Question about Carrier 38CKC042 Air Conditioner
Possible Contactor Issue
I have a 10 year old Carrier Heat Pump (Roof Top), sorry i do not have the model number available. Starting last night (7/23/09) I could tell the compressor was running, but no air was coming through the vents. I tried to turn off the unit at the thermostat, but the compressor kept running. The strange thing is I then bumped the temp setting down a couple of degrees and the blower then came on. I let it run at this setting a few minutes then bumped the thermostat setting back up to where it was, and evertything shut down. This whole thing repeated itself last night, and I had to do the same routine. At other times, the unit and blower turn on and off normally. It appears that when the room temperature is reached, the blower turns off but some times the compressor and fan do not. I am thinking a bad contactor, but I would think it would either be stuck open or closed. A dirty contactor maybe?
  • 614 Answers
Sounds like a bad fan switch in your unit. That unit has a fan board in it that is time delay on and off. Turn the fan to the on position and let it run all the time. If it keeps temp and does not shut off it is the fan realy board. The board also controls the compressor. Check that first and then the tsat. Russ
Posted on Jul 24, 2009
How can you find the model number for our Ruud Achiever 10 since the outside label has unreadable now? Our house was built in 1994.
just get a double pole contactor and rewire using existing contactor to wire new one ,, contacters are generally generic
Jun 22, 2014 | Ruud Matching Split Air Conditioner
I have a Goodman CE48-1GC outdoor unit, it just stopped working last night completely. I have verified the control switch is in fact being engaged when on A/C, however the fan and compressor are not...
A defective capacitor will prevent the compressor from starting. If as you say, the contactor is engaging, then it's either a defective capacitor or compressor motor. I'd check both, starting with the capacitor. The fact that the contactor is working, eliminates some other possibilities.
Aug 25, 2013 | Goodman CKL49AR49 Air Conditioner
Carrier A/C making buzzer noise every 6 minutes.
Probably the contactor, they have a coil that sometimes buzzes, after the contacts become pitted and no loger pull together like they are supposed to. It could also be a voltage problem from the transformer that is causing it, but I would bet on the contactor. Get it fixed quickly as a voltage drop across the contactor can be the demise of you compressor!
Jul 13, 2009 | Heating & Cooling
Have carrier heat pump that buzzes
What exactly does it do? If it buzz and don't turn a starting capacitor will not help, this is an indiction of a shorted motor.
Jul 02, 2009 | Carrier 38CKC036 Air Conditioner
I HAVE A 10 YR OLD CARRIER HEAT PUMP.THE CONTACTOR POINTS WERE REPLACED TWO MONTHS AGO ,THEY ORIGINAL POINTS WERE PITTED AND NOT OPENING CAUSING COND. UNIT TO KEEP RUNNING.THE NEW CONTACTOR POINTS ARE...
First, check your compressor wires connections for loose or coroded, then clean them (file or sand them or just add oil to the ends connectors and go with a higher 24-va contactor instead of a 40-va, maybe a 80va 24-volt contactor.
Sep 04, 2008 | Heating & Cooling
I am a ac tech, and i was working on a old carrier unit, wich had no schematic diagram. I need it in order to get the compressors going. if i give you a model # can you please provide one. roof top ac...
you aren't an ac tech number one but i shall overlook that . your question is llike will the sun come up in the north or the south tomorrow. obviously in the east as it has since the earth was created. anyway. all compressors since the beginning of time wire up the same .a wire commonly referred to as the common goes from the contactor to the compressor. usually black in color, hence the old coloqualism Blacks are common. the run wire is from the contactor to the run side of the run capacitor or from the contactor to the run connection on the compressor. hence the old slogan reds run when you point a gun at them. the only wire left is the start wire that come from the start capacitor and is usually yellow . hence the old saying blacks are common, reds run, and yellows are always starting something. very ethnic i know but thats how i was taught.now that the wirings correct check to see volts through contactor are correct and if one side of contactor is not feeding. if volts good then check capacitors with a cap checker. if all else looks good kill power and inspect compressor terminals at compressor. if burned off consider a termilock kit good luck..
Jul 19, 2008 | Goodman CLQ36AR49 Air Conditioner
We have a roof top mount cetral heating & air unit and its a day& night unit it will blow air out but not cold air .went on top of roof to check condencer and it is hot and coils are normal...
sounds like the compessor over load is cliking on&off compressor not starting could be a capacitor or compressor or if your lucky a contactor dan
Jul 13, 2008 | Heating & Cooling
Carrier 38CKC042 Air Conditioner Logo
218 people viewed this question
Top Carrier Heating & Cooling Experts
Bill Long
Tim Whalen
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
