I have a bernina 430 aurora that worked very well for 5 years without any problem. Lately It has some kind of electric problem that my dealer's mechanic cannot figure out.
Sometimes I turn it on and it's not working. No light, nothing. Other times it's fine until after some time of sewing, it shuts off again, as if there's some kind of loose connection. I push the switch, unplug and plug it back on again but nothing happens. After a while, it will start working again. Light comes back on, as if nothing has happened. Took it to a mechanic three times. He sais it's working fine without any interruption. Could anybody help me to figure what it could be?
SOURCE: Power light flashing/ no picture
I have the same problem. The only way to get the TV to come on is to unplug it, but once you get it back on it turns itself off again in a few minutes.
Posted on Jul 19, 2007
  • 239 Answers
SOURCE: Dell 5150 - solid amber light at the switch.
Make sure the 12v power connector is securely connected to the system board. If you open up your computer look at the end of the board that the memory modules are there is a 4 pin connector thats the 12 v Make sure thats plugged in and secure, If thats ok you have already did the removal of the memory and replaced them, take out any pci express cards and use your onboard video, if that don't work try one memory module at a time see if that works you already seem to be savoy enough to do that and try that, and if that does not work you may need a new power supply. You can check it but probally will be bad I have the same desktop and thats been a problem with these 5150 along with the mother board going out after the warranty expires. I sure Hope this helps you out,, Happy Holidays to you and yours. Hey If you need me to look anything else up let me know. Thanks again bear001
Posted on Dec 15, 2007
daniel719
  • 240 Answers
SOURCE: TV turns itself on and off, Green light blinks
lamp and thermistor needs replacing.
Posted on Jan 14, 2009
leecom72
  • 4806 Answers
SOURCE: Acer Aspire One Zg5 will not boot up no indicator light come one
Hi there.
Try taking the battery out and booting it on AC power only, if it boots up turn it back off and reinsert the battery, turn the computer on, if it boots up all good, if not please post back.
Good luck
Posted on May 21, 2009
  • 6982 Answers
SOURCE: turn the key and nothing happens,no crank,no sound,no start
It seems that you have a loose wire, bad connector or perhaps the main computer itself that is causing a problem If the shop is not seeing any codes, or codes come and go, likely I'm right...but someone is going to have to actually do some intensive testing to find the real cause. You can likely get another computer from a local scrapyard far cheaper than what the dealer will charge you...as far as wiring, you need a good accurate schematic a good volt/ohmeter and lots of time to trace wiring. When checking connectors test the pin, then probe the wire going into the pin...often the problem is where a wire meets the backside of the pin, either corroding or breaking..This also applies to any modules such as the security system...what you see on the dash does not always tell you that connection to components is good. This is not a "fix, but rather, a direction to go in. (exactly what I"d need to do if I was there)
Right now, everything is suspect including fuel system, till you rule it out!!!
Posted on Jun 05, 2009
Rick beament
I have been fixing Bernina's for 46 years and would not try to repair a board. Just saying. BERNINA has a replacement charge and gives credit for return of core and at a reasonable cost. ($150-250) Be sure you are dealing with a reputable BERNINA dealer
Jun 29, 2014 | Bernina Sewing Machines
Touch screen not working on new Bernina 560
Sometimes the touch screens can get accidentally re-calibrated incorrectly, and then will not work. It could also be a electrical defect, though this is rare with BERNINA products. I would recommend taking your machine back to the store that you bought it from to have it repaired. BERNINA machines come with a 5 year electronics warranty in the United States, so if it does happen to be an electrical defect, as long as your registered your warranty, this should be covered. If it is anything else, a BERNINA dealer should be able to re-calibrate or repair it fairly easily.
You can find a nearby BERNINA dealer at the attached link.
Find Dealer easily find your nearest BERNINA dealer BERNINA
May 08, 2014 | Bernina Sewing Machines
430 aurora
Probably too thick to feed without dislodging the bobbin case, causing the error message.
May 07, 2013 | Bernina Activa 140
I get an electrical tingle from metalwork on Bernina Aurora 430. They say this is common and not a problem. That doesn't sound like a good answer!
It's NOT a good answer!! Sounds to me like you have an short in the wiring. Unplug the machine and check all the wiring connections. Replace any frayed wires and make sure the connections are solid.
Robbie
Jul 27, 2010 | Bernina Activa 140
Bernina aurora 430 calibration problem
The complete manual is available at:
http://www.bernina.com/en-US/SupportData/BERNINA-Nah-und-Stickmaschinen/aurora/Manuals/032907-52-04_1103_a430_a440_a450_EN
A reset can be done as follows:
press the clr button. The altered stitches will be set to basic when you turn the machine off
May 21, 2017 | Bernina Artista 180
Aurora 430 Bernina
Hi, possibly your feedogs are dropped and in the darning position and/or its thinking you want to embroider and there is NO hoop attached or entire embroidery unit plugged in. Check your feedog button below the handwheel on the bottom.
Rick
Jul 29, 2009 | Bernina Sewing Machines
Bernina Aurora 430 utomatic button hole
Take it to your local bernina dealer and have them calibrate the buttonhole foot along with the speed control.
Jun 07, 2009 | Bernina Artista 180
I have a Bernina Aurora 430 (not on your list). For some reason, the feed dogs have dropped. The button that usually drops them isn't working.
If you remove the metal plate on the bottom of your machine, you can see the workings of the feed dog raise and lower button. With some luck it just might be a screw that came out or it might be a broken spring inside the sewing arm.
Without a service manual or a view of what it should look like inside when it is functioning correctly, at best you would just be guessing. It should be a simple 5 min fix but it is best to take it to a Bernina dealer for proper repair. Good luck, bushvideo
Aug 17, 2008 | Bernina Artista 180
Bernina Aurora 430
I figured out the solution for this issue. It all has to do with the threading. And I mean literally follow the instructions word for word. Most importantly is the Bobbin thread. make sure to thread the bobbin through the case eyelet.
Jan 11, 2008 | Sewing Machines
Televison & Video Logo
26 people viewed this question
Top Televison & Video Experts
