Question about Internet Computers & Internet
What is the part number for the defrost timer for the Amana refrigerator model #asd2522wrb06. It's not AP3109394 as I was told on here previously. It looks like W10366605. Please confirm.
I found on the internet that W10366605 looks exactly like the part I need. Can someone confirm compatibility please. Again, it's NOT AP3109394 or 4388932 as was suggested before.
Krazytech
  • 725 Answers
SOURCE: amana refrigerator not cooling
you may have a bad defrost thermostat .. it is on the evapator check it with a ohm meter and see if its open..
let me know
Posted on Jul 08, 2008
  • 111 Answers
SOURCE: Defrost timer sticking
Your model doesn't have a defrost timer. Everything is controlled by the main motherboard in the back. The ONLY way to get an acurate diagnosis is to call GE FActory Service at 1-800-432-2737. There is proprietary software and the tech will be able to plug in a laptop to your refer to find out what is going on. No other companies have this or have access to this software. By the way that deforst thermostat you think you found isn't what you think it is. It looks like one but it only a saftey device. Trust me...!
Posted on Dec 16, 2008
peyton32034
  • 410 Answers
SOURCE: Does new defroster timer require adjustment?
 there are 3 components in the defrost system that can go bad. timer, defrost thermostat, and defrost heater. since youve already replaced timer that means youve eliminated it as a bad component. the most common defrost system failure is actually the defrost thermostat. moisture will infiltrat into the control and ause it to short out. the way to check it is:
  • unload freezer section
  • remove shelving
  • remove icemaker if applicable
  • remove rear access cover
  • once coil is exposed look for a round disc shaped peice that is attached to the top of the coil and has 2 wires going to it
  • hopefuly the control will still be frozen
  • using a multimeter set to ohms sheck for continuity on the 2 wires that go to control
  • if the control has continuity then you have a bad heater if no cont then bad defrost sensor
  • in alot of cases you will actually see that the control has seperated and come apart and you will not even need a meter.
I hope this helps you out. while you have unit pulled apart and after youv'e diagnosed the problem use a hair dryer to defrost ice build up on the coil. this will get the unit working temporarily until you get a replacement part.  thanks Peyton
Posted on Mar 19, 2009
SOURCE: I need to know where to find the defrost timer on
I just replace my defrost timer & defrost thermostat. The timer is in the front bottom. Remove the kick plate at the bottom & you should see an orange knob. It takes about 10 min to replace. The thermostat is located in the freezer section. Remove the lower panel. This will expose the cooling coils and the defrost thermostat. Takes about an hour to replace.
Posted on Jun 16, 2009
SOURCE: I need a diagram for amana refrigerator model
My Amana refrigerator freezes everything. It has a bottom freezer.
Posted on Feb 14, 2010
Adaptive Defrost Control Board Part Number: AP3109394 MFG Part Number: Made by: Whirlpool
Apr 14, 2017 | Amana Refrigerators
My refrigerator & freezer are not keeping things cold/frozen unless the items are in the very back of the unit. I have been told it could be the defrost timer. I have the Amana fridge with freezer on...
Might try defrosting the unit manually,this will let u know if possibly bad defrost timer or heater,or thermister on condenser behind freezer panel try YouTube put in model number,should link you to an APV video.
Dec 27, 2017 | Amana ARB9058CS Bottom Freezer...
ARS8265 requires frost buildup to be removed from the supply outlet between freezer section and refrigeration section. The doors are opened only briefly but still regular plugging of the outlet. Seems...
The defrost on your model is began by the part=> 67001036 Defrost Timer All of this is hiding behind the controls=> Amana ARS2464BW Side by Side Refrigerator Control Panel Hope not to confuse you but we begin here and sometimes just getting the location is very helpful. I want you to find a hole that may be covered by a plastic plug that leads to the timer control in the photo below. Using a flathead screwdriver I want you to slowly turn the timer clockwise until you hear the compressor and fans stop. This should mark the beginning of forced defrost for your model. This begins the cycle of defrost on your timer that should last about 20 to 25 minutes every 8 hours three times daily. Once defrost starts the defrost heater inside the back wall of freezer should begin to heat up. If your timer does not come out of defrost simply turn clockwise again a little and this will manually get the timer out of defrost Opening the freezer door and listen for the sound of cracking or sizzling. If for some reason you get defrost when you do this then you need to replace the Defrost timer part Number 67001036 Click Here=> Testing Your Defrost Heater That page has your instructions on how to test your defrost heater just click on the tutorial at bottom right of that page. Your Defrost Heater is part number=> 12049801 and the defrost thermostat is part number=> R0131454 If you need to replace the defrost heater always replace the defrost thermostat. In your case the problem is most likely the defrost timer but these steps are the best way to diagose your models defrost problems. I will be here to answer any questions you may have, Thanks, Sea Breeze
Apr 21, 2011 | Amana ARS2464BW Side by Side Refrigerator
We have an Amana bottom freezer refrigerator model drb1910cc which has had frost build up problems in the freezer compartment. Eventually the refrigerator section warms up. We now have a defrost timer and...
More than likely it’s not the defrost timer it is most likely to be the bi metal it’s in the evaporator area in the freezer section
Refrigerator defrost bi-metal thermostat
Parts #: 12001937
Substitution: 12001937 I gave you the part number all you have to do is order it and install it
I’m happy to help further over the phone at https://www.6ya.com/expert/george_106a9535a98aec8a
Dec 15, 2017 | Amana ARB1905C Bottom Freezer Refrigerator
ATTEMPTING TO LOCATE DEFROST TIMER. DO U KNOW LOCATION ON MODEL # ARB2217CW
Up in the console with the light bulb and cold control is that there defrost timer. Number 12
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jan 01, 2011 | Amana ABB1927DE Bottom Freezer...
The freezer isnt working, it is running not cold enough model number ARB190ZCS
Your model has a simple defrost timer inside fresh food compartment and behind control panel. I would see if I could manually turn the timer clockwise until defrost comes on and compressor stops. If after 25 minutes it does not turn itself back on turn the time again clockwise slowly until it restarts. Part number 67001036 Defrost Timer
Dec 16, 2009 | Amana ARB190ZCS Bottom Freezer...
Refrigerator section on side by side losing cooling
Here is the Amana website with the manuals which should show you where the defrost timer etc. is located. Witht your model number and manual it will be a lot easer
http://shared.whirlpoolcorp.com/product_literature/search.jsp?siteCd=AMA
And yes the defrost timer thermostat and heater are the most likely problem.
Do not let this keep running and running or you may lose your compressor too which means a lot more expense than now.
May 09, 2009 | Amana Refrigerators
Defrost timer location for a amana model SR25F1L
part number (d7004112), its located under unit, remove back panel should be mounted to a metal plate along side compressor
Nov 13, 2008 | Amana 22.6 cu. ft. Side-By-Side...
Computers & Internet Logo
35 people viewed this question
Laxman Bisht
Laxman Bisht
vojvodabudva
