Speaker switch not working - Audio Players & Recorders
No sound from speaker but through ear piece I get sound.
Many devices will automatically switch off the large speaker when ear phones are plugged into them. Also there may be a switch or button or prompt on your radio to switch between regular speaker and ear phone jack. Look for that first.
Try connecting and disconnection ear phones while listening to a station and see if the problem is intermittent. If is works sometimes but not every time then it is most likely an internal connection.
You will have to access the inside of the radio to investigate further. Connect a working external music or sound source with speaker wire to the terminals inside the radio that connect to the radio's speaker. If the radio's speaker works with the external sound source then you know it is a bad connection inside your radio. If the radio's speaker does not work with the external sound source then it is most likely a faulty radio speaker. Look closely for a broken solder point or broken/disconnected wire.
Sep 10, 2013 | Eton E100 SW/FM/AM Radio
My center speaker connection is faulty?
There should be some fault to internal output circuit.
May 11, 2013 | Philips Audio Players & Recorders
Altec lansing vs4121 speaker boom sound
you may have blown out the speaker or there is a miscommunication between the laptop and the woofer
Jun 15, 2012 | Altec Lansing VS4121 Speaker
I only use the pa doesn't always work.mic prob?when i switch to cb-no prob.
What type of PA speaker are you using? what OHM? and wattage.. A cb pa can only supply MAX 5watts into a pa speaker. It may be too big of speaker or bad speaker? if it works on cb.. wrong OHMS can make problems too..
Nov 15, 2011 | Radio Shack TRC-447 CB Radio
RIght speaker not working in speaker system. Switching the left with right speaker make the right speaker work (not speaker) Plugging the 2 RCA into a different input changes nothing. 2 rear speakers...
Let's name the product and use FM for troubleshooting. Are you saying you have the Right Front and both rear amp channels/speakers not working? What DOES work?
Jan 17, 2011 | JVC Audio Players & Recorders
Cobra 29LTD speaker inop....No audio at all. Speaker Ohms out ok as do speaker leads from board to speaker. External speaker jack is inop. PA works in PA and CB modes. Other than speaker issues, radio...
There are some different things you could be facing like:
the speaker sound being cut-out by the mic switch, but my first guess is the switch in the external spkr. jack being faulty. Here is a schematic for you.
Apr 12, 2010 | Cobra 29 LTD CB Radio
B speaker doesnot get on.
apply a good contact cleaner in this button and press it many times.confirm good connection between amplifier output and speaker b.connect speaker A insted of speaker B if it is working the problem will be in cabel and speaker B if not the problem in your amp output stage.
Mar 08, 2008 | Yamaha DSP-AX1 10-Channel Amplifier
Audiofonics amp
Reconnect one speaker per channel and swap the RCA cables (L > R and R > L) to see if the working channel switches sides. If not, move all switches and controls to see if any are intermittent.
Jan 10, 2008 | Audiofonics ADF-241 Car Audio Amplifier
Only one surround back speaker works
It sounds to me like one of your speakers may be mis-wired. Try reversing the speaker wire (don't switch right-for left, but switch negative for positive) and see if that changes anything.
Dec 31, 2007 | Onkyo HT-SR800 System
No sound comes out of the speaker. The volume settings are correct. The sound is on, and the volume is all the way up. What can I do?
Your problem can be one of several. 1/ you have lost / deleted / corrupted the voices on your SD card. if there are no voices then you won't get any nav instructions. 2/ Your speaker has stopped working , if faulty it will need replacement. ( not unknown and common on early tomtoms ) . On other tomtom models that have an external speaker socket the socket becomes faulty. This socket has a switch that switches the internal speaker OFF when an external speaker is plugged in. If this switch is stuck OPEN then that connection to the internal speaker is lost. However , the Tomtom drums sound is connected to the speaker via a different route so doesnt get switched off by this socket switch so the drums can still be heard.
Dec 25, 2007 | Tomtom GO 300 GPS Receiver
27 people viewed this question
