly in touch with the captioning people.
The closed captioning is sent as one of the many information packets during the vertical blanking interval. In the NTSC system, it is sent on line 21 in both the even and odd fields. There are usualy 2 closed captioning selections for text. These are the CC1 and CC2. They are decoded according to their address code.
Jerry G.
Jun 28, 2008 | Insignia 19 in. Widescreen Flat-Panel LCD...
Closed captioning
The closed captioning decoder circuit in your TV set may not be working, or the closed captioning information from the station may not be present. Start investigating by finding out if there is actualy closed caption from the station that you are tuned in to. If so, then call the tech support for your set to know if there is something that you missed in the set-up for the closed captioning. It may be very simple. If all of this does not work, then the closed captioning decoder in the set may not be working properly and require service.
Jerry G.
Jan 06, 2008 | Sanyo DP42746 42 in. Plasma Television
Closed captioning
I had the same problem. My DVD player was connected to my HD TV via a HDMI cable as was recommended by the DVD owner's manual. I removed the HDMI cable and attached the three video component cables. Bingo, closed caption crossed immediately.
Aug 09, 2007 | Funai MWC24T5 24 in. OLED Television
Televison & Video Logo
29 people viewed this question
Top Televison & Video Experts
