Question about Frigidaire Refrigerators
My frigidaire refrigerator keeps shutting off
I have moved it to several outlets it powers back on then goes out again probably 2 times a day?
    Novelist:
  • 102 Answers
Your fridge may be low on refrigerant to cool the system and this could be from a leak in the system. Low refrigerant for the compressor and the suction line pressure drops to way below where it should be and most newer modern systems will shut the system down to protect the as they have a sensor that monitors the suction line pressure to the compressor. You will need the services of a skilled and licensed air conditioner repairman. This is not a do it yourself repair.
Posted on Apr 16, 2017
My Frigidaire model FFPT10F3MW stops running for hours at a time, every several days ,causing temps to rise. after 2-7 Hrs it begins cycling normally again, Sometimes for days till the next shutdown
The random shutdowns are being caused by a faulty defrost timer. The defrost timer is located at the bottom of the back of the refrigerator on the left side. It is a white box. You can attempt to reset the timer with a small slotted screw driver by placing the screw driver in the opening on the back of the box and twisting counter-clockwise until you hear or feel a click. If the reset doesn't work, you will need to replace the timer.
see
https://www.bing.com/videos/search?q=frigidaire+refrigerator+randomly+shuts+off&view=detail&mid=2D6EC6FAA19A62851F4B2D6EC6FAA19A62851F4B&FORM=VIRE
Apr 09, 2018 | Frigidaire Refrigerators
Snowmaster BD60DE keeps on beeping while doors are shut
Fridge keeps beeping or buzzing: The following is for Frigidaire models but others can be addressed similarly.
Several Frigidaire refrigerator models have an electronic control panel on the freezer door the owner can use to adjust the internal temperature, dispense ice and water and receive notification about issues such as the need to replace a water filter. The refrigerators also emit a beep for various actions and as an occasional alarm. Determining what causes the beeps necessitates some troubleshooting.
Temperature Controls ·A Frigidaire refrigerator's display panel blinks when the control panel is touched to set temperature controls. After pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, press the arrow buttons within five seconds to increase or decrease the desired temperature. If you do not press the arrow buttons within five seconds after pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, the refrigerator beeps to indicate the current setting will stay in place.
Door Open ·When you leave the refrigerator or freezer door open, the refrigerator beeps. Also, the "Door Ajar" indicator illuminates on the appliance's display panel. Shutting the door and pressing "Alarm Reset" stops the beeping and turns off the "Door Ajar" indicator light.
·The Frigidaire refrigerator has a control lock feature that prevents use of its control panel or dispensers when the unit is locked. When the control lock is active, a beep sounds when a keypad or dispenser is pressed. Release the control lock by pressing the "Control Lock" icon for three seconds. A beep will sound, and the icon's light will go out.
Power Reset ·A power reset is occasionally necessary if the Frigidaire refrigerator's control panel does not work normally or a reset function on the keypad does not work. A power reset involves disconnecting power to the refrigerator by unplugging its power cord from the electrical outlet, waiting 30 seconds and plugging the power cord back into the electrical outlet. When the control panel resets, a beep sounds. If the refrigerator beeps even after a power reset and the beeps' source is not known, contact Frigidaire.
Read more :
http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator.
http://www.appliancerepair.net/refrigerator-repair-1.html
Refrigeration System Basics Chapter 1 Cause of Beeping Noise in Frigidaire Refrigerator eHow
Feb 19, 2017 | Refrigerators
Fridge keeps bleeping
Read more :http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator.
Mar 19, 2016 | Refrigerators
Fridge keeps beeping, have unplugged, checked door and drawer seals and still keeps beeping
http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator. Cause of Beeping Noise in Frigidaire Refrigerator eHow
Jan 20, 2016 | GE Refrigerators
Why dose it keep beeping ?
Jun 20, 2015 | Refrigerators
Keeps beeping, but not overfilled
Read more :http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator.html
Mar 15, 2015 | Refrigerators
Beeps about 6 times when fridge door is opened.
Mar 11, 2015 | Refrigerators
Smeg refrigirator keeps beeping without stop
Mar 09, 2015 | Smeg Refrigerators
Why does my Hotpoint ff187e frost free fridge freezer lights flash and the alarm sound even after reseting them as per manual. rest them ok for a while but then restart what's the problem?
Jul 27, 2014 | Hotpoint Refrigerators
Frigidaire refrigerator FRT18L4J power problem
Probably the refrigerator especially if the compressor is not starting . Is refrigerator/freezer working?
Aug 29, 2017 | Frigidaire Refrigerators
Refrigerators Logo
56 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
