Simpson SWT 704. Eziset toploader. Main drive motor. What are the motor connections or does someone have a schematic?
I want to re use the motor for another purpose. I have the seperate capacitor.
hattonhall
  • 349 Answers
SOURCE: simpson eziset 800 clothes tangle when washing
If you can use a lollipop stick to operate the lid switch while you leave the lid open, you will be able to observe if the agitator is going smoothly back and forth EVENLY or not. If it is tending to turn just one way....this will tangle the clothing like mad!
If this is the problem it could be the switching module or capacitor that needs replacing.
Posted on Oct 25, 2009
Testimonial: "i will try it thanks "
  • 159 Answers
SOURCE: simpson eziset 950 wont turn on
Hi there.There is a fuse inside the head panel.the fuse is a glass type about 3.5 amp.you can normally get these from an electronics shop such as **** smith or Tandy Electronics.Make sure the plug is out.the fuse is in the green circuit board.
Posted on Jun 01, 2010
  • 713 Answers
SOURCE: My Simpson Eziset 550 won't
Hi just read your posting.Now in your posting you said there were 2 lights flashing.What lights are flashing?Also on a sticker at the back of the machine there is a model number.Could you please reply back and let me know the model number and which lights are flashing.Looking forward to your reply.
Posted on Aug 18, 2010
  • 20 Answers
SOURCE: I have a simpson eziset 52b870 dishwasher manual
This may work if you hold one of the program buttons on for 10 seconds then the currnet program is cleared and you can then select the program you want.
Posted on Dec 23, 2010
  • 6277 Answers
SOURCE: Looking or a service manual
Unfortunately this forum does not supply any type of manual, installation instructions, electrical or schematic diagrams direct; it's just made up of ordinary guys and gals, probably at home and from all over the world, with experience of addressing problems and giving guidance for free on the web ;-0)
You will need to type into your search engine/web browser '(make) washer service manual' and you may be presented with a number of sources from which you can either download for free or have to pay a nominal amount. During the process you will be asked for the actual model number!
May I also suggest you try the manufacturer's web site direct? You may find, however, that it will supply schematics only to service engineers but good luck anyway.
John C.
Posted on Mar 21, 2011
My Simpson eziset 8.5kg washing machine has just stopped filling with cold water
Then either the cold water inlet valve is faulty or the main board is not supplying power to turn valve on. Use a multi meter to test which it is or get someone out that can.
Apr 10, 2018 | Simpson Washing Machines
I have a Simpson Eziset 550 and I press the power button and get nothing
Either power on/off switch is faulty or main control board has a fault and may have to be replaced. You need a test meter and fault finding knowledge to trace the fault. Probably best you call out a service person.
Feb 17, 2018 | Simpson Washing Machines
Simpson Eziset 750 top loader washing machine won't fill with water.
might be the inlet valve has failed or the main controller
Dec 03, 2016 | Simpson Washing Machines
My Eziset Simpson 550 won't spin
either the motor brushes are badly worn
or the pump cant clear out the water
i would say check the brushes they should be quite long if they are shorter than 3/4 inch then replace them
Mar 09, 2015 | Simpson Washing Machines
My Simpson toploader Eziset 750 will not start, the power point is ok.
Maybe the lid inhibitor switch is faulty,or not being pushed in when lid closed
Sep 20, 2014 | Washing Machines
Simpson EZISET 605 top load washing machine stopped spinning sound like its spinning but the tub does not spin hence does not wash
I am not sure but it sounds like the rubber/plastic drive coupler between the motor and trans is out. simple repair
Feb 21, 2014 | Washing Machines
I need a manual for a Simpson Eziset 52B870 Dishwasher
http://spares.bigwarehouse.com.au/ this website has schematic diagrams with part numbers for Simpson dishwashers.Does have some manuals for a range of goods.If not you can upload one.
Oct 17, 2010 | Dishwashers
Clothes dryer stops
sounds like the drive belt has stretched, or the auto tension is low.
disconnect power and remove back cover, clean inside around motor resitor block wires, and inspect/ replace faulty components. good luck!
Jan 30, 2009 | Dryers
Simpson EziSet 750 washing machine won't spin - what am I looking for to fix it? Appears to be working in all other respects.
the lid-lock button keeps beeping on my simpson eziset 750washing machine. how do i make it stop!
Sep 20, 2008 | Washing Machines
Heating & Cooling Logo
42 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
