Question about The Audio Players & Recorders
My HV800 Wireless Bluetooth headphones only play out of the right ear bud. What am I doing wrong?
SOURCE: Sound very muffled in right ear bud
Yes, more than likely it is the wax build-up inside the screen of the earbuds. Take a tack and lightly pry the screen out. You will definitely see a noticeable amound of "gunk on the inside. Clean and you will hear a clearer and crisper sound. If you put the screens on flush and press them in they will stay.
Posted on Sep 26, 2008
  • 93 Answers
SOURCE: My right earphone won't play
Sound not coming out of one side of the headphone is an indication of connection failure, so that means you have to see where its 'broken' from, either inside the headphone on on the wire somewhere. Usually it happens at the jack, especially if you use an ipod as it tends to get moved alot in pockets, etc..
If this is the case, you could try to cut the wire from where you suspect its broken, and get a 3.5mm (or whatever the original size is) replacement (Do-it-yourself) jack from Radio shack or electronics store.
THen you would have to cut the wire, strip the the rubber coating off, and then if applicable, carefully strip the very thin layer of further insulation thats on the wire it self. Otherwise you would directly connect the cables to the prongs/connections located on the replacement jack. And depending on the jack you would screw it in place or soldier it with soldier and soldiering gun.
If its broken in the headphone or at the headphone, thats much harder to do as you would have to open the head/earphone case and soldier it that way and get it back together in one piece.
Next time don't buy bose headphones and by something cheaper, bose isn't that great, skullcandy is pretty good too. Sennheiser is the best though in my opinion. albieit its expensive too..
Posted on Feb 27, 2009
SOURCE: Only One Ear Bud Works
It is likely that your right stereo channel has either been severed somehow or there is a severe short in one of the cables. What you can try to do to test this theory is first turn on your music. Then wiggle the cable at the very base of the right earbud. If nothing happens wiggle the cord right where it connects to the stereo jack. If still nothing happens run your fingers along the right earbud audio cable bending and twisting it. If at any point you hear music again then you likely have a short. If it is near the earbud then it is going to be difficult to fix since these earbudfs have a large gauard. If the short is at the stereo jack then the fix is simple. A standard 1/8" stereo jack can be purchased from any electronics or audio store. You can then fairly easily seperate teh old stereo jack and solder this new one in place. Search the internet for tutorials on how to do this if need be. Even if you do not get any kind of sound when wiggling it at the base of the jack this is the most likely culprit since this is where most of the stress on the headphones occur. Be wary though, if you do attempt a stereo jack repair you will void whatever kind of warranty your earbuds may have so check before you try. But, in teh end you may end up saving a 60-100 dollar set of earbuds for 5-8 dollars. Hope this helped.
Posted on Sep 19, 2009
  • 272 Answers
SOURCE: my skullcandy earphones are busted
could be caused by the way you wrap them up the cords should never be wound tightly it causes a short and it just so happens that earphones are made of light weight wiring to make them seem to disapear when wearing them so what to do is instead of winding them when your done simply fold them loosely so to speak
Posted on Feb 25, 2010
  • 23 Answers
SOURCE: My skullcandy ink'd headphones have
Most likely they are defective, and you should take them back if
you have the receipt, or warranty.
Posted on Oct 05, 2010
Testimonial: "how do i get warranty?"
My phones' audio jack won't play music from the right ear bud
Have you use another headphones insteading of your Sony headphones to have a try? Make sure it is not the problem of headphone, then you may need a headphone jack replacement to replace the old one.
I've also met this situation with my phone. Finally I found the right
Headphone Earphone Audio Jack Flex Cable for Samsung Galaxy S4 i9500 to solve this problem. You can also look for one repair part for your phone, then find a video following to fix. It is easy to make it. Hope it can help.
Mar 07, 2014 | Bose QuietComfort 2 Consumer Headphones
Jvc gumy ear bud headphones purple
When you pull the wire up does it increase the right ear bud volume/ sound? If it does, then it means the right side ear bud has a short within the head phones circuit which is aka the wire that leads to the musical device in which the ear buds branch off from.
If the right side ear bud does not produce an increased volume for sound by picking the wire up or pulling it in towards you or to the left side of your body or musical device then it means that the right speaker is blown.
I know that all head phones come spiced together aka they are stuck together and have to be pulled apart in order to get both head phones seperated from each other so that they can be worn in the ears. If you pulled the wire apart to much or too quickly then that is what ruined the right head phone.
I suggest that regardless if the ear phones begin to work by pulling the wire up,side ways, or into towards your body that you return them back to the store since after awhile the problem will eventually continue to happen causing the right ear bud to completely blow. Once you return the ear phones be cautious with the new set when you seperate the ear buds from each other since they are very touchy and have to be handled with delicateness when seperation is taking place.
Please let me know how it works out for you. I have had many ear buds and I tell ya something; they are very easy to blow one side when seperating. I had to learn after a few pairs that I was ruining the speakers by the way I was seperating my wires. I kept thinking for the first 3 pairs that the store was selling blown ear buds until I began having same problems with another few stores so I said to myself "well the solution is to figure out what I am doing wrong in order to blow one side of my ear buds every time". After few seconds it was not that obvious that all I had to do for assembly was to pull the wires apart in order to get both ear buds to go into my ears.
Jan 22, 2014 | JVC Gumy Ear Bud Headphone - Peppermint...
Left ear phone does not work with bluetooth on the beats wirless
This worked for me! Just reset like the video. Had to do it a few times but working great now.
Apr 08, 2013 | Beats By Dr Dre - Wireless Bluetooth...
The left and right ear bud work some times. and if i turn the base were you plug it into the device it coukd work how can i fix it so they can both work at the same time.
Probably can't. What typically happens is that the base of the wire gets stressed from wrapping the cord around you media player and it eventually breaks the copper wire inside of the insulation. You likely can not even see the damage, let alone repair it. Be more carefull with the next set, and might I recommend a set of AKG ear buds. I use AKG studio headphones and bought my little sister some AKG ear buds, very impressive quality very close to my studio headphones. AKG K 313
Oct 29, 2010 | Skull Candy LINK Earbuds Consumer...
Wiring diagram for skullcandy headphones
The cat chewed my skullcandy headphone wire in two, how do I splice them. Thank you, Robin
May 17, 2010 | Audio Players & Recorders
Left ear bud does not work
yes a coil can burn out in secounds i think you have better have the unit looked at by an technition
Apr 21, 2010 | Sony Bud Style Headphones
I need a replacement rubber ear pad for one of my headphones.
most best buy stores have extra axcessories where the headphones and portable tape players are. try there, they might have them.
Mar 19, 2009 | JVC Gumy Ear Bud Headphone - Peppermint...
I lost one of the ear cushions of my insignia head phones
hi u can get these ear cushions in all bluetooth  accessories shop...
Feb 09, 2009 | Insignia Bluetooth Wireless Headphones...
23 people viewed this question
Top The Audio Players & Recorders Experts
Jose Ma DM.
Jose Ma DM.
Level 1 Expert
Are you a The Audio Player and Recorder Expert? Answer questions, earn points and help others
