Question about Mini Computers & Internet
Can i plug my dvr into my mac mini i only have one screen
How to planar touch screen to mac mini
Try downloading and installing the latest drivers for your particular model.
Drivers and Software
Oct 15, 2014 | Computers & Internet
Tech support
DVRs store files on either data tapes or on hard drives or on memory chips such as SD cards. If SD card then simply remove the card and plug into a computer where it will appear as a removable drive. If internal hard drive your DVR will be equipped with either a IEEE1394 mini socket or a USB mini socket. In either case plug the appropriate cable from your DVR to your computer where it will appear as an external removable drive. If you are talking about a proprietary DVR such as a Foxtel IQ or other brand name DVR then you have to know the format of the video files. Foxtel, for example, uses their own format which can be recovered and saved to an external hard drive on a computer using a video capture card and playing the file back in real time. Time consuming, but that's how I do that. Other branded DVRs use standard video file formats that can be copied to your computer easily via an HDMI socket or USB3 or whatever it has.
Dec 09, 2013 | Audio Players & Recorders
Mini Mac screen keeps freezing
Back up your profile data using Time Machine. Restore your computer to factory settings using the disc that came with your Mac and transfer settings from backup.
Oct 13, 2012 | Apple Mac Mini 2.66GHz Intel Core 2 Duo...
When I insert a blank DVD-R disk into my Pioneer DVD-RW DVR-111D burner, no "untitled disk" icon appears on my desktop. I am using a Mac mini computer. This is the first time this has happened...
Go into your system profiler. Make sure the DVD is showing up. Click the DVD and check what disks it can use and make sure the disks you are using are compatible.
Best of luck, Jim
May 01, 2011 | Pioneer DVR-111D (DVR111DBK) DVD RW Dual...
Trying to run a mac mini to philips flat tv
Hi Ralph
Normally it's either one of the AV channels OR the channel marked RGB.
What connector are you plugging into on the TV?
Jan 21, 2010 | Apple Mac mini
Broken power button jack/plug on apple mini mac (post 2009 intel)
Not sure about schematics but here are a couple links to disassembly guides:
<http://www.applefritter.com/Mac_Mini_Take_Apart_Guide>
<http://www.r3uk.com/index.php/tech-tips/34-disassembly-guides/4-apple-mac-mini-model-a1170-disassembly-guide>
Also,
Check this site out <http://www.123macmini.com/news/story/316.html>
Good luck.
K.
Dec 20, 2009 | Apple Mac mini
Mac mini display problem
Sounds like your monitor is not set right. Is the monitor LCD or CRT type? You can open system preferences from the top of the screen under the apple icon. Try and see if you can adjust the resolution settings. Also if you have an LCD screen set to "auto" adjust to reset the screen. Good Luck.
Aug 03, 2009 | Apple MB464LL/A Mac mini Desktop
How to connect YAMAHA DVR-S120 to computer
As long u`ve got audio out on ur Vaio (usually headphone mini jack on laptop`s) use stereo mini jack to RCA (both male plugs) extension cable. U may use video or vcr inputs on Yamaha. Be careful, when adjusting volume on ur Vaio - start from mid range & compare with other sources - DVD, TUNER etc. I`m not sure, but ur model got an optical SPDI/F audio output. In this case use toslink cable. Cheers
Dec 27, 2007 | Yamaha DVR-S120 DVD Player
Aquos lc-26ga5u to mac mini
Adjust resolution on your mac mini to something the TV supports. Usually 1080 vertical resolution or below
Nov 07, 2007 | Sharp Aquos LC-32D40U Television
Computers & Internet Logo
Top Mini Computers & Internet Experts
NOEL
NOEL
DROPNDEAL
DROPNDEAL
Are you a Mini Computer and Internet Expert? Answer questions, earn points and help others
