Question about The Office Equipment & Supplies
My machine is stuck in the 'start a run mode. Every time I hit enter to start, an error code pops up which says 'take label'.I have powered off, reset and cleaned the glass lense which reads the tag.
  • 25 Answers
SOURCE: KItchen Aid Dishwasher KUDI01FL Stopped Running and Will not Start
try the reset button sequence i posted in the other question..
Posted on Jan 24, 2009
SOURCE: to enter service mode on biz hub c 500 what is the key order?
Lost my access to add employee name to scan docs Biz 500/420
Posted on Jan 30, 2009
  • 188 Answers
SOURCE: ''Clean'' light is blinking, ''Cancel'' does not reset the cycle.
If the clean light flashes 7 times, pauses, then repeats...
When the dishwasher doesn't sense a water temperature increase, it stops working and locks the functions (clean light flashes 7 times, all buttons are non responsive). It does this as a safety in case the element is broken and feeding electrical current into the water.
To resolve this you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
...all the lights will turn on briefly and the machine will start a diagnostic cycle. You can press cancel or let the diagnostic cyle finish (1-2 minutes).
You should now be able to run the dishwasher as normal.
If the issue returns, you could have a problem with the heating circuit (ie. element, thermostat or wiring).
It rarely happens but it could also be the door switch not engaging properly when the door is closed (slightly bend the door latch down making sure it doesn't hit the door when you close it).
Posted on Apr 01, 2009
praky16
  • 744 Answers
SOURCE: my camera lense is stuck and my camera wont turn on
hi...The transmission system that moves the lens in and out has a problem with it's gears. There is most likely a gear or an actuator that has fallen out of alignment and is getting stuck at a certain point as the lens comes in/out.There is some disturbacnce of the lens arrangement that is preventing the lens from coming in/out.Any of these symptoms above could trigger the camera to shut itself off to protect itself from further damage.
thank u
rate me!!!
Posted on Jul 28, 2009
rylee_smith
  • 8619 Answers
SOURCE: clean button is flashing
Hi
Thanks for using FixYa. If the clean light flashes, pauses, and then repeats. When the dishwasher doesn't sense a water temperature increase, it stops working and locks the functions (clean light flashes, all buttons are non responsive). It does this as a safety in case the element is broken and feeding electrical current into the water.
-high temp wash
-heated dry
-high temp wash
-heated dry
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Jun 02, 2010
Call for service C413 toshiba estudio 2006
Here is the verbage for the error code at this link
http://printcopy.info/?l=en&mod=erc&brand=Toshiba&model=e-Studio%202006&code=C413
In the interim you may try the following one time to see if it is a false error... Hold "0" and "8" while turning on machine.....continue holding until machine enters service mode. Enter "400" press enter. Enter "0" press enter. Power off / on. If code returns, machine needs parts replaced. Contact your Toshiba technician (there should be an 800 number label on the unit for service. Do Not keep resetting, may cause damage to Fuser Unit.
Aug 11, 2016 | Toshiba Office Equipment & Supplies
Reset Error codes
E000001-0002 refers to the fuser assy either getting to hot or not hot enough. Fuser error codes cannot be reset by power cycling the machine even though that is what the display tells you to do. In order to reset the fuser error code you must enter the service mode & reset the code. To enter the service mode:
press"Additional Functions" button (looks like a picture of a head with a star inside)
press the #2 and #8 at the same time (simultaneousley)
press "additional functions" again
The display should show a choice of
copier,feeder,sorter,fax,or board service modes
Select copier
select clear
select ERR
press OK
Turn power off & back on.
After clearing error stay at the machine to see if it comes to ready. The fuser assy can reach 139 degrees C.(Water boils @ 100C) The error can only be cleared through the service mode because a technician should inspect the fuser to verify there is nothing faulty that could possibly start a fire. If you enter the service mode & clear the error, power cycle the machine & during warm up the machine throws a code again- turn it off, unplug it & call a tech for fuser repair.
Jul 02, 2008 | Canon imageRUNNER 3300 All-In-One Laser...
Error code E000002
That is the error code for a power supply failure or the printer not receiving enough power to heat the fusilier to print. This can be due to an power outage or not enough electricity flowing into the machine.
If the machine is receiving full power, you'll need to get rid this error through entering service mode.
1. Hit "additional functions" key on the printer's keypad.
2. Press and hold 2 & 8 at the same time for one second.
3. Hit additional functions key again.
NOTE: from this point forward you'll be in service mode which has a 60 operational second window. After 60 seconds it will exit out of this mode and you'll have to start over.
