Question about Car Audio & Video
I,have a Zeus zx7500 car amplifier I have all speakers and rca. Wires disconnected,and its,still in protected mode what do I do
GazllFixIt
  • 103 Answers
SOURCE: getting my amplifier out of protect mode
There is a problem with one or both of the audio amplification circuits. The amp is going into "protect mode" to protect your speakers. I'm afraid there is no simple fix. this will need to go to the shop to be repaired...
...unless you have been tinkering with the speaker connections recently. In which case, make sure all connections are sound & there are no wires touching other wires. This causes a short circuit. Leave it disconnected from the mains overnight. There's a slim chance it might spring back to life tomorrow.
Good luck & let me know how you get on.
Posted on Jan 10, 2008
SOURCE: Onkyo Tx-v940 Receiver/Amplifier Protection Mode
Audio amplifier IC's damaged you need to change it.Good luck
Posted on Jun 11, 2008
SOURCE: Denon AVR-1508 Receiver problems - cuts off and goes into protect mode
i have the same problem . denon had changed knob and circuits ?! one day later ... same issue !
i have 5.1 evo tangent 4-8ohms and 2 technics 8ohmsand i use frquently A+B configuration
Posted on Nov 08, 2008
  • 631 Answers
SOURCE: Protection mode
It's normal for some amps to go into protect for a few seconds when initially powered up. If it remains in protect mode, it may have shorted output transistors. To eliminate other possible causes, read through the following troubleshooting page:
Amp in Protect Mode - Troubleshooting
Let me know if you have any other questions.
Posted on Dec 11, 2008
  • 21 Answers
SOURCE: Problem With Onkyo Receiver Protected Mode.
If your receiver is going into protect mode with all speakers disconnected, you almost certainly have a shorted output transistor. Unfortunately, Onkyo recommends that a total of 14 transistors (on most models, 16 on some) be replaced. To make matters a little worse, a couple of those can only be obtained from Onkyo parts department.
Posted on Apr 07, 2010
Stays protection mode, how can i fix this?
Disconnect all speakers (at the amp terminals) and the RCA's leaving just power, ground, and remote connected. Does it turn on now without going to protection? If so, plug in the RCA's. Still good? If so, you have a shorted wire or bad speaker. If it still stays in protection, the amp is faulty. Have it repaired or replace it.
Dec 22, 2013 | PLANET Audio Rxd2400 Car Amp
Lanzar vibe266 2000 watt stays in protect mode
Disconnect all speaker connections and rca cables. Leave power, ground and remote wires intact. Try turning on again. If you still have a protection light your amp is faulty. Hopefully you have warranty .
.A thumbs up would be greatly appreciated if this answer is helpful to you. lanzar-vibe266-2000-watt-stays-in-zb4bomd1rt4qms0dqd12kkt2-3-0.jpg
Feb 05, 2013 | Lanzar VIBE266 Car Audio Amplifier
My Harmon kardon is stuck in protect mode
Disconnect all speaker connections and rca cables. Leave power, ground and remote wires intact. Try turning on again. If you still have a protection light your amp is faulty. Hopefully you have warranty. Double check all connections .A thumbs up would be greatly appreciated if this answer is helpful to you. Worth fixing.
Nov 19, 2011 | Harman Kardon Audio Players & Recorders
How do i reset my 4000 watt lanzar vibe 286 from being in protect mode
You can only reset it by disconnecting power to it. If it is in protect you may want to check your speakers and speaker wires for shorts and/or grounds. If they check out all right you may have internal problems in the amp.
Oct 28, 2011 | Lanzar VIBE286 Car Audio Amplifier
How do you reset nitro amp that is in protect mode?
If the amp is in protect mode, then there may be a speaker wire that is shorting out or you may have a bad speaker...you can test this by completely unhooking the speakers on the amplifier and then turning the amplifier on...if it comes out of protect mode then you will need to find out which speaker is bad...if the amplifier does not come out of protect mode when you turn it back on then there is a problem inside the amplifier and you will need to take it to a service shop for further diagnoses
May 15, 2011 | Nitro BMW-482 Car Audio Amplifier
My phoenix gold x200.4 amp turns on but the protect light keep on flashing
  • What does it mean when the LEDs flash on my amplifier?
    With most recently produced Phoenix Gold amplifiers, a flashing/blinking LED is an indication that the unit is in protect mode, usually due to an overcurrent condition caused by an internal short, external short (speakers), or low impedance. Overheating will also cause the amplifier to shut down temporarily.
    If amplifier remains in protect mode, power down the amplifier, disconnect the speakers, and power up again. If LEDs continue to flash, there is probably an internal problem with the amplifier that will require service attention to fix.
  • Sep 23, 2010 | Phoenix Gold ZX600ti Car Audio Amplifier
    Its in protect mode and wont go back to normal
    disconnect everything except the power, remote, and ground. turn off then on. if it goes into protect mode then there's a posibility that the amp if fried. check all the speaker inputs and outputs to make sure that there are no stray wires shorting out. if it stays on then you may have a short on a speaker wire or an auxilary input wire. plug each one in one at a time until it goes into protect mode, then that's the shorted wire or it could be a shorted speaker.
    Aug 09, 2010 | Nitro BMW-486 Car Audio Amplifier
    Protection fail
    DISCONNECT THE SPEAKERS AND ALSO DISCONNECT THE RCA INPUTS. POWER THE AMPLIFIER UP AND SEE IF IT GOES INTO PROTECTION. IF IT DOES, MAKE SURE ALL POWER CONNECTIONS ARE GOOD AND IF SO, THEN THE AMPLIFIER WILL NEED TO BE SERVICED. ALSO NOTE THAT AT NO TIME SHOULD YOU PROVIDE AN INPUT SIGNAL WITHOUT CONNECTING THE SPEAKERS, SO MAKE SURE YOU DO DISCONNECT BOTH THE SPEAKERS AND RCA INPUTS AS DESCRIBED ABOVE. HOPE THIS HELPS TO POINT YOU IN THE RIGHT DIRECTION.....V
    Dec 28, 2009 | Hifonics XX-Zeus Car Audio Amplifier
    My protect light is on amp no go
    disconnect the power wire from it for a minute then reconnect.
    Make sure the speakers are wired to an ohm load the amp can handle to prevent protection mode again.
    Nov 22, 2009 | Lanzar Vibe 410 Car Audio Amplifier
    Amp in power protect
    Protection Circuit is bad. It needs to be serviced. If all speaker wires are disconnected and it's still in protection, it's got a problem. Hope this helps
    Aug 08, 2009 | Sony Xplod XM-554ZR Car Audio Amplifier
    Car Audio & Video Logo
    Top Car Audio & Video Experts
    xxxxxx xxx
    Are you a Car Audio and Video Expert? Answer questions, earn points and help others
