All of a sudden my dvd player reads bad disc format what can i do
SOURCE: Bad Disc
First determine where the problem lies. This can be done by analyzing what is happening. Is the disc spinning. Is it spinning erratically? If the disc is not spinning, the spin motor is probably defective. But sometimes you can be fooled, if the laser does not detect information of the disc, it will not issue a start spin motor command. If you can get the unit to work with the door open by defeating the switches,(Do not under any circumstances look directly into the laser)If you see the laser then the spin motor is bad, In either case the unit is is probably cheaper to replace than to repair. Scrivitron
Posted on Jun 20, 2007
SOURCE: Bad disc message
Did you try cleaning the eye i have had dvds that would not play because the eye was dirty
Posted on Mar 10, 2008
praky16
  • 744 Answers
SOURCE: Toshiba SD-K770 DVD player flashes error and BAD DISC
hi... the problem might be in ur dvd... If ur dvd is perfect and u found that ur player has some problem means the best solution is that to clean up ur dvd player lense which plays a vital role in reading ur dvd when u insert into it...For cleaning up ur lense all u need is a lense cleaner dvd available in electronic shops.. u can purchase it and play that dvd as normal one.. ur problem will get solved..
thank u rate me!!!
Posted on Feb 07, 2009
  • 10 Answers
SOURCE: vm9212n in-dash dvd player won't load cd's or
Must reset lazer lens manually. Most of the time this does the trick. hope this helps you
Posted on Jul 01, 2009
  • 25 Answers
SOURCE: DVD Player stops reading disc Error message :
usually this happens when lens cannot read the the disc. Due to few reason 1 Your disk is scratched 2 Your DVD lens is covered with dust 3 You need to replace DVD lens
Try another few CD/DVD to rectify whether there is any problem with dvd you are trying to play
if this error occurs on all the dvd you played then the most likely proble is with your DVD lens either its coverd with dust use Disk cleaner if not you got to replace a new DVD lense as per model
Posted on Feb 18, 2010
Player reads DVD as bad
Are you using the correct format disc.If you are playing a blu ray disc in a non blu ray player the player will not read the disc
Jan 02, 2018 | Durabrand Audio Players & Recorders
Blaupunkt tv/dvd...dvd is not reading the disc
Most likely the disc is badly scratched or is a format not compatible to the player. Commercial DVD? Or home-burned DVD-R? They are totally different formats. DVDs can be made using many different audio and video CODECS. Players are designed with support for specific CODECS and will not recognize others.
Dec 26, 2013 | Car Audio & Video
My dvd player won't play dvd
likely if cannot read disc, or no disc or error, that unit has either dirty or bad optical pickup.
May 14, 2012 | Televison & Video
My dvd player ejects the cd when i load it
Either the reading head on the laser is dirty or bad and it is not recognizing the CD. If it is a homemade CD there might be a formatting problem that is not compatible with your player
Apr 17, 2011 | Televison & Video
My Dvd player will not format discs
If it is a DVD player, not a recorder, then it is not meant to format discs. DVD players are strictly playback only; they can only read and play discs; they cannot be formatted or recorded in any DVD player.
Apr 06, 2011 | Toshiba Televison & Video
Can not read dvd format
The player uses a different laser to read dvd's in respect to cd's. Either there's dust on the laser (or lens) and it needs cleaning or the dvd laser unit is busted - it can't be fixed, junk it and buy a new one.
Nov 30, 2009 | Hyundai Televison & Video
Hitachi dvd player not reading all dvds
Hello, I'm here try and help your problem, first older DVD players only read certain disc formats, If you have your owners manuel to your DVD player it will tell you what types of discs the DVD player will play. There are seneral types of burnable disc's DVD -, DVD +, DVD-R, DVD+R, DVD-RW, DVD+RW, please looking in the owners manual for the types of discs that the player will read, also in the same secton it will tell the types of formats that it will read DVD Video, DVD ROM, and there is a few others, Next is when you burn DVD's the type of burner you have makes a difference. You will need to find out what format your DVD burn, burns to disc, some of the newer DVD players
read alot of the formats. I would start by finding out what your DVD burns first, then I would suggest buying a DVD player that will read that format. If you have anyother questions please feel free to post them, Thank You and have a great day.
Jan 14, 2009 | Televison & Video
DVD player does not read DVD-r format disc
have you use a dvd-r format before? somes dvd dosent run in that format, but if yes then dont spend too much money in it becouses is a low cost one, try cleaning it with a cleaning cd, if is a bad chip(Ic) or the reading unit any way wll cost you a lot to repair and thats no bussines....good luck
Aug 06, 2006 | Panasonic PVD4744 DVD Player/VCR
DVD does not read DVD-r format disc
Televison & Video Logo
27 people viewed this question
Top Televison & Video Experts
Electro Med Services...