4. You've entered service mode. Now hit "copier"
5. "Function" key
6. "Clear"
7. "Err" . There should be an error or the error code in this section select this part.
8. Hit "ok"
9. Restart the printer by switching off the physical black power switch on the side and switching it back on.
The printer should restart and be working normally.
Feb 21, 2016 | Office Equipment & Supplies
I am getting error code E000001-0002 in my IMAGE COPPIER 3545.... how to solve it
press the #2 and #8 at the same time (simultaneously)
Select copier
select clear
select ERR
press OK
****IMPORTANT****
After clearing error stay at the machine to see if it comes to ready. The fuser assy can reach 139 degrees C.(Water boils at 100C) The error can only be cleared through the service mode because a technician should inspect the fuser to verify there is nothing faulty that could possibly start a fire. If you enter the service mode & clear the error, power cycle the machine & during warm up the machine throws a code again- turn it off, unplug it & call a tech for fuser repair.
Dec 20, 2014 | Canon CANNON IR 3530 COPIER FOR 220 VOLTS...
KEOCERA MITA photocopier KM4035 have problem. My Machine is showing error code C6000. How to tackle this proble. Please help me as soon as possible.
KM/CS 2530, 3530, 4030, 3035, 4035, 5035
C6400 is a fixing unit error.
To reset -
Try this, enter "10871087" from keypad, You should now be in maintenance mode.
Enter "163"press "Start / Print" key.
You should see a screen that says "Execute".
Press EXCUTE on the touch panel. It is displayed in reverse.
Press "Start / Print key.
The machine will turn off and then back on then come back to ready. If not then you need to replace the fixing unit.
I hope this is helpful,
Feb 02, 2011 | Kyocera Mita KM-4035 Printer
Stirling XQG65-908E E11 error clothes stuck in machine. Machine is lock and clothes are inside
Buttons:
Pre-Wash = K1
Delay = K2
Temp = K3
Spin Speed = K4
Add Garment = K5
Extra Rinse = K6 1. Press K3, K5, K3, K5 in 30 seconds after power on to enter serve mode(txx selection mode). The display will show t01.
2. Press K1 or K2, it will change from t01 to t12.
3. Press "start/pause" key to enter txx measure mode. Run txx after"start/pause" key. You can go back to txx selection mode if press "start/pause"key.
b. t02:Show fault code test
Press K1, K2 can see all record fault code EXX after enter t02. You can cleanupthe fault code per hold K2 for 3 seconds. If error code 11 does not go away after doing the above 3 times, then theremay be something wrong with the inlet valve, drain pump or PCB.
Jan 16, 2011 | Washing Machines
Ir6000 error code e246-0002
Select copier
select clear
select ERR
press OK
****IMPORTANT****
Jan 11, 2011 | Canon Office Equipment & Supplies
Error code H 4 on Sharp AL 1041 copier
H4 is a fuser error. It sometimes can be cleared out. But sometimes it is the fuser lamp or one of the heat sensors.
Try to clear the error in service mode by hitting. clear, auto(exposure), clear, auto. The display will go blank, enter 14 and hit start key, turn power off/on, if problem is gone then you overheated, if not then you need a tech. Good luck.
Jun 14, 2008 | Sharp Office Equipment & Supplies
Canon 850 E001 Error
this is an problem in fixing heater unit open the door turn it on press 2 and 8 at the same time than press copier then function then clear then error the ok after that all turn it off again if it doesn't work u have a problem maybe a heater lamp a thermistor
Mar 26, 2008 | Office Equipment & Supplies
Canon D861 copier
Garner,,, the C000 code is a fuser error code on this machine. It can "sometimes" pop up after a power surge/spike/loss event, and needs to be reset in service technician mode. If it doesn't reset, but rather comes back, you probably need a sevice call for something defective in the fuser (lamp, fuse, thermister).
IF YOU'RE GAME, here it is...
To enter service simulation: press"Additional Functions" to enter "User mode". Press # key. Press </> to select a menu item. enter new data using number keys. Press "Set/OK" key. Press Stop/additional functions to exit.
Note: To reset E000, E001, E002, E003, go to service mode 4. select SET, go to "#7 PRINT-ER," in service mode. Then press Execute "#4 PRINTER RESET."  Power the unit off/on.
Oct 11, 2007 | Office Equipment & Supplies
26 people viewed this question
Top The Office Equipment & Supplies Experts
Gareth Cockram
Gareth Cockram
Tygh Duval
Tygh Duval
Jerry Greenberg
Jerry Greenberg
Are you a The Office Equipment and Supply Expert? Answer questions, earn points and help others
