Question about The Home Security
# UT-7578-02. Icklr witeless doorbell. Cannot figure out how to set the tone NS it only rings when your finger is pushing the button. When you let go it stops.
cnavarro
  • 2460 Answers
SOURCE: doorbell/cartel
The cadence is different, but you can change all the other rings to a different tone. On a 76xx phone, press PROG and the CO button twice. Press your navigator button up (or down) until you hear the tone you like, then press enter to save.
Tones 01,04 and 05 tend to be reasonable.
Carl
Posted on Sep 01, 2008
  • 905 Answers
SOURCE: my pushbutton doorbell activates my neighbor's chime
in the chime box and remote you can change the setting for the remote signal that is picked up( refer to your manual for the correct settings) these will be a set of pin connections in the chime box and in the remote switch that will have to be set to another selection
Posted on Dec 29, 2008
cnavarro
  • 2460 Answers
SOURCE: Cant get ITCM light to stop flashing - no ring tone for incoming
If you're really lucky, you only put the system in night mode. From extension 10 press ITCM and #. Days :-)
Carl
Posted on Jun 04, 2009
bala31328
  • 71 Answers
SOURCE: how can i set message ring tone.
well go to settings menu, sound or tone settings.turn on message alert tone and select your tone
Posted on Jul 25, 2009
miroypianole
  • 6 Answers
SOURCE: A doorbell with a mind of its own?
replace the button switch
Posted on Nov 13, 2009
Rind doorbell doesn't stop ringing
it is possible that the doorbell button is sticking down and keeping contact - so the doorbell keeps chiming.
Mar 24, 2018 | New Home Security
I have a IQ America doorbell with 5 chimes and 5 tunes and the bell only plays a sorta gong which cannot even be heard How do I fix this problem so that it plays a chime/tune?
We had a similar problem with a wired doorbell. There is a diode in the doorbell itself that causes the chime to ring fully. If the diode is backwards, you get just a small tone and can only hear the full chime if you hold the button down. If this sounds like your problem, open up the doorbell at the button end (or have an electrician do it) and reverse the diode.
Nov 07, 2011 | Desa International White Wireless Plug In...
Phantom bell rings on Siemens wirreless door bell chime jsjs-204, I do not have instructions
You may need to change the frequency of the chime. In this model, you need to remove the batteries from the receiver unit and wait for a while. Then replace the batteries. The doorbell unit should automatically set itself to a different frequency once you press the button, which will(hopefully) solve the problem.
It seems impossible to find the instruction manual for the doorbell. But see http://oddsnsods.net/blog/?p=68 who had a similar problem with a different Siemens model, which works on the same principles. (I can't seem to be able to remove the battery from the door bell unit on the jsjs204, but it reset itself after changing the batteries in the receiver).
Nov 01, 2011 | Desa International White Wireless Plug In...
I have a Siemens Wireless Doorbell (Model No. JSJS-204. It started making ringing tones when no one was pushing the doorbell. I replaced the battery thinking that it was wearing out. Now the unit does not...
Hi
To fix the issue you need to remove the batterys from both the bell push and the bell unit for 10 mins, then replace the batterys and then push the bell push so it can switch channels and be different from the house down the road
Sep 17, 2011 | Vacuums
We had a storm and now the phone lines in the house to not give a dial tone. We did have minor flooding in the basement. I checked the outside box and there is a dial tone there. Also our doorbell is...
Check to see if you "minor" flooding watered a jack or you have a cable lying in the water or got wet. Examine the pins on each jack and cord. Or, as an alternative if you can unplug all but the main phone from the jacks (assuming there are modular jacks for each extension) then plug them in one at a time until the problem comes back, you may be able to pinpoint the bad cable run.
Carl
Aug 21, 2011 | Lands Phones
We are installing the doorbell and here is how we have it set up: the 18 volts off transformer red wire going to transformer on doorbell, negative wire going to outside button, red wire from button going...
need more info. Doorbells do not need 2 xfrms. The red off 24 volt xfmr foes to door switch and returns on white. If you have 2 door switch one switch to front door label on doorbell and the 2nd goes to back door label. What is the brand and model number/ I'll try and walk you thru it.
Jun 21, 2017 | Heath Zenith Designer Series...
How do i fix my doorbell
99% of the time, you need a new doorbell button
Also check if any circuit breakers are tripped
Check GFI breakers in baths and kitchen
Real-estate lady answer: buy a new doorbell button and connect 2 wires on back of new button.
Doorbells are low voltage and not dangerous.
If screws are loose in the holes, break off toothpicks in hole so screws have something to bite.
You need small screwdriver:
Repairman answer
Doorbell problems have 3 parts
1) The button
2) The chime or bell located in house
3) The 12V or 24V transformer located in attic or basement
4) rarely the wiring because it's low voltage and does not get hot
1) start at the button.
Remove button from wall
There are two LOW-voltage wires on back of button
Remove 1 wire and touch other wire, copper to copper
Does doorbell ring? Do you see a spark?
If bell rings, then button is bad
2) Chime or bell doesn't ring when button wires are crossed
Take cover off chime
The button works, so have helper push button while you're looking at chime
Can you hear any noise? Have helper push button on-and-off
Chimes have 2 or 3 wires >>> 2 wires if only front door has button, 3 wires if back door also has button
Take one wire loose and scratch it across each of the other wires
Remember front button is held down (or front button wires are twisted together)
Can you see a spark when wires are scratched together?
Try this with more than one wire ... but don't mix up location of each wire
If you are getting a spark, then chime is getting power, but it's not working
Replace chime
3) Transformer in attic or basement looks similar to this:
Use a wire and scratch across both screws to see if you get a spark
If you get a spark ... and the crossed wires dont ring the chime... and there is no spark at chime, then there is a bad wire
If no spark at transformer, then check circuit breaker
At last resort, but new transformer at Home depot in the doorbell section near light department
Oct 05, 2010 | Garden
I'm looking for push button for a trine/desa model #SL-6166-RX
I believe this is also the Zenith door chime. I bought mine at home depot, and they have the push buttons.
Mar 01, 2009 | NRS Huge Playhouse W/ Kitchen, Skylight,...
Doorbell/cartel
Carl
Aug 01, 2008 | Panasonic KX-T7633 Corded Phone
Ringtone doesn't want to set
Dear friend
pls go to settings option and open 2nd step go to ring style open then open ring style menu choose line 1 and slect ring tone by you choose then slect by scorall middle button and reday for use if fill diffcult then you go to nearest service center
thanks and regards
alok
bihar sharif
Feb 10, 2008 | Motorola Mobility RAZR V3i Cellular Phone
Home Security Logo
37 people viewed this question
Top The Home Security Experts
vince
 MikeWang
MikeWang
Level 1 Expert
Are you a The Home Security Expert? Answer questions, earn points and help others
