Question about Brother Sewing Machines
Please help the feed dogs on my brother LS 1217 has dropped I have taken the back off and the white bar with the teeth is in tact What else can I do
  • Brother Master
  • 11,769 Answers
Perhaps this will help:
Brother LS1217 feed dog repair
Posted on Apr 16, 2017
Problem with brother vx-1120 will not feed fabric
This is usually caused by the feed-dog ( the metal teeth in the area below the needle) being down instead of up - run your finger under there (over the teeth) if they do not stick up above the base line of the machine, they cannot feed the fabric. If this is the case, look in your manual (or and online manual for your machine) and find out how to put the feed dog up. Other than this, some machines have a plastic plate which fits over the feed dog, so that you can do free machine embroidery, if this is the case, you should be able to remove this and the fabric will feed through
Nov 30, 2012 | Brother LS-2125 Mechanical Sewing Machine
Hi, have tried to use buttonhole feature on singer 4423. Dog feed teeth have dropped - won't come back up and the material isn't feeding though. Any help greatly appreciated.
Re: Reverse feed dogs on Singer 4423 Remove extension table so you can see switch on BACK of machine @ left side. Flip switch to raise feed dogs up. If machine actually sewing in reverse - check n Buttonhole adjustment. Reset it (located bottom right side machine) Jimmy
Apr 04, 2012 | Singer 4423 Sewing Machine
I can't fund how to put the teeth on my Brother LX-3125 down, How would i?
There's a switch on back of machine to raise feed dogs to up position. Perhaps an extension table needs to be removed so you can see its location Jimmy
Apr 03, 2012 | Brother LS-1217 Mechanical Sewing Machine
The feed dogs are down is there any way to raise them?
Read your manual and you will have to move your handwheel, towards and they will come up. Get a copy of your manual to download for free at brother-usa.com. Good luck
Aug 30, 2010 | Brother LS-1217 Mechanical Sewing Machine
Fabric not able to move between foot and base.
you are talking about your feed dogs, do you have your manual? It will explain how to adjust them. If, that fails call the company support team. Most companies have a support section online at their site, and you usually can download you manual for free. If it is a Brother, google, Brother.com
Jul 24, 2010 | Brother LS-1217 Mechanical Sewing Machine
My Brother LS1217 does seem to be feeding the material properly
Are the feed dogs in the down position? There should be a lever in front or in back of the needle area..you may have to remove the freearm to find it. Once you flip that switch, you have to turn the hand wheel towards you almost a full turn to make the feed dogs pop back up.
If they are up & not moving...then something is caught in them...a bit of lint or thread probably.
May 14, 2010 | Brother LS-1217 Mechanical Sewing Machine
The dog foot has fallen down, it is still sewing but not pulling the fabric through.
If the teeth have dropped and you do not have a drop feed lever you will need to get into the bottom of the machine and raise the teeth slightly and tighten the screw.
Nov 02, 2009 | Brother LS-2125 Mechanical Sewing Machine
Stitch lendth isnt working, all the stitch lengths come out the same regardless of the setting
Are you sure that the feed dogs have not been dropped to enable embroidery, and not returned to the normal sew position, consult the handbook for instructions.
Oct 13, 2009 | Brother LS-1217 Mechanical Sewing Machine
The fabric doesn't move forward.
We need to do some examining. Remove the foot. Put the stitch length dial at the longest stitch. Turn the wheel and see if the feed dogs move about 1/4 inch. Also check to see that they rise just slightly above the needle plate. If it does these two things it will work. If the teeth don't rise above the plate, remove the needle plate and clean the lint out from between the rows of teeth. If you find a lot of tightly packed lint there this will solve your problem. Reinstall the needle plate and foot. If the feed dogs don't move about 1/4 inch, you probably have a problem which is going to require the services of a technician.
sewman7
Jun 09, 2008 | Brother LS-1217 Mechanical Sewing Machine
Feed dog & auto threader problems.
Remove the needle plate and clean the lint from between the teeth of feeddogs, also around and inside bobbin case.
The switch for the feeddogs is to raise (normal sewing) or lower (free motion) and if there is no difference, the accumulated lint will have made a felt pad between the teeth forcing the feeddogs to stay down and present with the problem you describe.
When things go a little "weird", the common instinct is OIL EVERYTHING............DON'T DO IT !!! ....this is rarely the solution on its own account, and can make the servicing a great deal longer as the excess must be removed........little oil regularly, not a bucketful every 5 years is a better approach.
Apr 23, 2008 | Brother LS-1217 Mechanical Sewing Machine
Sewing Machines Logo
46 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
