Question about Garden
SPARK PLUG GAP FOR E3CHO PPF 210 TRIMMER - Garden
  • Garden Master
  • 3,755 Answers
The manufacturer's recommended gap is suitable for the types of spark plug recommended by them. Other makes of plug often use a different gap.
I suggest you check your spark plug manufacturer's online catalogue.
Posted on Apr 15, 2017
    Master:
  • 347 Answers
0.026
Bosch spark plug gap for a fs46 weeteater
Hi
Stihl recommend 0.020 (20 thousands of an inch) or 0.5 mm. Incidentally the plug gap is independent of the plug make.
Regards
Jacko from down under
Aug 15, 2014 | Stihl Km 38 45 46 55 Trimmer Clutch Drum
What is the spark plug gap for a Ryobi string trimmer model RY30550 ?
No need to gap from a new spark plug unless the plug was dropped on the electrode.
May 02, 2014 | Ryobi Garden
25cc Craftsman line trimmer: - will not start. - no spark across the gap of the plug - plug shows no corrosion.
Hello there and thank you for choosing fixya
normally on these when you dont recieve a spark and you are 100% sure that the spark plug is good than the only thing left to check is the ignition coil
It is what the plug wire is connected to kind of a square or round part these are nortorious for going out in small engines this is a 35 dollar part ok?
thee if this does not do it check the on off switch for continuity
Then finaly Check the flywheel cover, the magneto gap and starter coil if there's still no spark.
Read more: How to Troubleshoot a Small Gas Engine Trimmer ' eHow.com http://www.ehow.com/how_6306856_troubleshoot-small-gas-engine-trimmer.html#ixzz1LrUTc28o
May 07, 2011 | Craftsman 25cc Gas Line Trimmer
25" /1.5 cu.in. 2-cycle 17" cutting
Easy way to test plug is to remove it from cylinder head, then ground its hex base to side of engine..reattatch plug wire and pull starter cord...Do this is dim light...need to see a nice blue spark. So, do that...check the plug gap and plug condition (even if new)...if it's NOT firing...try another plug...if same...you will need to pull the engine covers off and check the "air gap" of the flywheel magnets to the pickup legs on the ignition coil module. You can gap it the thickness of a regular business card (.010"-.014"). The gap has to be present for the spark plug to produce a spark.
Jul 16, 2010 | Craftsman 25cc Gas Line Trimmer
Spark plug gap
What plug are you currently using?
if its a DJ7Y gap at 0.025 tapered seat
if its a DJ7J gap at 0.030 tapered seat
if its a CJ8 gap at 0.025 gasket
if its aCJ6Y gap at0.030 gasket
if its a CJ6 gap at 0.030 gasket
these are champion plugs
if you have different cross reference your make
Jul 05, 2009 | Homelite Mighty Lite Lawn Trimmer
Home lite String Trimmer Won't Start
be sure your kill switch is set to run positon and the wires from it arent grounding theirself out . Make sure your spark plug is
grnded to metal when you check for spark.(ground to head away from the spark plug hole
You may have a bad ignition module if you still have no spark or the flywheel keyway has sheared for some reason throwing it out of timing.(removal of flywheel is required to see if the keyways are aligned flywheel and crankshaft)
If your flywheel seems tight then you may be ok
not a high failure rate but it has happened.Gap your plug at .030 then.025 see if that makes a difference? keep going to a smaller gap to show you may have a weak module not able to jump a wider gap.
just a couple things to check hope this helps maybe
May 31, 2009 | Homelite Mighty Lite Lawn Trimmer
I'm looking for a free downloadable owners manual for a McCulloch gas trimmer, model 1385L, or at least to find out what the spark plug gap should be.
spark plug gap is .025
spark plug recommended for this trimmer is DJ8J
Or RDJ8J if you dont want radio interference or if you do not like champion plugs NGK isMB6F
torqed at 110-120 inlb.
May 05, 2009 | McCulloch 26cc Gas Blower Mcb3208
Garden Logo
23 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
