Question about Poulan Garden
Poulan continually throwing drive belt
Tried new belt on mower main drive belt shifter goes from 3rd to 6th gear when clutch belt poops off.
    Top Expert:
  • Poulan Master
  • 48,229 Answers
Adjust the belt tensioner properly
check that the pulleys are in alignment
Posted on Apr 16, 2017
Poulan PO17542LT riding mower, the main drive belt broke and I am trying to replace it. However, everytime that I put the belt back on I get a terrible vibration from the belt and then it pops off.
Check to see if one (or more) of the pulleys are bent. Also check the engine drive pulley to see if it is bent.
Does the vibration happen if the clutch is engaged or released?
May 02, 2017 | Poulan Garden
Clutch noise
You got it, Bad throw out bearing!
Apr 17, 2014 | 1993 Chevrolet Corvette
Poulan xt 12530 lt with grabby clutch
there should be a adjustment rod from the pedal to the tension pulley
Apr 23, 2012 | Poulan Garden
Hi my rx8 is makin a grinding noise from the gearbox and the noise goes away wen foot is pressed on the clutch makes a noise wen drivin in 1st 2nd 3rd n 4th gear noise goes in 5th and the noise is there in...
What?! Really! The noise goes when the clutch pedal is depressed! So the noise goes when the release bearing (throw-out bearing) is engage? So how would that be a release bearing/clutch problem? If it didn't make a noise until the clutch pedal was depressed, it would be the release bearing! In other words its the input shaft bearing and/or counter shaft bearing in the gearbox. Stop giving people bad advice
Mar 11, 2011 | 2004 Mazda RX-8
Put new belt on ground drive, but gear shifter only goes to 2nd gear as it is pushing against the new belt. Should the gear shifter be against the belt? Does the clutch tension pulley need to be adjusted?...
No it should not be against the gear shifter look over and try to rearrange.You may have to turn a bolt or two.Thanks for asking and I hope this helps out.Please leave me 4 thumbs up.
Jul 13, 2010 | Poulan 38-Inch Steel Deck 15.5 HP Briggs &...
My Poulan 13.5 hp runs until cluch is released
remove the drive belts from the motor. if it runs ok check your pulleys. one of them might be siezed.if it still dies chk the safety switch on the gear selecter and deck engage lever.
Sep 25, 2009 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Replacing the Drive Belt on a Poulan Riding Mower
Without an impact, it's will be more difficult. The only way to get back-up on the bolt is to remove the screen over the flywheel on top and put a socket on the flywheel nut
May 28, 2009 | Poulan Garden
Shifter seems to have shifted
just ram the shifter in your booty,.....duh
Dec 31, 2008 | 2003 Toyota Celica
Garden Logo
37 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
