Question about Keurig B50 Coffee Maker
I accidentally left it on for a couple of hours. i unplugged it for a couple of days. It says its ready but it won't brew. Please help. (Keith)
    Problem Solver:
  • 10 Answers
What machine do you have?
Posted on Aug 02, 2009
My cuisinart keurig coffee maker won't brew. It
Try this.
There are a number of ways to descale a brewer, the least expensive being to run some vinegar through the machine a couple of times, and then run cold water through a few more times to rinse it.
However, simply trying to clear the lines often doesn't work. And as you will see from the many comments below, by far the most reliable way to get your Keurig brewer working again is the "Slap and Burp" method.
Here is how you do it.
First, unplug the brewer and remove both the water reservoir and drip tray.
Next, hold the brewer upside down over the sink and slap the base a few times. And I mean really slap it.
Now put everything back together and try brewing again. Most of the time this works with a couple of good slaps. If not, try it again.
And don't worry, there are no laws against giving your Keurig a good slapping!
Jun 03, 2013 | Coffee Makers & Espresso Machines
My brew group is jammed. I need to remove the screw that holds the small coupling water inlet to the brew group. The problem is that I cannot seem to find that screw in my Incanto Classic machine.
Hi
Its on the left inside of the brew unit. There is a hole on the left side of the brw unit. That hole is to access the screw in the normal position but now it has mover. You will have to go in from the side. Its a #1 Phillips screw. You will need a 6" screw driver.
Here are the directions you will need.
You must make sure that the brew unit is ready to reinsert into the machine. To return the brew group to the centered position, you first need to drop the funnel. To do this, look on the opposite side of the brew group from the handle. At the top you will see an object that looks like a sharks fin. If you follow this piece down you will see 2 horizontal bars on the brew group body. Push your finger between these 2 bars and the funnel will drop. If you have you key you can insert it in the front of the brew unit. There is a round hold in the center below the “Push”, and twist it clockwise until it stops and the 2 marks are lined up. If you don’t have your key you can do this. Push the puck slide on the left side down and to the center. If you look down through the funnel you should see a piston. This should be centered in the funnel. If not, locate the slide on the left side of the brew unit, (it should be hanging down, a flat rectangular piece attached to the cylinder) and push the slide to the right until it does. Press the “Push” lever until you hear a click and you are now ready to reinsert the brew group in to the machine. First you must close the door with the drip tray and dredge drawer inserted, and turn on the machine without having the brew group in. You will hear the motor turn on and when it stops completely, open the door and remove the tray, and dredge drawer, now insert the brew group, and replace the tray. If it still won’t go in check the cog in the back of the machine. There are 2 wide teeth that should be at the 10:00 and 12:00 position. If they are at a different position you have a broken drive gear.
Dec 27, 2009 | Saeco Incanto Classic Espresso Machine
Program light and 12:00 are flashing, no buttons work
Press program set once, then switch to clock mode to set time.
Sep 27, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
My DVR-625, wont even turn on.
at the time the hard drive problem came up the receiver would of went into recovery mode this can take a good hour for it to fix and can do nothing until it would finish on its own and take care of. Doing the power reset is just like unpluging the receiver. Try unpluging again for 30 minutes and plug back in again and just wait receiver should come back on its own. Don't hit any buttons. If not will have to send out to dish for repair. 800-333-3474 dish
Nov 22, 2007 | DISH Network DVR-625 DTV Receiver /...
2nd time using this brand new machine and it won't brew.
try unplugging the unit for 1 1/2 hours to reset the electronics...I just called them and that was their advice...we shall see..worth a try
Aug 09, 2007 | Cuisinart DTC-975 Coffee Maker
DGB 600 Grind & Brew
Had the same problem, I used coffee pot cleaning solution a couple times through and it woks fine. Had to do this a few times now. Cleaning solution is the type bought at local retail store.
Aug 03, 2007 | Cuisinart Thermal DGB-600 Grinder
Keurig B50 Coffee Maker Logo
225 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
