Question about Dryers
Dpsb620gc4ww relay on control board not engaging to deliver power to dryer motor
I bought a tech manual and through the diagnosis it would appear that I am not getting power through the relay on the control board to the dryer motor. Trying to find the part online and whether I could actually just replace the relay on the board
  • 159 Answers
SOURCE: Kenmore Elite Oasis Dryer top removal
there should be 2 clips you kind of press and then it should pull off. if not look to see if there is a leg that also go's into the bord if so you need to move it in to reles it from the bord and then it should pull off.
Posted on Aug 10, 2007
SOURCE: Vizio P42HDTV Power on Diagnosis
Please check the U29 8 pin little surface mount mosfet it has this letters > FDS4935 > > In this part inputs 13.2 volts which is ok for the near 12 vdc but it > outputs 1.250 vdc i am 100% sure that this is all the problem > > check it out, and tell me if you´re agree with me > > On this output pin it feeds the audio Ic, the 7809 and the tuner side board > which needs de 12vdc too and its getting only the 5vdc part > > what do ya think?? > > Richard
Posted on Apr 13, 2008
SOURCE: Maytag Washer/Dryer stackable
well i am having about the same problem, but mine won't even fill, the dryer works but the washer won't fill or turn on at all. my husband had it all apart, too the control assembly to parts place and they said that hardly ever goes bad so it is still sitting unusable with no answer or money to spend on it in site.
Posted on Jul 24, 2008
tzweeb
  • 318 Answers
SOURCE: Maytag Neptune MAH5500BWW Will not spin
maytag neptune washers do have a motor problem and they have a kit to replace the motor and motor controller.
when the motor fails, it wont wash or spin. most units have a 5 year parts warranty and should be replaced with a free part, but you will have to pay an authorized servicer to do this.
if it is over 5 years then i would call maytag and see if they will help you with an authorization for repair.
most of the time they will provide the part for free. just call the 800 # and ask for help. they wont send you the part but might give you some help with the parts.
Posted on Jan 06, 2009
  • 5 Answers
SOURCE: 2001 f250 won't shift into 4wd high using the dash
you can use a test light to see if you are getting power to your shift actuator by unplugging actuator and testing for power at your wires while someone activates your switch,if you have power then should be a bad actuator.
Posted on Feb 25, 2009
I have Bosch model WFB 4000 washing machine. If I start machine in any mode, after going through washing cycle. It stops without draining water.I need help to fix the problem
Some machines have a setting for "drip dry" which stops the drain cycle after rinsing. Check for the wrong setting and hope that is all that is the matter. Use the manual to find out about your model.
You say it stops after washing cycle. Please confirm you mean washing cycle and not rinse cycle (makes a difference to the diagnosis)
Otherwise it could be a pump problem, and that is likely to be (in order) pump motor failed, bad/broken electrical connection to pump motor (an easy fix), controller board relay* failure, other** control board failure.
* It used to be all motors were controlled by electro-mechanical relays, which were in turn actuated by the control board. These days solid state relays are often used. If it is either one of these, an electronics technician will likely be of more use than a washing machine technician because he or she stands a chance of fixing the board rather than replacing the whole thing.
** New board called for. That is a washing machine tech job as an E-tech will find it harder to source the relevant part, and a board fix other than relays is unlikely to be economic.
Dec 28, 2017 | Bosch Washing Machines
Kenmore Dryer 110.61066000 control panel is on, but just gives a
2 options.
1. your belt broke and the microswitch on the idler pulley is not being depressed therefor the motor will get power. This is easy to diagnose. Open the door and try turning the drum by hand. If it spins with little to no resistance then you need a new belt. If it spins but has resistance then you don't.
2. The motor relay on the control board is bad. The control will run through diagnostics and can appear fine even if this relay is bad.
Nov 15, 2012 | Kenmore Dryers
My samsung fronload dryer will not spin. There is no error code. Someone came out and told me that I need a belt. The belt was replaced but the tech now says he
see this causes and fix it. God bless you
Belt
The belt may have come off or broke. If you hear the motor running but nothings moving the problem is likely the belt. This is easy to check and replace. .
Door Switch
This can cause the washer to not agitate or go into the spin cycle. You will need to remove the door switch to check it. You will perform an ohm reading on the bottom terminals. The reading varies from manufacturers most Frigidaires is around 1500 ohms others like the whirlpool duet is checked at the main control board with the door closed should be around zero ohms. You will need to refer to the tech sheet or service manual for the proper reading.
