Question about Roku Televison & Video
Hello, Roku has been working for months. Sorce for TV is HDMI and Roku is HDMI3. As soon as I switch it to HDMI3 it goes within seconds back to HDMI.I unplugged and hit the reset button. Thank you
SOURCE: Power turns off automatically
Same w/ mine.  Repairman said they turn off auto to protect the set no matter what is wrong.  Take it to be fixed.  Mine was right at $100.  Works great again.
Posted on Oct 25, 2007
SOURCE: rca drc8060n
BTW - I did open the unit up, and my hunch is that it is a power supply issue. Also, the DVD drive appears to be a standard 5.25" IDE drive made by Philips. It might be worth salvaging for use in a PC if drivers and/or firmware exist for it.
Posted on Nov 19, 2007
SOURCE: sa-dx1040 dvd optical input works, tv and cd do not.
You have to manually select digital input on the receiver.
Posted on Aug 30, 2008
SOURCE: wont stay open
I had load of these units and the cure is simple. You need to replace the ribbon to the faceplate as these get damaged due to wear and tear. Every unit i had with this fault, i fixed by replacing this ribbon. Buy the ribbon and surround as the new surround is a modified one to give extra life to the ribbon. Hope this helps, good luck!
Posted on Nov 14, 2008
  • 41 Answers
SOURCE: Tv picture freezes then goes black 10seconds later HL-R5067W
Sounds like the digital board needs replaced.
Posted on Jul 11, 2009
No hdmi audio output except Roku 2.
You didn't mention whether you switched inputs on your TV for the different devices. Fix could be that simple.
Apr 30, 2016 | RCA Televison & Video
Just hooked up the streaming stick to HDMI to the TV. nothing is showing up, What do I do now?
Sounds like you have a bad connection on either your roku stick or your HDMI PORT.Does you ROKU stick show a white light if not check power cable or electrical plug.
Try wiggling ROKU stick just a hair or push it in and out until you get a signal..A purple screen with the words ROKU should show up on TV.If you have a bad port on TV it would have to be replaced but this is rare,if you have a second port on tv try that.Have you tried your ROKU stick on another tv?Does your streaming stick go in vertically or horizontally,if it goes in vertically it may be pressing against side of tv prohibiting a good connection.You could try a HDMI cable, plug the HDMI cable into tv and put ROKU in other side of cable.There is also a restart button on ROKU stick push it and it will start blinking,if it doesn't light up you may have a defective ROKU stick.
Feb 25, 2016 | Roku Streaming Stick HDMI Version
Out of no where my Vizio won't show cable, Blue Ray, or shows on Roku. One of the HDMI ports hasn't worked well for awhile so would have to switch HDMI ports to watch Roku or Blue Ray, but overall worked...
you may need to change the HDMI board in the tv. it will be the hole board the parts are just to small to replace them all to get the HDMI board working again. find a second hand replacement. should be fine with another known working one.
Sep 21, 2013 | Vizio Televison & Video
TV doesn't recognize HDMI with Roku
The Roku is the problem, not the TV. You need to go to the Roku site and request download information to synch the Roku to an HDMI input.
Jan 13, 2013 | Sony KLV-S32A10 32 in. HD-Ready LCD...
Why does our TV go through the channell setup everytime we turn it on?
Are you turning "OFF" the TV with a power strip ? or a switched wall outlet..
Check your power source..
Jul 15, 2017 | Sanyo 52" Class LCD 1080p 120Hz HDTV,...
HDMI signal cuts out for a few seconds constantly from receiver to television. It does it when switched to cable box and the roku box. Onkyo TX-SR606 Scientific Atlanta Cable box thru HDMI Roku Box...
Mine did the same thing where the screen would go black for a few seconds and then the picture and sound came back. I would try (1) switch HDMI cables, (2) try a different HDMI input in the back of the receiver, (3) try different input in the back of the TV. None of these seemed to work with mine. I finally ended up running the cable box direct to the TV and only run the audio through the reciever via coax or digital. No more problems. I think the HDMI inputs in the back of the reciever have a problem continuously carrying the signal if it is the leaset bit weak.
Sep 08, 2010 | Onkyo TX-SR606 Receiver
Plasma vizio 50 inch goes into deep sleep mode
when turned on tv no signal comes on a few minutes later deep sleep mode and tv turns on
Sep 17, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
Televison & Video Logo
Top Roku Televison & Video Experts
David Payne
David Payne
Thomas Stauber
Thomas Stauber
ray gallant
Are you a Roku Televison and Video Expert? Answer questions, earn points and help others
