Question about Orbit Hardware & Accessories
How can I manually test one station on an orbit irrigation water master 6 station indoor time Right?
  • 1723 Answers
SOURCE: Orbit sprinkler system
Have you programmed the new one with all the info for date and time? Did you set the zones for the days you want and watering times?
Posted on Jul 02, 2009
  • 597 Answers
SOURCE: instructions for operating orbit control centre required
INstruction manual
Easy Programing guide
Posted on Nov 22, 2009
  • 33 Answers
SOURCE: i need a user manual for the timer box of a orbit
Posted on May 16, 2010
SOURCE: need orbit irrigation manual for model #57979
How does one connect the Wired Toro Rain Sensor, Model 53769 to the Orbit, Model #57979?
Posted on Jun 07, 2010
SOURCE: I have a Orbit 57161
Tech service 1-800-488-6156
Timer has 4 year warranty
The manual has troubleshooting
Looking through the manual I can see potential trouble areas:
-Water pressure too high > 60 psi is ordinary household pressure > order Brady BTG pressure gauge that connects to hose
-Overlapping times are 'stacked' by timer ... but 'more than one start time' is listed as cause of stations turning on when not supposed to >> reset and re-program timer, make chart of on-off times
-Weak or missing AA batteries >> clean terminal inside timer and replace batteries
-Hard water deposits or unfiltered water clogging water valve (water softeners frequently have this problem) >>> see if vinegar or CLR cleaner can help flush water valve >>> add sediment filter in front of timer
-Fuse blown
-Bad solenoid
-A combination of problems listed above with sediment -or- solenoid as main suspects
Posted on Oct 06, 2010
Where can I get a manual for 6 station irrigation timer?
Hi Colleen, The 1st link is a 2 page manual for a 4 & 6 station indoor controller and the 2nd link is a youtube video showing how to program an orbit timer, I hope this helps because you don't give a brand or model number.........CHEERS..
How to Program an Orbit Easy Set Logic Timer
Apr 27, 2016 | Orbit Hardware & Accessories
Shows station 2 and 3 on screen but watering does not commence. Have reset numerous times same result.
bad solenoids or valves. also check and bleed air out of sysyem. bleed screws are on top of valve
Dec 12, 2015 | Orbit Irrigation 57856 6 Station Easy Dial...
How stop sprinklers from starting over
You only program the first zone to turn on at a specific time. The rest of the zones go in sequence.
Aug 22, 2014 | Orbit 6 Station Indoor Dual Program...
Orbit sprinkler timer manual
Contact the manufacturer. They usually will have the manual online for downloading.
Jul 30, 2014 | Orbit Irrigation 57856 6-Station Easy Dial...
"my orbit easy dial 6 station quit working in auto
Does it work manually? If so, which is rare and almost unheard of I would replace the timer. You can't buy a less expensive timer $20 for a 4 station. Which explains why it is not working. If it doesn't work make sure it is plugged in and outlet has power.
Aug 11, 2013 | Orbit Irrigation 57856 6 Station Easy Dial...
Model 57882 9 station timer I did set up station 1 where do I begin in order to set up station 3
Question is not clear.
Do you have programming problem with the timer?
Or problem locating sprinkler heads?
Or a sprinkler valve problem?
Add a comment with detailed information.
Sprinkler timer turns ON-and-OFF.
Timer does not advance the sprinkler to next station. The sprinkler valve advances to next station when timer turns OFF.
For example, when timer turns ON, then station 1 starts watering.
Timer turns off, and then sprinkler valve automatically advances to station 2.
Timer turns on again, and station 2 starts watering.
Orbit resources:
Aug 02, 2011 | Orbit 57882 9 Station Super Dial...
Need orbit irrigation manual for model #57979
Jun 05, 2010 | MicroBoards Orbit (ORB-4201-01) Burner
Hardware & Accessories Logo
Top Orbit Hardware & Accessories Experts
Craig Butler
Craig Butler
Are you an Orbit Hardware and Accessory Expert? Answer questions, earn points and help others
