Question about Craftsman Garden
15hp craftsman tractor manual - Craftsman Garden
  • 1,057 Answers
Go to searsparts.com and input your model number and at the bottom of the page you can order one.
Posted on Apr 16, 2017
Craftsman tractor how do I engage freewheel control rod?
Craftsman Lawn Mower manuals - ManualsLib
www.manualslib.com/brand/craftsman/lawn-mower.html
. PDF manuals. User manuals, Craftsman Lawn mower Operating guides and Service manuals. ... 28910 - Lt 2000 20 HP 42" Lawn Tractor · Operation Manual.Craftsman Lawn Mower manuals - ‎Craftsman 247.370310 - ‎Craftsman 247.37030
Aug 02, 2015 | Craftsman Garden
The deck on my mower is lower on one side than the other. Is there a way to raise it up? It is tearing my yard up and scalping. I have a craftsman 15hp 42inch cut command. Any help would be appreciated...
To adjust a Craftsman deck, raise the deck to the normal cutting height.
Measure to the flange on the deck on the right & left sides. It is easier to lower the deck than to raise it, so, on the high side, find the threaded rod that supports the deck. Using a wrench, back off of the nut (counterclockwise as viewed from the end of the rod) until both the left & right sides of the deck are the same height.
Be sure your tires are properly inflated before measuring.
Gary
Jul 03, 2011 | Craftsman Garden
Craftsman Kohler 15HP 42
it deffenetly sounds like the coil is bad . as the motor increases in temp. the coil pack expands thus loosing positive charge. change it if it has points filr them a little too remove the tartar you should have a sharp blue spark
Apr 05, 2010 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
I have a craftman lawn tractor with a 15hp kohler engine. Engines starts and runs fine After mowing for a while and then shutting it off the engine will not restart until it cool off completly. Any...
See if there as any difference in compression when the engine is cold verses hot. Also check ignition spark when it is hot. Unit could be vapor locking because of heat. Carb float could be suspect.
Sep 14, 2009 | Craftsman Garden
Craftsman 42in 15hp Kohler engine dies when either the brake is released or the blades are engaged. Replaced switches, still happens.
You replaced the seat switch? Make sure you trace the seat wiring back to the main harness. Look for any signs of the wire rubbing against metal and shorting to the frame or other metal component.
Good luck, let me know.
Regards,
Aug 22, 2009 | Craftsman Garden
Looking for manual for Craftsman 917.256552 15HP OHV Kohler 42" Hydro lawn tractor mower. I have the Spanish version but lost the English version with parts and diagrams!
if you go to sears.com click on parts direct
enter your mod # and to the right of the next page says get manual click on that and then click on view manual and it should come up for your mower
Jun 09, 2009 | Craftsman 42 in. Precision Cut Plus 24hp...
Tractor stalls when letting out clutch
Sounds like the clutch safety switch is going bad.
May 28, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Need to change secondary drive belt
Hello kerry_byrum:
>>To View a Breakdown of this Unit Go to this Site Addy, http://www.searspartsdirect.com/partsdirect/index.action?sid=PSHx20080114x00001 and Enter the Model Numbers and Click Search. From this Page you can View Diagrams and Parts Lists for you Equipment Using the "View Sub Components" Section Near the Bottom Left. Select Ground Drive for a Breakdown of the Belt and Other Drive Related Components.
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
May 13, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Garden Logo
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
