Merry chef e4 won't work message says wrong device I'd,. On display
E4 message on toastmaster pressure cookerwhat am I doing wrong have used p cooker before and it worked fine
Instruction manual below states:
The LED display shows E4 error.
Unplug the power cord from the wall outlet. Wait approximately 15 minutes. Plug the power cord back into the wall outlet. Press "CANCEL" button on the pressure cooker. Select cooking process to begin cooking. If problem persists, contact customer service at (800) 365-6133 ext. 120/107/105 for a replacement thermofuse.
http://www.qvc.com/footers/cd/pdf/K44020_OwnersManual.pdf
Feb 22, 2018 | Home
Magic chef error E4
E4 indicates the washer failed to drain out after 4 minutes, after that time the code is set. Check and clean the drain filter first.
Jan 19, 2017 | Magic Chef Washing Machines
Yes, where & what is the internal rubber ring on a Magic Chef 2.1 cubic ft. Portable Washer?
Go www.repairclinic.com and enter model. You will be presented with a list of common replacement parts and may be able to view a video that shows disassembly.
Aug 02, 2016 | Magic Chef Washing Machines
Control says E4 and is not cooling
E4" on display for lower zone - error of DC electric fan for lower zone.
If any of above errors happens, please contact Customer Service Dept. for further assistance. Do not attempt to repair it yourself.
For Service or Assistance please call 888 775- 0202. Or visit us on the web at www.mcappliance.com to request warranty service. Your unit has a one year warranty from date of purchase. Hope this helps you. Jim
Feb 12, 2011 | Magic Chef MCWC44DZ Wine Cooler
The refrigerator just stopped working. After looking at some complaint boards on the ewb it could very well be the compressor
compressors work for a long time the first device to check is the thermostat this is the most common fault in fridge units that are not turning on ( kicking in )
best of luck merry christmas
Dec 08, 2010 | Magic Chef MCWC30MCG Compact Wine Cooler
Error message e4 54040990
It may mean that the disk is no longer usable due to scratches or other over-use reasons. If a new disk, it may mean you're using the wrong brand. This machine works on recommended brands, and the brand of DVD+RW that has proven to be workable on this device, and that I use with no problems, is VERBATIM. Hope this helps you solve what's wrong.
Mar 22, 2010 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Singer Futura 350
Dear Wendy,
The E4, error message means the safety device is activated. Machine is locked up due to thread entangled with the bobbin case. Remove the needle plate and bobbin case. Check for any thread around the hook area. Also check your handwheel. It should turn freely. Good Luck
Jan 11, 2009 | Singer CE-200 Quantum Futura Computerized...
Error message E4
All sewing machines are 'picky' about being threaded correctly. As you seem to understand. There is no shame in asking the seller for help.
Jan 23, 2018 | Singer CE350
Canon MP 145 ink reset
If i am not mistaken error E4 is printer has NO INK. Check the cartridges first.
Jul 25, 2008 | Canon PIXMA MP150 All-In-One InkJet...
Heating & Cooling Logo
26 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
