Question about Pentair Intellitouch Pool or Spa Personality Kit - Single Body of Water - i5s - P/N
Remote control not functioning
Remote control no longer powers on, unable to use it.
  • 163 Answers
Make sure they are both set the same both clrener ann\d romote same seting
Posted on Jul 26, 2009
Tip
Why Am I Unable To Program The RCA Remote Control To Operate My Components
Why am I unable to program the RCA remote control to operate a component? Why am I unable to program the RCA remote control to operate a component? If you are unable to program the remote control to operate a component, review the following information:
Compatibility
If none of the programming procedures work, the universal remote control may not be compatible with your components, based on the type of infrared technology and the age of the components. Some RCA universal remote controls will only work with components manufactured after 1990.
Distance
If you are testing the remote control after you have entered a code, you may be too far away from the component or you may not have the remote control aimed directly at the component. Because the remote control uses infrared (IR) technology to communicate with components, there must be an unobstructed path between the remote control and the IR sensor on the component.
Code Entry Methods
If the Direct Code Entry method was used to enter the codes for your brand and the unit is still not functioning properly, try one of the automatic code search methods instead. During automatic code search, the remote searches for the correct code to program.
Modes
For the remote control to know which component you wish to operate, you must put the remote control in the correct mode by pressing the corresponding component button.
Combo Units
To program the remote control to operate combo units, such as TV/VCR’s, TV/DVD’s, or TV/VCR/DVD’s, use the combo codes in the Code List to program the individual corresponding component buttons. Once programmed successfully, the TV button controls the TV functions on your unit, and the DVD or VCR button controls the DVD or VCR functions, respectively. The codes in the combo section should be tried first, using the Direct Code Entry method on the TV and DVD or VCR buttons. If this is unsuccessful, use one of the Code Search methods to program your combo unit.
Batteries
Make sure the batteries are new and properly installed.
on Jun 19, 2009 | RCA DIRECTV Satellite Remote Control
Remote control issues
If you whsh to get all functions operated with your TV, you must have its original remote control, and it is no doubt. No universal remote control will operate with all functions, that are supposed to be, especially to Sony Brands. You can buy the original remote control from the authorized service center for Sony, or from any authorized dealer for Sony. Then why do you go for an experiment
May 14, 2013 | Sony Bravia KDL-32V4000 32 in. LCD TV
Remote will no longer power on Onkyo HT-S3500. Once I turn it on manually, the rest of the functions work properly.
I just had this same issue. I tried to change the batteries for the factory remote that came with the Onkyo HT-S3500 (remote: RC-799M). Still no luck. It would not power on with the remote, despite the light flashing and the and all other remote function working. If I powered on the receiver manually, everything worked (except power on/off).
I just pushed a button on the remote labeled "REMOTE MODE RECEIVER" and viola, the remote now powers the device on and off and works just like usual. Not sure what the heck happened, but I would suggest pushing that button on your remote.
Dec 19, 2012 | Onkyo HT-S3500
Panasonic dmrez27 dvd recorder stuck on dvd2 setting
If you point the remote towards sensor, simultaneously hold down the number (1, 2, etc) you want AND the enter button for 5 or more seconds it should switch to the number pressed. Remember if you have a second one, make sure it's off or put towel over its remote sensor. Sue
Feb 20, 2010 | Panasonic DMREZ27 DVD Recorder
CT-877 Power on/ Power off function no longer works. All other function working.
Re-programmed remote using instructions found at Toshiba website.
Dec 31, 2009 | Toshiba CT-877 Remote Control
Nec chromvision tv (no remote) unable to tune
Just buy any Logitech Harmony universal remote control
Jul 30, 2009 | Televison & Video
Denon RC-980 subsitute remote for Denon AVR-3200
I have a remote left over from my denon ACR3200. the remote is RC-825. It is currently listed on Ebay.
Dec 24, 2008 | Audio Players & Recorders
Device stuck on bottom right icon. cannot change.
Good Day, hcolern2b;
Sound like your TV's front panel button assembly is bad, replace or disconnect and use remote only.
Good Luck, big IRISH.............PS disconnect from front by removing speaker grill and small black panel, follow wire harness.real close by.
Sep 07, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Pentair Intellitouch Pool or Spa Personality Kit - Single Body of Water - i5s - P/N Logo
154 people viewed this question
Top Pentair Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
