Question about Malibu Hardware & Accessories
I have a Malibu 600W transformer with 17 20W lights. All the lights turn on but after 3-5 minutes 14 lights turn off. Suggestions?
    Top Expert:
  • 48,419 Answers
Try replacing the light just before the pint where the lights turn off
eg -- if the first 3 lights work replace light no 4 as it is possible that it is failing from an overheating component internally
Posted on Apr 16, 2017
  • Jon Sullberg
    Jon Sullberg Apr 21, 2017
    Bill, your suggestion was perfect. I did not disconnect the light but took out the light bulb. I kept the lights on for 3 hours and they burned beautifully. My next step is to replace the very old light fixtures and add a couple more. Thank you very much!
I have a Malibu 300 watt transformer that is 4 years old. it is working but after about 15 minutes the lights turn off and the red rest button pops. I tested so it is not the outlet.
check what you have running from the transformer
if it uses more than 280 watts the transformer is overheating and throwing the reset button
Jun 25, 2017 | Malibu Hardware & Accessories
Describe your Malibu 600W Power Pack Transformer Problem When it is time for the low voltage lights to come on the timer can not get past the pin to turn it on, however when I turn the timer dial it...
When dial gets stuck at tripper, then clock motor has gotten weak.
1) Some people report taking apart the clock motor, cleaning gears, and adding vaseline to gears.
-Some people write and ask how to put gears back together after taking timer apart.
-Some people find the gears are stripped.
-There are no replacement clock motors or timer modules for Malibu/Intermatic timers.
2) Easiest solution might be to buy cheap plug in timer, set power pack to override, then plug power pack into cheap timer.
3) Power packs come with a warranty, but warranty requires sales receipt.
-Open following link for resources including warranty.
4) Take a moment and rate answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Sep 08, 2011 | Intermatic Malibu 300W Power Pack...
Hello! I have a Malibu transformer for my outdoor lighting. Last night, we had a severe rain storm. During the storm, my outdoor lighting went out. When I went to check the transformer box this...
My malibu transformer has a reset button on the back near the terminal connections. If the transformer is on (time displays on the panel) but the light fixtures are not lit, look for the reset button on the back and depress it.
Oct 07, 2010 | Malibu Hardware & Accessories
I have a two wire to connect to output A B C on a malibu ml600tw low voltage transformer. Which two output do I use?
Use "A" and "B" terminals. The "C" terminal is a "dummy" terminal - it isn't connected to anything inside the transformer. It is used as a splice point in the event you decide to connect a photo cell (dawn to dusk) controller.
Aug 22, 2010 | Intermatic ML600TW MALIBU POWER PACK 600W...
Hi, i have a 600w fusion amplifier in my house running on a transformer. when i turn it on the red light comes on but when it changes to green the transformer shorts out. its not the transformer thats...
How many watts is your power supply capable of supplying to a given load. There could be a problem with your amp. The quiescent current should be in the high mA to low A range which in no way would cause your supply to overload.
Dec 20, 2009 | Car Audio & Video
Hardware & Accessories Logo
342 people viewed this question
Top Malibu Hardware & Accessories Experts
Craig Butler
Craig Butler
Gene Haynes
Are you a Malibu Hardware and Accessory Expert? Answer questions, earn points and help others
