Question about Plumbing
Why is the pressure reduced on kitchen faucets?
    Top Expert:
  • 49,198 Answers
Blocked inlet lines or tap seats
Posted on Apr 16, 2017
Why low water pressure on MOEN Kitchen Faucet Model CA87316SRS?
sad to tell you this but all kitchen faucet mfg's have put in pressure reducers and as hard as I have tried personally I can not get good pressure at the kitchen either
Feb 14, 2015 | Moen Plumbing
We have a problem with not having good water pressure. Is there a way to adjust pressure?
is low pressure limited to just one particular faucet...lavatory, kitchen, etc...? is pressure low on both hot and cold? if so, the first thing to check is the aerator..where water come out of spout..if all fixtures are have low pressure..you could get a water pressure gauge at hm depot..or local hardware store and check incoming house pressure at outside hosebid..you mite have a faulty pressure reducing valve usually located at owner side of city water meter..
Oct 30, 2013 | Belle Foret Plumbing
Hansgrohe Kitchen Faucet low water pressure
Try removing the aerator and handspray to clean out any debris that may have accumulated. After 8 years there could be quite a buildup if it hasn't been regularly cleaned.
May 24, 2010 | Plumbing
What is that rattling sound when i use my kitchen faucet in the extreme hot or extreme cold position?
Water hammer: is a loud banging or clanging of the pipes usually occurring when a valve is turned on or off due to loose pipes.
Solution: Anchor the offending pipes to the wall. Buy water hammer arrestors. Also Lower the water pressure with a pressure reducing valve
Hope this tip Helps.
Jan 24, 2010 | Hansgrohe 06649860 Solaris Single Hole...
I have poor water pressure from the faucet, hot and cold, in a single handle faucet
could be a number of things.
most mixer taps have flexible braided inlet hose's make shure there not kinked.
also there may be built pressure reducing valves,usually removerable,a plumbers job really.
is there servive valves on hot and cold if so make shure there fully on.good luck ,any qs ask
Aug 09, 2009 | Kohler K-15160-7 Coralais single-control...
No water pressure on Pegasus kitchen single handle faucet
Those new faucets generally have a lower water pressure due to legislation passed in 2007 that reduced that maximum allowable gpm (gallons per minute). I hate to tell anyone this but there is little if anything you can do. First of all, make sure the shut-off valves are open completely. I know that sounds elementary but I've seen it a bunch of times.
Also check to see if the aerator is blocked with a bit of debris.....unlikely if the flow is uniform but still an easy fix.
Hope I didn't break your spirit too much....
Apr 28, 2009 | Pegasus Technologies Pegasus F1225100BN...
Water flow is too powerful..
I got you, you want a screen to be put on the spout!
check the inside of the spout. there may be a internal thread, if it is, then you can get a external thread screen from home depot.
Apr 22, 2009 | Danze D405046 Bellefleur Single Handle...
Low pressure and flow on hot water side of single handle faucet
It could be one of two problems, one simple, one serious.
  • Easy fix
  1. Turn off hot water angle stop under sink to faucet.
  2. Remove supply line from hot angle stop.
  3. Place end of supply line in a small bucket to catch some water.
  4. Turn on cold water for a couple of seconds and backflush debris from faucet.
  5. Reconnect supply line.
  6. Turn on angle stop and test
  • Complex fix
If you have steel pipes you may be experiencing reduced flow due to corrosion in your pipes. Reduced hot water pressure in the kitchen faucet is usually the first sign since this is the faucet that is most used in the home.
Repiping is a job for a professional. Another symptom you may need a repipe is orange colored or rusty water.
Nov 14, 2008 | Delta Faucet Plumbing
Plumbing Logo
Top Plumbing Experts
Paul Carew
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
