Question about The Computers & Internet
Navigation system on my 2003 bmw 745li says to insert cd when it isready inserted and I removed and inserted it multiple times and the same message shows up "insert cd"
    New Friend:
  • 170 Answers
Go to BMW they will be glad to fix it! Your CD or the drive in the unit is damaged. That is why I love my Garmin, it only cost my $60 and for an additional $79 I can upgrade it 3 times a year for as long as I own it.
Posted on Apr 16, 2017
SOURCE: 2003 BMW CI Convertable Radio/CD Problem
Had the same problem with my '03 330xi. Navigation worked fine but radio and CD did not work at all. I opened the fuse box located in the glove compartment to check the three fuses associated with the navigation system and radio. #7, #39, and #41. All three fuses were intact so I put them back in. I then put the key into the ignition, turned it to position 2 and miraculously the radio came to life. I guess it acted as some type of reset?
Posted on Nov 21, 2008
Eagleeyes
  • 199 Answers
SOURCE: AVIC-N3
Hi check your navigation disc for dust, dirt, damage.
if disc is good, you might like to try running a dvd cleaner in the unit, the avic has a fan that sucks in dust from the car, and this coates the cd lens.
we can service the unit for £45.00 plus return postage @ £10.00 (uk mainland)
www.blueice-electronics.co.uk
Regards
Mark
Posted on Nov 25, 2008
manojro
  • 495 Answers
SOURCE: Insert SIM Card message in nokia 6080 though SIM is inserted
May be its detecting your sim card properly. Check your sim card in another handset. Verify if its the propbelm with sim card not your handset.
Posted on Nov 26, 2008
  • 62 Answers
SOURCE: Xplode cdx-gt460u CD Reset Error
REMOVE THE FACE PLATE THERE SHOULD BE A RESET BUTTON ON THE FRONT OF THE RADIO PUSH THAT AND TRY AGAIN IF THAT DOESNT WORK THEN PULL THE RADIO AND DISCONNECT FROM POWER 4 A LIL BIT AND THAT MAY WORK
Posted on Dec 29, 2008
  • 43 Answers
SOURCE: lincoln navigation dvd
On my '06 Navigator the navigation dvd goes in a slot on the console to the left of the passenger's feet. There's a removable panel.
On a side note... does anyone have a newer dvd for Canada? The one that came with my vehicle is compile for the Quebec (*gasp*) market and is outdated.
Posted on Apr 07, 2009
How to remove the head rest out the front seat of a 2003 BMW 745li
Hi, at the back of the seat you have 2 parts you have to take off
1) bottom pocket insert
2) and the insert that's at top of that witch is just below head rest.
3) once those 2 parts off you will see the head rest and motor. Theirs two pins, one on each side of the chrome arms. Pull pins out and head rest slides.
Sep 26, 2016 | 2003 BMW 745 Li
When putting on your water pump. In a bmw 745li, how do you insert heater return pipe pass o ring on water pump
Not familiar with your car, but usually you put the O ring on the pipe, lube it with some clean anti-freeze and push the pump onto it.
Feb 09, 2015 | BMW Cars & Trucks
Bmw 745li problems
Bmw 745 li 2003 changed batery and audio system and navigation system not work
Jan 09, 2014 | Cars & Trucks
Hi, I have a BMW 525D '06 My problem is that the navigator suddenly stop working - "Reading error. Please insert DVD" and I can not use the navigator. Often it occur after aprox one hour drive....
This SIB may apply to this issue:
SI B 65 24 07
Audio, Navigation, Monitors, Alarms, SRS August 2007
Technical Service
SUBJECT
CCC Navigation Map DVD not Detected
MODEL
E90, E91, E92, E93 (3 Series) with SA 609 (CCC Navigation)
E60, E61 (5 Series) with SA 609 (CCC Navigation)
E63, E64 (6 Series)
E70 (X5) with SA 609 (CCC Navigation)
Vehicles produced from 8/31/2006
SITUATION
When entering into the navigation system, the screen only displays "Please insert DVD", even though a DVD map is inserted in the drive.
CAUSE
Incorrect map DVD
CCC software or hardware error
PROCEDURE
On a customer complaint basis proceed as follows:
Always verify that the correct map DVD is used (identified by DVD-CCC). Try a known good map DVD and see if the problem is resolved.
Update the complete vehicle per SI B09 05 01 (Programming and Coding with Progman) Procedure B, using Progman 25.00.00 or higher.
If the fault is still present, replace the DVD drive. Refer to Repair Instructions RA 65 83 580
PARTS INFORMATION
Part Number
Description
Quantity
Refer to EPC
DVD drive
WARRANTY INFORMATION
Covered under the terms of the BMW New Vehicle Limited Warranty.
Please refer to the latest KSD for all applicable labor operations and allowances.
If the appropriate labor operation is not contained in KSD, then a work time labor operation should be used.
Mar 07, 2011 | 2007 BMW M6 Convertible
How to connect personal cell phone in BMW 2003 745 li
i bought 2003 BMW 745LI
i don't know how to connet phone and also i am not sure it has bluetooth
Oct 02, 2010 | BMW 750 Cars & Trucks
Do i have a gps receiver on board in my BMW 525i?
Dear Sir,
You answered me that if there is not 2 CD slots, i will not have a GPS receiver for navigation, but also u aked one more question if my BMW car was US one, and i answered by Yes.
Waiting for another answer again.
Now I plan to borrought from any BMW owner i will find on the road, and who will have any DVD navigation disc, to insert it in my BMW and look for settings and fetch to know if i have a GPS receiver and what model .... if any..
The prime dealer in Lebanon will not help me fetching this, that's why i went for you..or for any friends i will find on the roads....
Thank you for your concerning
Best Regards
Pierre
Jun 10, 2009 | 2004 BMW 5 Series
A8 2004 Navigation system not active
NAV unit uses a DVD disc. If its a copy, it may or may not work. I suggest you remove the NAV disc, unplug the NAV unit from power for 4-5 minutes, reconnect the NAV and try inserting the disc again to see if it reads. If it still does not read, another NAV disc needs to be inserted to verify its not a "bad" NAV DVD disc issue. If it still cannot read the second disc, the NAV unit is bad. The handbook feature needs the disc inserted in the slot 1 of the CD changer unit.
Feb 23, 2009 | 2004 Audi A8
Lincoln navigation dvd
May 28, 2008 | 2003 Lincoln Navigator
Computers & Internet Logo
52 people viewed this question
Top The Computers & Internet Experts
Perry Ralston
Level 1 Expert
ashu k...........
Level 1 Expert
ted dux
Are you a The Computer and Internet Expert? Answer questions, earn points and help others