Main Control Module / CCU
The main control unit is the circuit board located behind the console. If the door switch tests good the main control is usually the problem. Check all connections for a goood tight fit. You will need to refer to the tech sheet or service manual to check this further. The main control is easy to replace
Motor Control Module
The motor Control Module is located inside the cabinet down near the motor. This recieves the signals from the main control module then relays this information to the motor. Check all connections sometimes a communcation problem is just a loose connection. The Motor Control Module is esasy to replace .. To check this further you will need to refer to your tech sheet or service manual.
Oct 17, 2012 | Dryers
Dryer will not start. Start control engages solenoid and holds contacts closed, but nothing else happens. Solenoid disengages when door is opened and light does come on. Wiring contacts all appear tight...
Check for power through the soleniod... if power is going to the motor and it is not running then the motor is shot...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
May 14, 2011 | Kenmore 63942 Dryer
Kenmore elite dryer 11063942101 works if I force the switch to stay in the on position but won't start by just pressing the switch. Replaced pust-to-start switch. Same problem. Vacuuming out the areas...
The problem is definitely not the motor but rather the motor relay or the electronic control. Either the motor relay is not working to close the motor circuit or the electronic control is not powering up the motor relay to serve its function.
The motor relay and the heater relay are identical and can be used interchangeably. The heater relay may be used in place of the motor relay if the dryer heats up when the start switch is held on. It indicates that the heater relay is working.
Disconnect power to the dryer then pull the end cap trims off then remove the control panel securing screws. Once the screws are removed, rotate the control panel up to the rear of the dryer.
Disconnect the wires and remove the relays then put each in the place of the other. Refer to the component layout diagram for the location of the relays.
Reconnect the wires then rotate the control panel down back into position then plug the dryer in and start it. The dryer should start and continue to run when the start switch is released since the working heater relay is used but will not heat up indicating that the motor relay is not working. Otherwise the fault is in the electronic control.
Replace the faulty component and it should address the problem. The relay (heater/motor) is part number
3405281 and the electronic control is part number W10116565.
Squeeze on the electronic control mounting bracket as shown then pull the board up to remove.
Insert the new control board and gently press it down into position. Transfer the wires from the old board to the new board one at a time.
Simply unscrew the relay to be replaced then secure the new one into position and transfer the wires.
Rotate the control panel down and secure it back into position to complete the repair.
Aug 30, 2010 | Dryers
Dryers stops after 30 seconds of running.
#5 post_old.gif September 24th, 2009, 08:49 AM jake.gif?dateline=1263924303 Jake user_offline.gif Appliance Tech - Admin Join Date: Aug 2004 Location: Springfield, Oregon Posts: 32,822 Thanks: 48 Thanked 1,244 Times in 1,238 Posts reputation_pos.gifreputation_pos.gifreputation_pos.gifreputation_pos.gifreputation_pos.gifreputation_highpos.gifreputation_highpos.gifreputation_highpos.gif icon1.gif So you need the motor control board #17 here?
http://c.searspartsdirect.com/lis_pn...2059-00001.png
Here's the motor control board for your model:
Manufacturer's Number: 8544799
Jun 30, 2010 | Kenmore Elite Oasis 7808 Gas Dryer
When i start dryer it does not start . 88 appears in the display
This is indicating an error in the motor relay area.
Try powering off the AC to the machine and let it stand for 30 mins. Then reconnect the power to see if the error persists.
If it does then
Check:
· relay coil
· wire harnessand the control board
Unfortunately to repair this you will have to replace the whole control board.
Nov 10, 2009 | Maytag Neptune MDE5500AY Electric Dryer
There is a start relay on the computer control board. You probably hear a very dull click. That click is the relay on the computer board trying to engage, but it won't and therefore your dryer won't spin and your board sends a beep and perhaps an "E11" error code to the LED display (Not sure on Kenmores.).
In plain english, you have a bad control board now and will have to replace it. Cost about $130.
Dec 15, 2008 | Kenmore Elite HE4 Electric Dryer
Roper REX4634KQ
That should be just a push to start switch. The start switch is inside the motor. When the motor turns fast enough it trips an internal switch to keep the motor running. It sounds like you have a motor on the way out.
Apr 24, 2008 | Roper REX4634KQ Electric Dryer
Dryers Logo
41 people viewed this question
Top Dryers Experts
