MR SLIM 410a cooling only where is fuse on main unit as not getting power after a power outage
bobotfel
  • 236 Answers
SOURCE: Mitsubish mr Slim air contioner heat & cooling control panel
HOW TO WORK THE HEATING AND COOLING CONTROL PANEL
- PRESS THE SWITCH ONCE IT OPERATES "COOL"
- PRESS THE SWITCH AGAIN IT OPERATES "HEAT"
- PRESS THE SWITCH ONCE AGAIN IT STOPS.
Posted on Mar 05, 2008
  • 958 Answers
SOURCE: Mitsubishi Mr. Slim Mini Split MS-A12WA Indoor Unit
no sir gary,
the water would not go to the drain pan if you install it vertically.
water would just drop anywhere and would ruin a lot of things...
tnx 4 using fixya,
drcool
Posted on Sep 13, 2008
  • 958 Answers
SOURCE: Mr. Slim msz-a17na won't turn on after power outtage
after a power outage, normally as power comes back in, it's a little bit high than normal.
with a dead set that you got, it would probably be the control transformer. the primary could have been burn by a spike voltage.( sudden rise in voltage above normal).
or im sure it has a fuse. check first the fuse. if the fuse is ok, then it would be the transformer.
tnx 4 using fixya,
Drcool
Posted on Nov 26, 2008
  • 8 Answers
SOURCE: Mr Slim air unit is blowing out dirt into my room.
Simple matter of cleaning the unit. You have to clean the filters, the coil and around the louver.
Posted on Jun 10, 2009
  • 340 Answers
SOURCE: mr. slim air conditioner does not cool.
maybe just a cleaning
Posted on Jun 19, 2009
Power outage happened now power is on and no power to mr, slim .. main unit and wall mount no power ,, fuse box has no tripped fuses
Check the disconnect at the outside unit, little box on the wall. If not, turn power off and remove top to outdoor unit.
Apr 15, 2017 | Heating & Cooling
Mr. Slim aint cool!
Unit short of refrigerant or outside condenser very dirty. Clean outside thoroughly and make sure there is plenty of warmth coming from it when working.
Jul 07, 2012 | Mitsubishi MSZ-D30NA Mr. Slim Wall Heat...
We have a quad mitsubishi mr slim unit. one of the units was on during a power outage. We were not home so we did not see what happened but when we returned, the unit that was left on has the vent still...
Try to turn all of the power off for a few minutes and then turn it back on...this should reset everything again...
If not you will need to get a tech. to check it all out...
Here is a tip about Mitsubishi Air Conditionersand how to get the manuals for all of the Mitsubishi line. The manual includeboth troubleshooting and installation.
Mitsubishi Air Conditioner Troubleshooting and Repair
heatman101
Jul 24, 2011 | Mitsubishi Mr. Slim MXZ30TN Air...
Had a short power outage now the unit will not run. breaker ok and 234 volts to outside unit but inside unit will not come on. is there a reset or something
Try turning the unit off at thye meter box or the isolator switch out next to the outdoor unit of the air con. Leave off for 15 minutes and then switch back on again. Some Air cons get screwed up with power surges... Leaving off at the mains for a while often resets them. If the air con was running at the time the power went off, it may have damaged one of the electronic boards... Do you get any flashing lights or displays showing what could be an error code ??
Jul 16, 2011 | Mitsubishi Mr. Slim MXZ30TN Air...
Mr Slim unit "spits" water/dust mixture
some of those units are equipped with a condensat pump you could have a loose connection or a small crack in the line
Jul 08, 2009 | Mitsubishi Mr. Slim MXZ30TN Air...
tnx 4 using fixya,
Drcool
Nov 25, 2008 | Mitsubishi Mr. Slim MXZ30TN Air...
Mitsubishi Mr. Slim M/N MSH15EN
Try calling G A Larson's for technical advice. I think that they handle this product. 499-0866
May 22, 2008 | Mitsubishi Heating & Cooling
Heating & Cooling Logo
29 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
