Question about Paragon Hardware & Accessories
I'm looking for a replacement pool timer for my paragon 4004-20 pool timer208-240 volt.
  • 30 Answers
SOURCE: Changing Pool Timer
As long as you get a new timer that is 220/240v and is the same amperage or larger, you should be fine. Wiring would be the same.
Posted on Jul 09, 2009
  • 52 Answers
SOURCE: Paragon timer parts
electricalexpeditors.com
Posted on Oct 05, 2009
al_kupchella
  • 843 Answers
SOURCE: model 4013-00pc pool timer. I am looking for the
Scroll down to the bottom of the page at: http://www.icca.invensys.com/paragon/parts_accessories.htm
Posted on Jun 23, 2010
  • 760 Answers
SOURCE: I'm looking for trippers for a paragon timer for
Try this link, lots of good pictures
Posted on Jul 19, 2010
SOURCE: need trippers for older unknown model number amf
Paragon no longer makes timers or parts, except defrost timers.
Typically, defrost timers are not used for pools.
Open following link to possibly identify timer and tripper part number.
http://waterheatertimer.org/Paragon-timers-and-manuals.html
If you want a new timer for pools, Intermatic makes the T101 120Volt and T104 240Volt:
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html
If you want T100 series timer with fireman's switch that turns off heater 10 minutes before turning off pump:
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#pool
If you have energy-saving 2-speed pool pump, and thermostat and pool light, then buy P1353 digital timer with enclosure. Enclosure and timer sold together as P1353ME.
http://waterheatertimer.org/Intermatic-trippers-and-parts.html#P1353
http://waterheatertimer.org/pdf/PE100-series-with-P1353-timer.pdf
P1353 is not easy to wire or program for novice, so you can add a comment or repost question on fixya and I will catch it.
Posted on Jul 21, 2011
Paragon model 8141-00 defrost timer wont turn.
Is this a used timer?
8141-00 is 120 volt timer.
Is your 120 volt Hot wire on terminal 3 and Neutral on terminal X?
Test across 3 and x for 120 volt.
http://waterheatertimer.org/Paragon-timers-and-manuals.html#defrost
Don't buy used defrost timers... they always look good when you inspect, but never work when connected... that's why the timer was taken out of service and sold as used timer.
Save the old trippers for use on new timer.
Gene
Water Heater Timers Save Money
Mar 28, 2015 | Paragon Hardware & Accessories
I have the Paragon 4001-00 timer. The timer seems to be working okay as far as time and trippers are tripping however it doesnt seem to be engaging our secutiy door lock for the night. Could the conrt
Does the manual override lever move back and forth as trippers pass? If NO, then trippers are bad
http://waterheatertimer.org/Paragon-timers-and-manuals.html#4000
http://www.amazon.com/dp/B00441YVCO/?tag=waterheaterti-20
120 Volt timer.
When timer is ON, test across terminals 2 and 3 for 120 Volt
If 2 and 3 show 120 volt, then timer is delivering power on schedule. Look for loose connections. Loose wire nuts.
If 2 and 3 do not show 120 Volt, then timer has failed.
Suggest buy T101 as replacement for durability and generic replacement parts.
http://waterheatertimer.org/Buy-T100-series-timers.html
Crossover wiring from Paragon 4001-00 to Intermatic T101
Paragon 1 to Intermatic 1, Paragon 2 to Intermatic 2, paragon 3 to Intermatic A
Nov 05, 2014 | Paragon 4001-00 24-hr Timer Control 120v...
Looking for set of trippers for paragon 4014-20 pool timer
Copy following link to identify timer:
Paragon 4000 series uses X2772 tripper
Paragon is no longer making timers except for defrost times.
There is a new line of timers coming from China that looks identical to Paragon 4000, and uses same tripper. As a result this timer design and trippers could be around for years to come.
Replacement timer is Intermatic T104R 240Volt indoor outdoor enclosure, with replacement parts widely available
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html#T104
Add a comment
Apr 03, 2013 | Paragon Amf 7008-00 Timer 7 Day 120 Volt...
Need trippers for older unknown model number amf paragon pool timer. timer is 15 - 20 years old
Jul 21, 2011 | Paragon Amf 7008-00 Timer 7 Day 120 Volt...
Hardware & Accessories Logo
Top Paragon Hardware & Accessories Experts
Gene Haynes
Steve
jdthefixer
Are you a Paragon Hardware and Accessory Expert? Answer questions, earn points and help others
