SOURCE: front seat stays in the reclined postion..
The seat position is changed through the use of a cable that runs through a flexible tunnel, under the seat. In one case that I'm aware of, this cable got stuck around a projecting seat spring under the seat. When the seat was reclined and moved backward or forward, the cable caught on the seat spring and the seat had insufficient slack in the cable to release from the reclined position.
SOURCE: reclining
The manual should tell you how. If you don't have one, go to http://eddiebauer.djgusa.com/instructions/ and enter in your model # and manufactor date. Good Luck!
SOURCE: front power seat
this is a common problem unfortunatly the switch is no good and must be replaced
SOURCE: GRACO STROLLER FRONT WHEEL BROKEN
Contact Graco directly...the will send out a free replacement wheel. The whole unit comes together and snaps on.
SOURCE: my front seats on my fiesta 54 reg are broken i have to recline t
I TAKE IT YOU CAN'T USE TILT ON YOUR SEATS MOST LIKELY TO BE BROKEN CABLES YOU WILL REQ CABLES & BOTH SEAT HANDLES TO DO JOB OULD NOT RECOMMEND IT THOUGH AS ITS A PAIN OF A JOB TO DO.RECOMMEND BOOKING INTO LOCAL FORD DEALER AS THEY PROBABLY HAVE PARTS IN STOCK.
