Question about Garden
Cadet 1154 have replaced pto clutch new spark plugs oil change filter thought it was the pto clutch cause the pto will run when standing still start to move it disengages this happens intermittently
lastech
  • 408 Answers
SOURCE: 1987 mercedes 190e replaced spark plugs put new gas and filter and battery and oil change car start but wont turn over
hello,be sure your starter motor is working,fly wheel gear(for starter bendix drive)should also check,valve clearance also,try to rotate your engine with socket 27mm,(manually) maybe your piston is stuck-up,ty
Posted on Apr 28, 2009
panilling9
  • 284 Answers
SOURCE: engine stalls when electric PTO clutch is engaged
check your spacers to be sure you havent locked the clutch assembly directly to the motor shaft
you should be able to turn it fairly free less some clutch drag
Posted on May 26, 2009
  • 130 Answers
SOURCE: electric pto won't stay engaged on LT 1045
you have a shortage or your clutch is going bad
Posted on Jul 18, 2009
  • 61 Answers
SOURCE: Cub Cadet 1641 PTO problems
bad switch.
Posted on Sep 06, 2009
  • 110 Answers
SOURCE: Cub Cadet LT1042 PTO won't disengage
If its an electric PTO then the switch on the dash is bad, Its a lever type ungagement then the little break shoes that rub on the blade spindles are either worn out or mis adjusted.If it started when you changed the blade drive belt its possibly the wrong belt??
Posted on Nov 01, 2009
I have a LT1042, cub cadet. PTO clutch burnt up. I replaced it and the solenoid, fuse, and relay. Thinking that when PTO clutch burnt out that something else like a wire or sensor went out also.
Check all the safety switches u have a bad one look under the seat first that one is a common problem so I take it your PTO won't engage I bet your old PTO is still good the safety junk they put on these mowers fails a lot causing problems running your mower also look under the back side by the tire there is another safety switch that gets corroded that's switch is the one that will not let you mow in reverse if you want to bypass it u can just put the wires together then beware your mower will work in reverse also I hope this helps you have a great day Regards Chris
Aug 03, 2016 | Cub Cadet Garden
LT1046 cub cadet blown clutch..what caused this with new Pto switchpto switch froze..replaced it still will not engage blades.what could blow the new clutch
Are you sure it's blown? Run two jumper wires from the battery or power side of the starter solenoid and energize the clutch. If it energizes and clicks, that's eliminated. Did you blow any fuses?
Jun 16, 2016 | Cub Cadet Garden
Rider will not turn over more than once no matter how many times I try.
I sounds like there's significant resistance to the engine turning over. I experienced this when the electric PTO/clutch seized - and the mower was trying to turn over the engine AND the mower blades because the PTO wasn't disengaging. Try taking the mower belt off the PTO and see how the engine turns over. If it's still slow, the problem is in the engine. If it spins normally, replace the PTO clutch. BTW - when my clutch seized, it also burned out the PTO switch. The switch is pretty inexpensive, so if you're replacing the PTO/clutch (I found one online for about $175.00 - MUCH more expensive at the dealership) - you should probably replace the switch as well.
Jun 28, 2014 | Cub Cadet Op's Manual Model Lt1042 Lt1045...
Keeps blowing fuse
There are several things that can cause the fuse to blow. PTO stands for Power Take Off and most likely this will not be the problem unless it blows the fuse when it is turned on. What you are saying is the fuse is blowing by just turning on the switch will be a short which can be anything from a pinched wire, shorted diode, short in the stator. bad voltage regulator.etc
Apr 17, 2014 | Cub Cadet Lawn Mower Electric PTO Clutch...
What does PTO stand for
power take off which drives the belt that runs the mower deck sounds like a dead short in the pto clutch maybe a wire shorting out check for bare wires
I have a rzt 54 cub cadet, when i engage the pto it cuts breifly then the mower shuts down PLEASE HELP
A battery going bad may be your culprit. I found out just the other day that your mower can keep running but when the battery gets too weak, the pto clutch disengages and shuts down,
Apr 29, 2012 | Oregon Scientific Electric PTO Clutch for...
I have a cub cadet LT1018 with 800 hrs. The engine, B&S 18.5 hp, started running rough and sputtering while mowing. Disengaged PTO to return to garage - mower died. Cleaned air filter and restarted,...
Sounds like water in your carberator. Remove the bowl and check for dirt and water, drain some gas from the tank into a bowl and check for water in the gas. Remove air filter housing and lubrcate all of the carberator linking with a product such as WD-40. Reassemble everything and start again. While you are at it check the spark plug too.
Oct 20, 2017 | Cub Cadet Garden
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
