Question about KitchenAid Refrigerators
KitchenAid KBFC42FTS Service Evaporator coil - KitchenAid Refrigerators
2 Suggested Answers
  • 9 Answers
SOURCE: evaporator coil continue frosting\build up ice
check the indoor fan motor, the indoor fan motor has to be running while condenser is on. make sure the filter is clean and the return vents are not blocked. Check charge.
Posted on Dec 16, 2009
I have a KitchenAid side by side refrigerator, model KSSC48QKS01 and the call service light is on and it is beeping every several minutes. Is there a common problem associated with this?
Correct me im mistaking but is that a buildin kitchenaid. If it is there is a service flash for evaporator fan motor. If you already changed the main board then the only other thing that can cause that is that service flash is a kit evaporator fan and the Bimetal. I would suggest to call kitchenaid and get the part number unfortunately I dont have it handy. But most likely thats the problem.
Jan 02, 2015 | KitchenAid Refrigerators
What does the code PO mean on my kitchenaid refrigerator?
On my KitchenAid, KRSC503ESS, to clear the PO (Power Out) message, press the 'measured fill' button on the front panel for 2-3 seconds. It is right below the word 'confirm' on the display. The technician told me that you need to confirm that you know the power went out so you don't eat any refrozen food. There is absolutely no information about this in the user manual or on the KitchenAid site
Sep 28, 2014 | KitchenAid Kitchen Aid 22.6 Cu. Ft....
My KitchenAid KSCS23INSS00 refrigerator double beeping. Compressor is working and I see some ice in freezer evaporator era but temperature in freeze and in refrigarator not going down. Frame beetween
Make sure your coils under fridge are not obstructed. The Black grill at the bottom pulls strait off allowing access to the coils. There is a long skinny brush made for the purpose of cleaning the pet hair and dust bunnies from between the coil rows. If you have a pet this is a regular task. The brush can be purchased at most hardware stores, just ask for a coil brush. Without sufficient air to pass across these coils the return Freon doesn't have a way to dissipate the heat.
Sep 18, 2014 | KitchenAid KSCS23INSS Stainless Steel Side...
How to fix kitchenaid kbfc42fts bottom freezer builds up ice and leaks on floor
The drain line is clogged go around the back of machine take off back cover and you will see a drain line coming through the floor and at the end of it is a rubber grommet.The rubber grommet is clogged up just take it off and throw it out and then turn off machine for 24 hrs with doors open to melt out all the ice
Aug 08, 2014 | KitchenAid KBFC42FTS 42" Bottom Mount...
Kitchenaid Side by Side refrigerator
Check the defrost heater for continuity.
Jun 26, 2013 | Refrigerators
My refridge is too cold in the back side. Things are freezing near the back. Should I just lower the temperature?
same problem was on my customers refrigerator. found leak at evaporator, if you watch the whole vid pay atantion to the defrost heater, black piece, got deformed over the years and was touching evaporator in several spots. Heater burned holes in evaporator coils. This is Thermador refrigerator, but same design as KitchenAid, even parts are edentical. Hope That will help to explain Your problem!
May 14, 2011 | KitchenAid Architect Series II KFCS22EV ...
Is it possible to replace the handles on the KitchenAid 42" built-in stainless french door refrigerator (KBFC42FTS) with different handles? Ideally handles that look more like the handles on the Pro...
most the handles will inter change . you will need the model # of the other frig in order to get the ones you like . but keep in mind they are not inexpensive . I looked up one of these pt # 2316868 stainless handle and are sittind down! they are $ 101.93 each . . and you need 3 .. hope this helps mm feed back pls
Jan 20, 2011 | KitchenAid Architect ® Series II KBFC42FTS...
My Kitchenaid refrigerator stop freezing. It still gets cold on both sides. But the freezer does not freeze anymore. I was told that it was the coils need cleaning, so I blew them ouy with my air...
It could be a freon leak, or the compressor is not staying on.  If you can hear a clicking sound coming from the back every couple of minutes, your compressor overload is kicking off.  More than likely you either have a freon leak, or a defective compressor. Check the warranty on your machine as many manufactures warranty the sealed system for much longer than the rest of the refrigerator.
Nov 03, 2009 | KitchenAid Superba Architect KSCS25INSS...
Kitchenaid Bottom mount refridgerator is has stopped cooling but freezer is maintaining correct temperature$FILE/FDBMREFRIG.pdf
We replaced the evaporator motor. Use an Ohmmeter to see if electricity is going there, first, see if fan is running, then, if not, replace evaporator motor-part # 12002744.
Fridge is now running! I'll post again, if there is any more to the story. We are now waiting to see if it gets to temp, but it is running. I'd love to find info on a reset code.
Sep 23, 2009 | KitchenAid Architect KBFA25ERSS Stainless...
Build in kitchenaid, freezer working but not freezing
This video I made how to change evaporator on Thermador refrigerator, which is just copy of of Build in Kitchenaid. Problem was that it was running, but ice cream never got frozen. I checked pressures, was low on freon. I checked evaporator coils - found out that defrost heater got deformed and was touching evaporator coils - so it burned holes, where freon started to leak.( I think it designed not best way). Defrost heater on this fridges way to close to evaporator coils. Check this video to get an idea what Im talking about. I hope That helps u to understand why this repair is so expensive and what causing it.
May 08, 2009 | KitchenAid KSCS25FKSS Side by Side...
Refrigerators Logo
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
