Question about Crayola Office Equipment & Supplies
How do you change the light bulb in a Crayola Trace 'N Draw Projector Deluxe? I can not get the light bulb compartment open.
3 Suggested Answers
SOURCE: Infocus screenplay 4805 projector
check the wireing in the new bulb . My new one had the wires in the wrong holes like if there are 4 slots in the connector then my orignal was in slots 1 and 4 the new one was in slots 1 and 3 so I took the wire out and put it in the #4 slot and put it in and unpluged the machine and did a reset and restart and it came on green. Hope this helps.
Posted on Jan 28, 2009
  • 48 Answers
SOURCE: Projector powers on but bulb
If you feel that it is working abnormally you can send it to service. In the USA Braun service is: HP Marketing Corp. PO Box 715 16 Chapin Rd. Unit 908 Pine Brook, NJ 07058 800-735-4373
Otherwise contact the service center in your country.
Posted on Sep 15, 2011
How do I open up a Rank Aldis 2000 Auto Deluxe Slide Projector to change the bulb and free a jammed slide?
There is usually a sliding tab on the side of the projector (behind the handle) that toggles between "manual" and "automatic" advance.
Aug 27, 2016 | Office Equipment & Supplies
Video about how to fix a crayola light box
Does it have a replaceable bulb? If is LED then it might be done with unless the LED plugs in. Most people cant unsolder an replace them. Or it could be a bad switch
Mar 28, 2014 | Crayola Store Light Up Tracing Pad - Boy
When I try to power the projector up, a red light flashes and then it switches itself off. We have had a message saying replace bulb prevoius to the problem. Thank you
You will need to replace the bulb for this to work again. This is very easy to do. There will be a compartment to open with a screwdriver more than likely on the underside of the projector behind the lens. Remove that and you will see the bulb cartridge. Get the numbers off of that, order a couple of them and replace it. This should start up nicely after that. Every bulb has a projected hour life as well which is not like a home bulb. The life is considerably shorter so I would make sure you turn this off when not in use to get longer life out of it.
Feb 25, 2011 | InFocus ScreenPlay 5700 Multimedia...
How do I change the lamp? Lamp came with no directions. This is a HD72.
Hello there,If your movie projector light bulb has stopped working, there are some simple steps to take to get your movies playing again. The hardest part may be finding the correct replacement bulb. There are so many different models with their own specific bulb. Here are some steps to follow to replace your burned out light bulb.
  • Locate the bulb in the movie projector. You may need to use a screwdriver to open the bulb compartment. Check your owner's manual for proper procedures.
  • Step 2.Remove the movie projector light bulb or lamp. The bulb must be cool before you take it out. Use a tissue or cloth to remove the bulb because the glass bulb is very fragile. Do not throw away your bulb yet, you may need it to help find a replacement.
  • Step 3.Find replacement bulb. The Better Lamps website offers a wide variety of light bulb models. From their homepage select the brand of movie projector you have and using the model number from your old bulb, buy a replacement.
  • Step 4Replace the movie projector lamp or light bulb. Do not touch the bulb with your skin. This can transfer oils from you onto the bulb resulting in a hot spot which can make the bulb burst. Use a tissue or cloth to handle the new bulb to screw it back into place and then replace the cover.
  • Jul 31, 2010 | Optoma HD70 DLP Projector
    How do I open the top of the projector to replace the light bulb?
    Hi, Follow :- http://www.wikihow.com/Replace-a-Projector-Lamp There is a Video as well on the same page.If you wish to Purchase the Bulb, you could consider :- http://www.partstore.com/minisites/projectorLamps/HowToReplaceProjectorLamps.aspx Let me know, if needed further assistance, Hope i helped you. Thanks for using ' Fixya ' and have a nice day!!
    Feb 10, 2010 | Televison & Video
    Lp790 projector does not turn on
    it would still try to turn on even iff there wasn't a lamp in it. if it won't even turn on, see if the switch inside the lamp door is working. it won't turn on if the door is open. also, the thermoswitch on to of the lamp compartment (through the inside) may also be blown and needs replacement.
    May 12, 2009 | ASK Proxima InFocus LP790 and Proxima...
    Changing a light bulb?
    Yes the bulb will need to be replaced. You can do a google search and find the bulbs from different vendors at cheaper rates.
    As far as knowing how to change it, Dell has excellent tech support.
    Nov 21, 2007 | Dell 2300MP Projector with 3-Year Advanced...
    Promima pro av 9400+ light dims slightly
    It may sound like the bulb needs replacing but first you should make sure that the outlet you plug it into has a constant 110 voltage. You may need to buy a voltage regulator to see if that works first. You can try a new outlet too. Sometimes other sources draw electricity from your wall outlet which cause the drop in voltage and poor lighting. Of coarse if that does not work, replacing the bulb would be the next logical solution. If your handy at opening it up, you could test the capacitors and connections for polarity and resistance with an ohm meter. Also check the current in the wall socket for constant voltage.
    Nov 20, 2007 | ASK Proxima Proxima LAMP-021 Replacement...
    57 people viewed this question
    Top Crayola Office Equipment & Supplies Experts
    k24674
    jasbo
    jasbo
    Are you a Crayola Office Equipment and Supply Expert? Answer questions, earn points and help others
